I am running gnome 40 with testing and its super smooth and nice! Only issue is that since install, the icon is missing for window close in overview regardless of theme! No rush for a fix, I thought I’d just post so folks know! See attached screenshot!
That’s not stock, that’s Dash to Dock. FYI, the testing branch does not have all the GNOME 40 packages yet. Unstable does with WIP versions of Dash to Dock and Dash to Panel.
Ah got it! I switched to unstable and enabled Dash to Dock and Dash to Panel, but still no luck! Are you saying its caused by a lack of support from those extensions?
Thanks for the suggestion! I’ve tried all the themes including adwaita and matcha (just tried them again to double check) and no luck! Also rebooted in-between theme applications a couple times and no luck on that front either!
Yeah, it’s odd! I might just try a reinstall this weekend or something and see if that fixes it? Not sure what else could be going on? I’ve poked around dconf editor, but can’t even find a section for that part of the UI, so don’t really know where to start! Maybe just something wonkey I did around time of install? I’ll let you know what it’s like after reinstalling!
Has this been fixed? I’m still having the issue but I can’t find any update on this
EDIT: I found out it was an issue with Loginized. I was using it to change GDM background and for some reason it was messing up gnome-shell’s theme. Switched to GitHub - realmazharhussain/gdm-tools: tools for Gnome's login manager to change background and everything went fine!
