ifconfig doesn’t work. I need it to find the ip address my computer is using.
Use ip instead.
ifconfig is depricated.
To get your interface details just run ip addr.
If you must have it:
it is in core/net-tools
So just install net-tools and you have it.
I had net-tools on one computer and not the other. That’s why I was confused.
What was the ultimate goal?
Having ifconfig
or
finding out the ip address your computer is using?
You got responses to both objectives.
It can be done without ifconfig - and even better, more elegantly (in my opinion)
as described in the tutorial @freggel.doe linked you to
ip -br a
lo UNKNOWN 127.0.0.1/8 ::1/128
enp4s0 DOWN
wlan0 UP 192.168.20.140/24
virbr0 DOWN 192.168.122.1/24
Thanks @freggel.doe - I didn’t know this and learned something!
