Hi,
I have an ideapad 5 pro with the ryzen 5800h and GTX1650.
It mostly works great with the latest linux, however I have found two issues related to the battery:
- The charger state is not recognized correctly. The icon shows the charger is connected even though it is not. First this only happend sometimes and could be seen as “delayed reaction” with some good will, right now it is permanently showing that it’s charging. However the charge percentage is shown correctly. Also in the system monitor, the chargin rate always shows a negative value no matter if the laptop is charging or not. However the absolute value seems plausible.
- TLP behaves strangely. I tried setting a maximum scaling frequency on battery of 2GHZ, however this resulted in the CPU frequency being capped at 1.2GHZ (I suppose the lowest possible value). This limit kept active when I plugged in the charger or even removed the config and ran
tlp start. Only a reboot with this limit removed restored the old config. However it was not necessary to reboot the laptop for the limit to get activated. Interestingly, thetlp startcommand returns the correct charger connection status even when the icon does not.
Here is my system info:
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=5379a4c7-4ca0-4f6d-8da9-827dbeb59dd8 rw quiet apparmor=1
security=apparmor resume=UUID=12da933e-5b2c-4926-adee-5c1904aa8f1f
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
Mobo: LENOVO model: LNVNB161216 v: WIN serial: <superuser required>
UEFI: LENOVO v: GSCN29WW date: 10/08/2021
ID-1: BAT0 charge: 67.2 Wh (87.8%) condition: 76.5/75.0 Wh (102.0%)
volts: 16.8 min: 15.4 model: LGC L20L4PE1 type: Li-ion serial: <filter>
status: Discharging
RAM: total: 14.56 GiB used: 3.39 GiB (23.3%)
RAM Report:
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1350 high: 1667 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1312 2: 1667
3: 1225 4: 1641 5: 1211 6: 1321 7: 1353 8: 1341 9: 1358 10: 1501 11: 1400
12: 1198 13: 1224 14: 1241 15: 1382 16: 1227 bogomips: 102241
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 13d3:56fb class-ID: fe01 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 05:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: MEDIATEK vendor: Lenovo driver: mt7921e v: kernel port: N/A
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 99.83 GiB (20.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
lanes: 4 type: SSD serial: <filter> rev: 41010C22 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 461.71 GiB size: 453.39 GiB (98.20%)
used: 99.83 GiB (22.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5379a4c7-4ca0-4f6d-8da9-827dbeb59dd8
label: NO_LABEL uuid: 7A47-3FAB
ID-1: swap-1 type: partition size: 14.93 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 12da933e-5b2c-4926-adee-5c1904aa8f1f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Foxconn / Hon Hai Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Device-2: 3-4:3 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 401 Uptime: 19m wakeups: 1664 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1463
pacman: 1447 lib: 414 flatpak: 12 snap: 4 Shell: Zsh v: 5.8 default: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.12
Using the 5.15 kernel does not help.
Any ideas how to fix this?
