Hello, today I updated my graphic card driver and after that, my external screen couldn’t be seen by my computer. So I installed optimus-switch(GitHub - dglt1/optimus-switch-sddm: easy installer for optimus-switch for SDDM, sets up nvidia PRIME and also allows for easy switching between intel/nvidia (prime mode) and intel only mode where nvidia gpu is powered down and no longer visible. modes are switched with "sudo set-intel.sh" or "sudo set-nvidia.sh" .) and now I can see it but when I see it I can’t see my principal screen. Does someone have an idea of what’s going on?[
Hi and welcome to the forum ![]()
From the README.md on that repo:
Usage after running install script:
sudo set-intel.shwill set intel only mode, reboot and nvidia powered off and removed from view.sudo set-nvidia.shsets intel/nvidia (prime) mode.This should be pretty straight forward, if however, you cant figure it out, I am @dglt on the manjaro forum. I hope this is as useful for you as it is for me.
Added side-note, for persistent changes to configurations, modify the configurations used for switching located in
/etc/switch/nvidia/and/etc/switch/intel/.
Also this issue might be related, with a response from the maintainer:
