This is a fresh vanilla install of the latest Plasma image. At the moment, I’ve reinstalled Manjaro to fix the issue, but I would like to use the nVidia drivers because I want to do games on Steam/Proton.
I have an MSI GeForce RTX 3060. I’m wondering what I need to do to get the nVidia driver working, if anything can be done at all.
I’m not sure if this will be relevant, but I also plan on building a customized low latency kernel for gaming, via this Xanmod kernel guide: (redacted since I can’t post links)
But at the moment, I haven’t gotten that far.
Any help or relevant links is appreciated. Thanks.
My apologies, you were right, it was live usb. I’ve rebooted into the actual install now, and edited my previous post with the real information.
head /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
so try adding the ibt parameter:
open this file: kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter: ibt=off
dont remove anything from there!, just add it to existing parameters, save the file, update grub: sudo update-grub
install nvidia: sudo mhwd -a pci nonfree 0300
reboot and verify with: inxi -G
that nvidia is there instead of nouveau
