I’m new to Manjaro and just learned of pamac. The first time I used it went well, but now I tried it with vscodium and it failed. I did not think ahead and now realize I don’t know what most of this text in my terminal means and am not sure if action is required on my part to remedy this, or what to do next?
[man@BRUTUS ~]$ pamac build vscodium
Preparing...
Checking vscodium dependencies...
Resolving dependencies...
Checking inter-conflicts...
To install (12):
oniguruma 6.9.9-1 (Required By: vscodium) extra 225.4 kB
jq 1.7.1-1 (Required By: vscodium) extra 292.8 kB
pkgconf 2.1.0-2 (Required By: vscodium) core 62.9 kB
libuv 1.47.0-1 (Required By: vscodium) extra 246.3 kB
c-ares 1.25.0-1 (Required By: vscodium) extra 263.5 kB
nodejs 21.5.0-1 (Required By: vscodium) extra 16.0 MB
yarn 1.22.21-1 (Required By: vscodium) extra 3.6 MB
semver 7.5.4-1 (Required By: vscodium) extra 38.3 kB
gulp 4.0.2-3 (Required By: vscodium) extra 1.1 MB
nvm 0.39.7-1 (Required By: vscodium) extra 39.3 kB
patch 2.7.6-10 (Required By: vscodium) core 95.2 kB
git-lfs 3.4.1-1 (Required By: vscodium) extra 4.1 MB
To build (1):
vscodium 1.85.2.24019-2 AUR
Total download size: 26.1 MB
Total installed size: 110.7 MB
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning vscodium build files...
Generating vscodium information...
Authenticating as: Manjaro (man)
Password:
Download of oniguruma (6.9.9-1) started
Download of oniguruma (6.9.9-1) finished
Download of libuv (1.47.0-1) started
Download of libuv (1.47.0-1) finished
Download of jq (1.7.1-1) started
Download of pkgconf (2.1.0-2) started
Download of pkgconf (2.1.0-2) finished
Download of c-ares (1.25.0-1) started
Download of c-ares (1.25.0-1) finished
Download of nodejs (21.5.0-1) started
Download of jq (1.7.1-1) finished
Download of semver (7.5.4-1) started
Download of semver (7.5.4-1) finished
Download of yarn (1.22.21-1) started
Download of nodejs (21.5.0-1) finished
Download of gulp (4.0.2-3) started
Download of gulp (4.0.2-3) finished
Download of git-lfs (3.4.1-1) started
Download of git-lfs (3.4.1-1) finished
Download of patch (2.7.6-10) started
Download of patch (2.7.6-10) finished
Download of nvm (0.39.7-1) started
Download of nvm (0.39.7-1) finished
Download of yarn (1.22.21-1) finished
Checking keyring... [12/12]
Checking integrity... [12/12]
Loading packages files... [12/12]
Checking file conflicts... [12/12]
Checking available disk space... [12/12]
Installing oniguruma (6.9.9-1)... [1/12]
Installing jq (1.7.1-1)... [2/12]
Installing pkgconf (2.1.0-2)... [3/12]
Installing libuv (1.47.0-1)... [4/12]
Installing c-ares (1.25.0-1)... [5/12]
Installing nodejs (21.5.0-1)... [6/12]
Installing yarn (1.22.21-1)... [7/12]
Installing semver (7.5.4-1)... [8/12]
Installing gulp (4.0.2-3)... [9/12]
Installing git-lfs (3.4.1-1)... [10/12]
Installing patch (2.7.6-10)... [11/12]
Installing nvm (0.39.7-1)... [12/12]
You need to source nvm before you can use it. Do one of the following
or similar depending on your shell (and then restart your shell):
echo 'source /usr/share/nvm/init-nvm.sh' >> ~/.bashrc
echo 'source /usr/share/nvm/init-nvm.sh' >> ~/.zshrc
You can now install node.js versions (e.g. nvm install 10) and
activate them (e.g. nvm use 10).
init-nvm.sh is a convenience script which does the following:
[ -z "$NVM_DIR" ] && export NVM_DIR="$HOME/.nvm"
source /usr/share/nvm/nvm.sh
source /usr/share/nvm/bash_completion
source /usr/share/nvm/install-nvm-exec
You may wish to customize and put these lines directly in your
.bashrc (or similar) if, for example, you would like an NVM_DIR
other than ~/.nvm or you don't want bash completion.
See the nvm readme for more information: https://github.com/creationix/nvm
Arming ConditionNeedsUpdate... [1/1]
Building vscodium...
==> Making package: vscodium 1.85.2.24019-2 (Sat 10 Feb 2024 08:40:02 PM CST)
==> Retrieving sources...
