Hi,
I found a problem with Plasma notifications, the problem is that, when using the default font which is Noto Sans
at a size of 9, if a notification has large content (more than 1 line), like a Spotify song change, it doesn’t wrap to the next line, it just gets cut with “…”. As can be seen in the first image:
https://imgur.com/a/DNiuYX0
(can’t post pictures yet)
But if I use another font like Inter
using the same 9 pts size, this doesnt happen (2nd screenshot):
It only happens with the title, the rest wraps correctly to the next line, as can be seen in the screenshots.
Also when using another font that isn’t the default, the header gets smaller.
