So I have been unable to get hardware acceleration on my iGPU correctly, I have a dedicated Nvidia card which I can confirm works, but when I try to run video on my iGPU, it can’t display framerates above 30 without extreme stutter. I tried manually setting up my xorg.conf file without any luck, after doing so, I either get xorg crashes or boot into my Nvidia card. I also tried declaring which drivers to use as environment variables, specifically following what is said on Hardware video acceleration - ArchWiki and configuring driver names. I have all relevant drivers installed and have tried both declaring and removing VDPAU_DRIVER
variables. VAAPI is listed as working but web browsers seem to default to VDPAU.
inxi -G output with GPU active
Graphics: Device-1: Intel UHD Graphics driver: i915 v: kernel
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] driver: nvidia v: 455.38
Device-3: Quanta HP True Vision HD Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.9 driver: intel,nvidia resolution: 3840x2160~60Hz
OpenGL: renderer: GeForce GTX 1650 Ti with Max-Q Design/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
and if I have the iGPU running, xrandr --listproviders gives
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 5 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x1e9 cap: 0xb, Source Output, Sink Output, Sink Offload crtcs: 4 outputs: 4 associated providers: 1 name:Intel
and if on iGPU
When I try to use xrandr --setprovideroffloadsink 1 0
I get
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 34 (RRSetProviderOffloadSink)
Value in failed request: 0x1e9
Serial number of failed request: 16
Current serial number in output stream: 17
Regardless if I’m on my Nvidia or Intel already.
Using this command doesn’t seem to change anything
xrandr --setprovideroutputsource Intel NVIDIA-0
And if I run it on the iGPU and swap the outputsources I get
Minor opcode of failed request: 35 (RRSetProviderOutputSource)
Value in failed request: 0x257
If I’m booted into the Nvidia card, vdpau info gives
display: :0 screen: 0
API version: 1
Information string: NVIDIA VDPAU Driver Shared Library 455.38 Thu Oct 22 05:57:08 UTC 2020
Video surface:
name width height types
420 8192 8192 NV12 YV12
422 8192 8192 UYVY YUYV
444 8192 8192 NV24 YV24
420_16 8192 8192 P010 P016
422_16 8192 8192 UYVY YUYV
444_16 8192 8192 Y_U_V_444_16
Decoder capabilities:
name level macbs width height
MPEG1 0 65536 4096 4096
MPEG2_SIMPLE 3 65536 4096 4096
MPEG2_MAIN 3 65536 4096 4096
H264_BASELINE 51 65536 4096 4096
H264_MAIN 51 65536 4096 4096
H264_HIGH 51 65536 4096 4096
VC1_SIMPLE 1 8190 2048 2048
VC1_MAIN 2 8190 2048 2048
VC1_ADVANCED 4 8190 2048 2048
MPEG4_PART2_SP 3 8192 2048 2048
MPEG4_PART2_ASP 5 8192 2048 2048
DIVX4_QMOBILE 0 8192 2048 2048
DIVX4_MOBILE 0 8192 2048 2048
DIVX4_HOME_THEATER 0 8192 2048 2048
DIVX4_HD_1080P 0 8192 2048 2048
DIVX5_QMOBILE 0 8192 2048 2048
DIVX5_MOBILE 0 8192 2048 2048
DIVX5_HOME_THEATER 0 8192 2048 2048
DIVX5_HD_1080P 0 8192 2048 2048
H264_CONSTRAINED_BASELINE 51 65536 4096 4096
H264_EXTENDED 51 65536 4096 4096
H264_PROGRESSIVE_HIGH 51 65536 4096 4096
H264_CONSTRAINED_HIGH 51 65536 4096 4096
H264_HIGH_444_PREDICTIVE 51 65536 4096 4096
VP9_PROFILE_0 1 262144 8192 8192
VP9_PROFILE_1 --- not supported ---
VP9_PROFILE_2 1 262144 8192 8192
VP9_PROFILE_3 --- not supported ---
HEVC_MAIN 153 262144 8192 8192
HEVC_MAIN_10 153 262144 8192 8192
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 153 262144 8192 8192
HEVC_MAIN_444 153 262144 8192 8192
HEVC_MAIN_444_10 153 262144 8192 8192
HEVC_MAIN_444_12 153 262144 8192 8192
and if I am on GPU and run it through prime, I get the same output. If I switch GPU to Intel and run it, I get
API version: 1
Information string: OpenGL/VAAPI backend for VDPAU
Video surface:
420 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
422 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
444 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
420_16 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
422_16 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
444_16 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
MPEG1 --- not supported ---
MPEG2_SIMPLE --- not supported ---
MPEG2_MAIN --- not supported ---
H264_BASELINE 51 16384 2048 2048
H264_MAIN 51 16384 2048 2048
H264_HIGH 51 16384 2048 2048
VC1_SIMPLE --- not supported ---
VC1_MAIN --- not supported ---
VC1_ADVANCED --- not supported ---
MPEG4_PART2_SP --- not supported ---
MPEG4_PART2_ASP --- not supported ---
DIVX4_QMOBILE --- not supported ---
DIVX4_MOBILE --- not supported ---
DIVX4_HOME_THEATER --- not supported ---
DIVX4_HD_1080P --- not supported ---
DIVX5_QMOBILE --- not supported ---
DIVX5_MOBILE --- not supported ---
DIVX5_HOME_THEATER --- not supported ---
DIVX5_HD_1080P --- not supported ---
H264_CONSTRAINED_BASELINE 51 16384 2048 2048
H264_EXTENDED --- not supported ---
H264_PROGRESSIVE_HIGH --- not supported ---
H264_CONSTRAINED_HIGH --- not supported ---
H264_HIGH_444_PREDICTIVE --- not supported ---
VP9_PROFILE_0 --- not supported ---
VP9_PROFILE_2 --- not supported ---
HEVC_MAIN --- not supported ---
HEVC_MAIN_10 --- not supported ---
HEVC_MAIN_12 --- not supported ---
HEVC_MAIN_444 --- not supported ---
HEVC_MAIN_444_10 --- not supported ---
HEVC_MAIN_444_12 --- not supported ---
Segmentation fault (core dumped)
My xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "iGPU"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "AllowEmptyInitialConfiguration"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
Section "Device"
Identifier "iGPU"
Driver "intel"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "iGPU"
Device "iGPU"
Option "DRI" "3"
EndSection
I’m skipping some of the output since you can see the main thing there, but whatever I do, I can’t get Youtube or other streaming services to play smoothly unless I’m using my dedicated GPU but I don’t want it running constantly and killing battery. Any idea what I’m doing wrong here?
Edit: Found that after running xrandr --setprovideroutputsource 1 0
while on iGPU will cause it to render with the Nvidia card for some applications (like glmark2), but it won’t decode video or render my web browser. glmark2 lists the wrong card running too but only when booted with iGPU (ie intel says it’s nvidia, nvidia says its intel). If I run xrandr --setprovideroutputsource 0 1
I get a similar error to running --setprovideroffloadsink
