Hello everyone, I am sorry to bother you, I’ve been using Manjaro for little over a month now and every problem I’ve had I’ve managed to resolve without much fuss, but I need some help now.
I’m currently using a Lenovo ThinkPad E14 Gen 5 with a Ryzen 7 7730U (integrated graphics) and a ThinkPad USB-C Docking Station, recently I also purchased an LG 27GR75Q-B and I have had issues with it.
First of all, I am aware this dock is not powerful enough to deliver 2K 165Hz image, hence why I’m currently using it at 2K 60Hz and plan on getting a different ThinkPad dock later on.
To start, the monitor won’t work if I log in with standard GNOME, it will only work if I use GNOME with Xorg, which for it to work properly I had to uninstall video-linux, video-modsetting and video-vesa, which in turn causes issues with screen tearing in other applications (such as Mupen64), second of all, the monitor will not work if I plug in the dock while my computer has already finished booting, I need to do a full reboot in order to get it to work, which obviously is very annoying, if I unplug it and want to use it later I must do a reboot while the dock is connected, no matter which of the two DP ports I use, strangely, this does not happen with USB, power delivery or Ethernet, which can be unplugged and plugged no issue. And finally this isn’t too much of a real issue but still bugs me, on the login screen after a reboot the monitor always displays a cropped up zoomed in top left corner of the image, while the ThinkPad’s display works as normal, I’ve got no clue what causes this.
Here’s what the Terminal displays after running inxi -Fza
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=f7c94276-524c-46cc-8f72-d6bc3154d42c rw quiet splash apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 21JSS0Y500 v: ThinkPad E14 Gen 5
Mobo: LENOVO model: 21JSS0Y500 v: ThinkPad serial: <superuser required>
part-nu: LENOVO_MT_21JS_BU_Think_FM_ThinkPad E14 Gen 5
uuid: <superuser required> UEFI: LENOVO v: R2CET29W (1.11 )
date: 07/25/2023
ID-1: BAT0 charge: 49.1 Wh (100.0%) condition: 49.1/47.0 Wh (104.6%)
volts: 13.1 min: 11.3 model: Sunwoda L22D3PG4 type: Li-poly serial: <filter>
status: full cycles: 11
Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1854 high: 3974 min/max: 400/4546 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3223 2: 400 3: 400
4: 400 5: 3013 6: 400 7: 3478 8: 3171 9: 400 10: 400 11: 3468 12: 400
13: 2924 14: 3223 15: 3974 16: 400 bogomips: 63904
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-4 off: eDP-1
empty: DP-1, DP-2, DP-3, DP-5, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 51.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:2469
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-4 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2023 res: 2560x1440 dpi: 108 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
Monitor-2: eDP-1 model: AU Optronics 0xfa9b built: 2021 res: 1920x1200
dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
renoir LLVM 16.0.6 DRM 3.57 6.7.7-1-MANJARO) device-ID: 1002:15e7
memory: 1000 MiB unified: no display-ID: :0.0
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Lenovo ThinkPad Dock Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.4.2.3:10 chip-ID: 17ef:3063 class-ID: 0300
serial: <filter>
Device-5: DCMT USB Condenser Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.4.3:7 chip-ID: 31b2:0011 class-ID: 0300
serial: <filter>
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: Lenovo RTL8111/8168/8411 driver: r8168 v: 8.052.01-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-3: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] driver: r8152
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:5
chip-ID: 17ef:3062 class-ID: 0000 serial: <filter>
IF: enp4s0f3u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Foxconn / Hon Hai Bluetooth Adapter driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 0489:e0d8
Local Storage: total: 1.82 TiB used: 136.87 GiB (7.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02106 temp: 46.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SDRW-11A0XS0 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 131.05 GiB (14.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 56.0 C mobo: 46.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): fan-1: 2300 fan-2: 2300
Memory: total: 16 GiB note: est. available: 14.46 GiB used: 2.99 GiB (20.6%)
Processes: 392 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
image: 5.77 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1604 pm: pacman pkgs: 1575 libs: 507 tools: gnome-software,pamac
pm: flatpak pkgs: 29 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.33
I would really appreciate any help I can get, thank you.
UPDATE: It works with regular GNOME now, wakes up from sleep with seemingly no problems, I was able to reinstall open-source drivers with no hiccups which is awesome, will keep testing and tweaking, in the meantime, anything that could help is much appreciated.
