I improved the script a bit and removed the dependency on grep
and awk
Here is an improved version that allows to:
- Manually set the size of the RAM used.
SIZE=x
andSIZE_TYPE=y
where y can beKiB
,MiB
orGiB
(Default). - Prevent use of unsupported compression algorithms.
- Prevent the use of more as max RAM
ZRAM_MAX_PERCENT=x
(50% Default) -
RAM_PERCENT
is used to config a percentage of max ram (20% Default). A non-zeroSIZE=
takes precedence.
You can start/enable it as usual:
systemctl enable --now zramswap-trimoon
File /etc/zramswap.conf :
SIZE=8
RAM_PERCENT=25
# See: cat /sys/block/zram0/comp_algorithm
# One of: lzo [lzo-rle] lz4 lz4hc 842 zstd
ZRAM_COMPRESSION_ALGO=zstd
File /usr/lib/systemd/scripts/zramctrl.trimoon :
#!/bin/bash
declare -i ZRAM_MAX_PERCENT=50
declare -i RAM_PERCENT=0 SIZE=0
if [ -f /etc/zramswap.conf ]; then
source /etc/zramswap.conf
fi
start() {
local Item Multiplier AVAILABLE_ALGO
local -i Amount RAM_TOTAL_BYTES ZRAM_SIZE ZRAM_SIZE_REQ FOUND_ALGO
test $RAM_PERCENT -eq 0 && RAM_PERCENT=20
test $RAM_PERCENT -gt $ZRAM_MAX_PERCENT && RAM_PERCENT=$ZRAM_MAX_PERCENT
# echo $RAM_PERCENT
# Grab max memory
while read -r Item Amount Multiplier; do
test "$Item" != "MemTotal:" && continue
# echo "|$Item|$Amount|$Multiplier|"
case $Multiplier in
kB) RAM_TOTAL_BYTES=$((Amount * 1024)) ;;
mB) RAM_TOTAL_BYTES=$((Amount * (1024**2) )) ;;
gB) RAM_TOTAL_BYTES=$((Amount * (1024**3) )) ;;
*) RAM_TOTAL_BYTES=$Amount ;;
esac
# echo "$RAM_TOTAL_BYTES $RAM_PERCENT"
done </proc/meminfo
# SIZE=8
# Manual size config?
if test $SIZE -gt 0; then
case "${SIZE_TYPE:-GiB}" in
KiB) ZRAM_SIZE_REQ=$((SIZE * 1024)) ;;
MiB) ZRAM_SIZE_REQ=$((SIZE * (1024**2) )) ;;
GiB) ZRAM_SIZE_REQ=$((SIZE * (1024**3) )) ;;
*) ZRAM_SIZE_REQ=$SIZE ;;
esac
if test $ZRAM_SIZE_REQ -gt $((RAM_TOTAL_BYTES * ZRAM_MAX_PERCENT / 100)); then
ZRAM_SIZE=$((RAM_TOTAL_BYTES * ZRAM_MAX_PERCENT / 100))
echo "Using: $ZRAM_SIZE Bytes (Clipped at $ZRAM_MAX_PERCENT% of max.)"
else
ZRAM_SIZE=$ZRAM_SIZE_REQ
echo "Using: $ZRAM_SIZE Bytes ($SIZE ${SIZE_TYPE:-GiB})"
fi
else
ZRAM_SIZE=$((RAM_TOTAL_BYTES * RAM_PERCENT / 100))
echo "Using: $ZRAM_SIZE Bytes ($RAM_PERCENT% of max.)"
fi
# Load the zram module
modprobe zram
if test -n "$ZRAM_COMPRESSION_ALGO"; then
# Iterate over available compression algorithms.
for AVAILABLE_ALGO in $(</sys/block/zram0/comp_algorithm); do
# Remove brackets from active one
AVAILABLE_ALGO=${AVAILABLE_ALGO#[}
AVAILABLE_ALGO=${AVAILABLE_ALGO%]}
# echo "$AVAILABLE_ALGO"
if test "$ZRAM_COMPRESSION_ALGO" = "$AVAILABLE_ALGO"; then
FOUND_ALGO=1
break
fi
done
# Only change algorithm when available.
if test $FOUND_ALGO -eq 1; then
echo "$ZRAM_COMPRESSION_ALGO" > /sys/block/zram0/comp_algorithm
fi
fi
# Setup the ZRam swap.
echo $ZRAM_SIZE > /sys/block/zram0/disksize
mkswap /dev/zram0 -L zram0
swapon -p 100 /dev/zram0
stop() {
swapoff /dev/zram0
rmmod zram
case $1 in
start|stop) "$1" ;;
esac
File /usr/lib/systemd/system/zramswap-trimoon.service :
[Unit]
Description=Zram-based swap (compressed RAM block devices)
Documentation=https://forum.manjaro.org/t/improved-zramswap/34767
[Service]
Type=oneshot
ExecStart=/usr/lib/systemd/scripts/zramctrl.trimoon start
ExecStop=/usr/lib/systemd/scripts/zramctrl.trimoon stop
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
> systemctl status zramswap-trimoon | xclip
● zramswap-trimoon.service - Zram-based swap (compressed RAM block devices)
Loaded: loaded (/usr/lib/systemd/system/zramswap-trimoon.service; enabled; vendor preset: disabled)
Active: active (exited) since Fri 2020-10-30 15:53:08 +03; 47min ago
Docs: https://forum.manjaro.org/t/improved-zramswap/34767
Main PID: 49644 (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 38400)
Memory: 0B
CGroup: /system.slice/zramswap-trimoon.service
Eki 30 15:53:08 manjaro systemd[1]: Starting Zram-based swap (compressed RAM block devices)...
Eki 30 15:53:08 manjaro zramctrl.trimoon[49644]: Using: 8589934592 Bytes (8 GiB)
Eki 30 15:53:08 manjaro zramctrl.trimoon[49656]: Setting up swapspace version 1, size = 8 GiB (8589930496 bytes)
Eki 30 15:53:08 manjaro zramctrl.trimoon[49656]: LABEL=zram0, UUID=8458757a-fb36-4088-894b-ba1ec9e48fa2
Eki 30 15:53:08 manjaro systemd[1]: Finished Zram-based swap (compressed RAM block devices).
If the owner/maintainer of the zramswap
AUR package sees this he may update his version with this one while renaming the above versions without the trimoon
parts
See also my comment there…