-> Found vscodium.desktop
-> Found vscodium-wayland.desktop
-> Found vscodium-uri-handler.desktop
-> Downloading VSCodium-1.85.2.24019-src.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 8849k 100 8849k 0 0 2388k 0 0:00:03 0:00:03 --:--:-- 2702k
vscodium.desktop ... Passed
vscodium-wayland.desktop ... Passed
vscodium-uri-handler.desktop ... Passed
VSCodium-1.85.2.24019-src.tar.gz ... Passed
==> Extracting sources...
-> Extracting VSCodium-1.85.2.24019-src.tar.gz with bsdtar
==> Starting build()...
Downloading and installing node v18.15.0...
Downloading https://nodejs.org/dist/v18.15.0/node-v18.15.0-linux-x64.tar.xz...
######################################################################### 100.0%
Computing checksum with sha256sum
Checksums matched!
Now using node v18.15.0 (npm v9.5.0)
Creating default alias: default -> 18.15 (-> v18.15.0)
Found '/var/tmp/pamac-build-man/vscodium/src/.nvmrc' with version <18.15>
Configured .nvmrc version is [18.15], adding the v prefix before checking if it matches with the node command.
Installed version of node [v18.15.0] matches required version [v18.15], continuing.
RELEASE_VERSION="1.85.2.24019"
MS_TAG="1.85.2"
MS_COMMIT="8b3775030ed1a69b13e4f4c628c612102e30a681"
remote: Enumerating objects: 8845, done.
remote: Counting objects: 100% (8845/8845), done.
remote: Compressing objects: 100% (7474/7474), done.
remote: Total 8845 (delta 1194), reused 4385 (delta 670), pack-reused 0
Receiving objects: 100% (8845/8845), 17.61 MiB | 2.04 MiB/s, done.
Resolving deltas: 100% (1194/1194), done.
From https://github.com/Microsoft/vscode
* branch 8b3775030ed1a69b13e4f4c628c612102e30a681 -> FETCH_HEAD
Note: switching to 'FETCH_HEAD'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD is now at 8b37750 chore: update electron v25.9.7 (#202679)
++ [[ -f ./remote-dependencies.tar ]]
++ . version.sh
+++ [[ -z '' ]]
+++ type -t sha1sum
++++ echo 1.85.2.24019
++++ sha1sum
++++ cut '-d ' -f1
+++ BUILD_SOURCEVERSION=c8a36a69377856369f139f39ee56dd3838130fbf
+++ echo 'BUILD_SOURCEVERSION="c8a36a69377856369f139f39ee56dd3838130fbf"'
+++ [[ -n '' ]]
+++ export BUILD_SOURCEVERSION
++ [[ yes == \y\e\s ]]
++ echo 'MS_COMMIT="8b3775030ed1a69b13e4f4c628c612102e30a681"'
++ . prepare_vscode.sh
+++ set -e
+++ . ./utils.sh
++++ exists gsed
++++ type -t gsed
++++ is_gnu_sed
++++ sed --version
+++ [[ stable == \i\n\s\i\d\e\r ]]
+++ cp -rp src/stable/resources src/stable/src vscode/
+++ cp -f LICENSE vscode/LICENSE.txt
+++ cd vscode
+++ ../update_settings.sh
266s/'default': true/'default': false/
217s/'default': TelemetryConfiguration.ON/'default': TelemetryConfiguration.OFF/
147s/'default': true/'default': false/
applying patch: ../patches/binary-name.patch
applying patch: ../patches/brand.patch
applying patch: ../patches/build-version.patch
applying patch: ../patches/crash-reporter.patch
applying patch: ../patches/disable-cloud.patch
applying patch: ../patches/ext-from-gh.patch
applying patch: ../patches/feat-announcements.patch
applying patch: ../patches/fix-build-linux.patch
applying patch: ../patches/fix-eol-banner.patch
applying patch: ../patches/merge-user-product.patch
applying patch: ../patches/ppc64le-support.patch
applying patch: ../patches/remove-mangle.patch
applying patch: ../patches/report-issue.patch
applying patch: ../patches/update-cache-path.patch
applying patch: ../patches/update-msi.patch
applying patch: ../patches/update-windows.patch
applying patch: ../patches/use-github-pat.patch
applying patch: ../patches/win7.patch
+++ export ELECTRON_SKIP_BINARY_DOWNLOAD=1
+++ ELECTRON_SKIP_BINARY_DOWNLOAD=1
+++ export PLAYWRIGHT_SKIP_BROWSER_DOWNLOAD=1
+++ PLAYWRIGHT_SKIP_BROWSER_DOWNLOAD=1
+++ [[ linux == \l\i\n\u\x ]]
+++ export VSCODE_SKIP_NODE_VERSION_CHECK=1
+++ VSCODE_SKIP_NODE_VERSION_CHECK=1
+++ [[ linux == \o\s\x ]]
+++ [[ linux == \w\i\n\d\o\w\s ]]
+++ [[ '' == \a\r\m ]]
+++ CHILD_CONCURRENCY=1
+++ yarn --frozen-lockfile --check-files --network-timeout 180000
yarn install v1.22.21
$ node build/npm/preinstall.js
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
warning "@microsoft/1ds-core-js > @microsoft/applicationinsights-core-js@2.8.15" has unmet peer dependency "tslib@*".
warning " > gulp-postcss@9.0.0" has unmet peer dependency "postcss@^8.0.0".
warning " > tsec@0.2.7" has unmet peer dependency "@bazel/bazelisk@>=1.7.5".
warning " > tsec@0.2.7" has unmet peer dependency "@bazel/concatjs@>=5.3.0".
