Hi there .. So i wanted to publish an application using snapcraft and noticed that i required lxd to work properly .. but how many times i tried there are bunch of errors ..how to bypass it or is there other way around ?
The first thing to do will be to change branch and thus get a newer version. Other than this, you’ll at least need to post your inxi and logs.
Without the exact command you are running and the exact error messages you see we’ll just be guessing.
Please copy and paste the exact message, and format it properly: [HowTo] Post command output and file content as preformatted text
For instance, highlight the output in the reply and use the </> button.
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
