I do not know whether this is a way to do this,
but I noticed that I have, for some apps, two shortcuts defined for the same action.
For instance for exo-open --launch WebBrowser
I have two, one key is the “HomePage” key and the second set to use the “Internet” key.
… none of these keys exist on my keyboard - this is the default setting for my installation
I never use hotkeys anyway - I use the whisker menu - the windows key brings it up, and then I start typing, it usually only takes one keystroke.
A bit like rofi.
This is what my default looks like:
exo-open --launch WebBrowser --> Internet
exo-open --launch WebBrowser --> HomePage
Perhaps you can set one hotkey using the english layout and another for the kyrillic one?
There are members here that, like you, use two keyboard layouts - they might know.
I have long list of shortcuts for every application I use (browser, text editor, file manager, image viewer, IDE, terminal/console, task manager, telegram messenger, tor browser, mail client, system update, printscreen). And now I have to make this list twice long.