[4/4] Building fresh packages...
error /var/tmp/pamac-build-man/vscodium/src/vscode/node_modules/@parcel/watcher: Command failed.
Exit code: 1
Command: node-gyp-build
Arguments:
Directory: /var/tmp/pamac-build-man/vscodium/src/vscode/node_modules/@parcel/watcher
Output:
gyp info it worked if it ends with ok
gyp info using node-gyp@9.3.1
gyp info using node@18.15.0 | linux | x64
gyp info find Python using Python version 3.11.6 found at "/usr/bin/python3"
gyp http GET https://electronjs.org/headers/v25.9.7/node-v25.9.7-headers.tar.gz
gyp http 200 https://artifacts.electronjs.org/headers/v25.9.7/node-v25.9.7-headers.tar.gz?force_headers_dist=1
gyp http GET https://electronjs.org/headers/v25.9.7/SHASUMS256.txt
gyp http 200 https://artifacts.electronjs.org/headers/v25.9.7/SHASUMS256.txt?force_headers_dist=1
gyp info spawn /usr/bin/python3
gyp info spawn args [
gyp info spawn args '/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
gyp info spawn args 'binding.gyp',
gyp info spawn args '-f',
gyp info spawn args 'make',
gyp info spawn args '-I',
gyp info spawn args '/var/tmp/pamac-build-man/vscodium/src/vscode/node_modules/@parcel/watcher/build/config.gypi',
gyp info spawn args '/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
gyp info spawn args '/home/man/.cache/node-gyp/25.9.7/include/node/common.gypi',
gyp info spawn args '-Dlibrary=shared_library',
gyp info spawn args '-Dvisibility=default',
gyp info spawn args '-Dnode_root_dir=/home/man/.cache/node-gyp/25.9.7',
gyp info spawn args '-Dnode_gyp_dir=/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp',
gyp info spawn args '-Dnode_lib_file=/home/man/.cache/node-gyp/25.9.7/<(target_arch)/node.lib',
gyp info spawn args '-Dmodule_root_dir=/var/tmp/pamac-build-man/vscodium/src/vscode/node_modules/@parcel/watcher',
gyp info spawn args '-Dnode_engine=v8',
gyp info spawn args '--depth=.',
gyp info spawn args '--no-parallel',
gyp info spawn args '--generator-output',
gyp info spawn args 'build',
gyp info spawn args '-Goutput_dir=.'
gyp info spawn args ]
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:10:17)
gyp ERR! stack at /var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:57:18
gyp ERR! stack at new Promise (<anonymous>)
gyp ERR! stack at step (/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:54:21)
gyp ERR! stack at /var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:71:22
gyp ERR! stack at subStep (/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:69:33)
gyp ERR! stack at /var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:80:22
gyp ERR! stack at /var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! System Linux 6.6.10-1-MANJARO
gyp ERR! command "/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/bin/node" "/var/tmp/pamac-build-man/vscodium/src/.nvm/versions/node/v18.15.0/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /var/tmp/pamac-build-man/vscodium/src/vscode/node_modules/@parcel/watcher
gyp ERR! node -v v18.15.0
gyp ERR! node-gyp -v v9.3.1
gyp ERR! not ok
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
++++ error_function build
++++ (( ! BASH_SUBSHELL ))
+++++ gettext 'A failure occurred in %s().'
++++ error 'A failure occurred in %s().' build
++++ local 'mesg=A failure occurred in %s().'
++++ shift
+++++ gettext ERROR:
++++ printf '==> ERROR: A failure occurred in %s().\n' build
==> ERROR: A failure occurred in build().
+++++ gettext Aborting...
++++ plainerr Aborting...
++++ plain Aborting...
++++ (( QUIET ))
++++ local mesg=Aborting...
++++ shift
++++ printf ' Aborting...\n'
Aborting...
++++ exit 4
+ clean_up
+ local EXIT_CODE=4
+ (( INFAKEROOT ))
+ [[ -p '' ]]
+ (( (EXIT_CODE == E_OK || EXIT_CODE == E_INSTALL_FAILED) && BUILDPKG && CLEANUP ))
+ remove_deps
+ (( ! RMDEPS ))
+ return 0
+ exit 4
[man@BRUTUS ~]$
