Hi all,
Okay, I’m worried. Why does my PC do that?
Thanks
Melissa
Maybe it’s your subnets gateway?
10.1.1.1 does not seem to be “pingable” from the internet.
can you post output of “ip route”?
well, my network is not in that range…it’s 192.168.x.x…that is weird…
hang on…
It’s this:
default via 192.168.1.1 dev enp1s0 proto dhcp metric 100
192.168.1.0/24 dev enp1s0 proto kernel scope link src 192.168.1.12 metric 100
10.x.x.x is a private address range - it is often used by ISP - especially on celluar connections.
It may also be used when your connection is part of a larger private network - ISP network.
The ip may also be used by VirtualBox or VMware when creating the network interfaces for the guest and a guest system will operate on 10.x.x.x but the host will also see the 10. address
okay, I’ll check with my ISP. Could be just that. Since I dont even “live” in that range, this struck me as strange…
Are you using docker?
we could check “ip addr show”, there it should show all interfaces from docker or virtualbox
no, not using docker. I noticed that the triad was 192.168.1.44, 224.0.0.251 and 10.1.1.1.
Now, as I called the ISP, they explained that the moden responds to either 10.1.1.1 or 192.168.1.1, and 224.0.0.251 is connected to itunes. Which…is weird, but possible…
and…I learned something again ![]()
ip addr show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether dd:dd:dd:dd:dd:dd brd ff:ff:ff:ff:ff:ff
inet 192.168.1.12/24 brd 192.168.1.255 scope global dynamic noprefixroute enp1s0
valid_lft 2879sec preferred_lft 2879sec
inet6 2a02:a03f:877e:9a00:b8bc:56ee:ca56:e0a8/64 scope global dynamic noprefixroute
valid_lft 86393sec preferred_lft 71993sec
inet6 fe80::e8a1:cf5:10a4:75fb/64 scope link noprefixroute
(MAC is smudged…)
Nothing weird. There can be multiple IPs on a single interface. And routers can also have multiple loopback addresses configured. If you access router via web, you can probably reach it via both IPs.
224.0.0.0/4 are multicast addresses. .251 = mDNS.
Also to comment on “well, my network is not in that range…it’s 192.168.x.x…that is weird…”:
You constantly connect to other networks while you are on the internet for example. That’s the whole point of a router - it routes packets to other networks. =)
