I’ve installed Manjaro 20.2.1 Nibia on my old iMac12,1 (21.5" 2011) in EFI mode. Most works out of box, except the displayer backlight.
There is acpi_video0
under /sys/class/backlight
. I can move the brightness slider in KDE system tray. Though the value of /sys/class/backlight/acpi_video0/brightness
can be changed, the displayer stays unchanged.
The displayer will get stuck in discomfortable highest brightness after suspend. So I have to reboot to restore the original brightness.
I’ve googled this problem for days. All suggest the kernel command line parameter acpi_backlight
. I’ve tried all possible values video
, vendor
, native
, and none
, with kernel 5.4, 5.9, and 5.10.
acpi_backlight=video
changes nothing, just as absence of this parameter. Other values result in the empty /sys/class/backlight/
dir, then no slider in Battery and Brightness
widget at all.
Some people reported it worked on their imac12,2 (27" 2011). The baclight would be adjusted via the /sys/class/backlight/radeon_bl0
. It’s almost the same hardware except more powerful CPU/GPU and bigger displayer. But it didn’t on my smaller imac12,1.
Below is basic info:
System: Kernel: 5.10.18-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.21.1 Distro: Manjaro Linux
Machine: Type: Desktop System: Apple product: iMac12,1 v: 1.0 serial: <filter>
Mobo: Apple model: Mac-942B5BF58194151B serial: <filter> UEFI: Apple v: 87.0.0.0.0 date: 06/14/2019
CPU: Info: Quad Core model: Intel Core i5-2400S bits: 64 type: MCP L2 cache: 6 MiB
Speed: 2328 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 2328 2: 2255 3: 2794 4: 2254
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel
Device-2: Advanced Micro Devices [AMD/ATI] Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M] driver: radeon
v: kernel
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: loaded: ati,intel,radeon unloaded: modesetting resolution:
1: 1920x1080~60Hz 2: 1680x1050~60Hz
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.10.18-1-MANJARO LLVM 11.1.0) v: 3.3 Mesa 20.3.4
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series] driver: snd_hda_intel
Sound Server: ALSA v: k5.10.18-1-MANJARO
Network: Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: br-6c39ac847b4b state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Bluetooth: Device-1: Apple Built-in Bluetooth 2.0+EDR HCI type: USB driver: btusb
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 465.76 GiB used: 65.37 GiB (14.0%)
ID-1: /dev/sda vendor: Seagate model: ST3500418AS size: 465.76 GiB
Partition: ID-1: / size: 456.66 GiB used: 65.08 GiB (14.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 196.9 MiB used: 23.4 MiB (11.9%) fs: vfat dev: /dev/sda1
Swap: ID-1: swap-1 type: file size: 256 MiB used: 0 KiB (0.0%) file: /swapfile
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1197
Info: Processes: 262 Uptime: 6h 15m Memory: 23.47 GiB used: 5.37 GiB (22.9%) Shell: Zsh inxi: 3.3.01
