iDRAC Remote Console access or otherwise opening a .jnlp in a browser
For some necessary detail but maybe usable detail:
I have a home lab consisting of a Dell r720 server
The Dell r720 has a thing called iDRAC which allows you to administer the server remotely (via web browser) and the server has a interface that you need to stand in front of the server to access unless you use iDRAC’s Virtual Console. Which I am trying to use and the reason for this post.
Now for the question at hand:
When I click launch remote console from iDRAC, it downloads a .jnlp file. A quick Google search indicates that I need to install Java to launch this remote console (or otherwise somehow get Java in a browser). Problem is I dunno how to do this in Manjaro/Arch becuase there are so many “Java” things I dunno which one to install.
Anyone have any advice?
Thanks! Oh. Entirely off topic - Please Keep Compiz Alive!! If you try it, you will love it. Trust me. To everyone that hasen’t yet used Compiz. Do so and you will see just how awesome it is!
iDRAC 7 or newer has also HTML5 Virtual Console so if you choose this option you don’t need Java.
If you want open .jnlp file you need icedtea-web. Java version no matter unless you use iDRAC 6 – in this case see Java IDRAC 6 Ubuntu 18.04 setup - Technicus
Yes indeed sir. Changing to HTML5 in the plugin type within the settings of virtual console fixed the issue and opened it right up!
Thank you so much!
