Hi everyone! I’m with an issue with i3blocks. My icons (discord / telegram) are transparent on the bar.
I’m using compton/picom and here is my picom.conf:
# Backend
# Backend to use: "xrender" or "glx".
# GLX backend is typically much faster but depends on a sane driver.
backend = "glx";
# GLX backend
glx-no-stencil = true;
# GLX backend: Copy unmodified regions from front buffer instead of redrawing them all.
# My tests with nvidia-drivers show a 10% decrease in performance when the whole screen is modified,
# but a 20% increase when only 1/4 is.
# My tests on nouveau show terrible slowdown.
glx-copy-from-front = false;
# GLX backend: Use MESA_copy_sub_buffer to do partial screen update.
# My tests on nouveau shows a 200% performance boost when only 1/4 of the screen is updated.
# May break VSync and is not available on some drivers.
# Overrides --glx-copy-from-front.
# glx-use-copysubbuffermesa = true;
# GLX backend: Avoid rebinding pixmap on window damage.
# Probably could improve performance on rapid window content changes, but is known to break things on some drivers (LLVMpipe).
# Recommended if it works.
# glx-no-rebind-pixmap = true;
# GLX backend: GLX buffer swap method we assume.
# Could be undefined (0), copy (1), exchange (2), 3-6, or buffer-age (-1).
# undefined is the slowest and the safest, and the default value.
# copy is fastest, but may fail on some drivers,
# 2-6 are gradually slower but safer (6 is still faster than 0).
# Usually, double buffer means 2, triple buffer means 3.
# buffer-age means auto-detect using GLX_EXT_buffer_age, supported by some drivers.
# Useless with --glx-use-copysubbuffermesa.
# Partially breaks --resize-damage.
# Defaults to undefined.
#glx-swap-method = "undefined"; #deprecated !
#use-damage = true
# Shadows
# Enabled client-side shadows on windows.
shadow = true;
# The blur radius for shadows. (default 12)
shadow-radius = 5;
# The left offset for shadows. (default -15)
shadow-offset-x = 1;
# The top offset for shadows. (default -15)
shadow-offset-y = 1;
# The translucency for shadows. (default .75)
shadow-opacity = 0.3;
# Set if you want different colour shadows
# shadow-red = 0.0;
# shadow-green = 0.0;
# shadow-blue = 0.0;
# The shadow exclude options are helpful if you have shadows enabled. Due to the way picom draws its shadows, certain applications will have visual glitches
# (most applications are fine, only apps that do weird things with xshapes or argb are affected).
# This list includes all the affected apps I found in my testing. The "! name~=''" part excludes shadows on any "Unknown" windows, this prevents a visual glitch with the XFWM alt tab switcher.
shadow-exclude = [
"! name~=''",
"name = 'Notification'",
"name = 'Plank'",
"name = 'Docky'",
"name = 'Kupfer'",
"name = 'xfce4-notifyd'",
"name *= 'VLC'",
"name *= 'compton'",
"name *= 'picom'",
"name *= 'Chromium'",
"name *= 'Chrome'",
"class_g = 'Firefox' && argb",
"class_g = 'Conky'",
"class_g = 'Kupfer'",
"class_g = 'Synapse'",
"class_g ?= 'Notify-osd'",
"class_g ?= 'Cairo-dock'",
"class_g ?= 'Xfce4-notifyd'",
"class_g ?= 'Xfce4-power-manager'",
"class_g ?= 'Dmenu'",
# "class_g ?= 'Dunst'",
# disables shadows on i3 frames
"class_g ?= 'i3-frame'",
"_GTK_FRAME_EXTENTS@:c",
"_NET_WM_STATE@:32a *= '_NET_WM_STATE_HIDDEN'"
# Avoid drawing shadow on all shaped windows (see also: --detect-rounded-corners)
shadow-ignore-shaped = false;
# Opacity
inactive-opacity = 1;
active-opacity = 1;
frame-opacity = 1;
inactive-opacity-override = false;
# Dim inactive windows. (0.0 - 1.0)
# inactive-dim = 0.2;
# Do not let dimness adjust based on window opacity.
# inactive-dim-fixed = true;
# Blur background of transparent windows. Bad performance with X Render backend. GLX backend is preferred.
# blur-background = true;
# Blur background of opaque windows with transparent frames as well.
# blur-background-frame = true;
# Do not let blur radius adjust based on window opacity.
blur-background-fixed = false;
blur-background-exclude = [
"window_type = 'dock'",
"window_type = 'desktop'"
# Fading
# Fade windows during opacity changes.
fading = true;
# The time between steps in a fade in milliseconds. (default 10).
fade-delta = 1;
# Opacity change between steps while fading in. (default 0.028).
fade-in-step = 0.03;
# Opacity change between steps while fading out. (default 0.03).
fade-out-step = 0.03;
# Fade windows in/out when opening/closing
# no-fading-openclose = true;
# Specify a list of conditions of windows that should not be faded.
fade-exclude = [ ];
# Other
# Try to detect WM windows and mark them as active.
mark-wmwin-focused = true;
# Mark all non-WM but override-redirect windows active (e.g. menus).
mark-ovredir-focused = true;
# Use EWMH _NET_WM_ACTIVE_WINDOW to determine which window is focused instead of using FocusIn/Out events.
# Usually more reliable but depends on a EWMH-compliant WM.
use-ewmh-active-win = true;
# Detect rounded corners and treat them as rectangular when --shadow-ignore-shaped is on.
detect-rounded-corners = true;
# Detect _NET_WM_OPACITY on client windows, useful for window managers not passing _NET_WM_OPACITY of client windows to frame windows.
# This prevents opacity being ignored for some apps.
# For example without this enabled my xfce4-notifyd is 100% opacity no matter what.
detect-client-opacity = true;
# Specify refresh rate of the screen.
# If not specified or 0, picom will try detecting this with X RandR extension.
refresh-rate = 0;
# Vertical synchronization: match the refresh rate of the monitor
vsync = false;
# Enable DBE painting mode, intended to use with VSync to (hopefully) eliminate tearing.
# Reported to have no effect, though.
dbe = false;
# Limit picom to repaint at most once every 1 / refresh_rate second to boost performance.
# This should not be used with --vsync drm/opengl/opengl-oml as they essentially does --sw-opti's job already,
# unless you wish to specify a lower refresh rate than the actual value.
#sw-opti = true;
# Unredirect all windows if a full-screen opaque window is detected, to maximize performance for full-screen windows, like games.
# Known to cause flickering when redirecting/unredirecting windows.
unredir-if-possible = true;
# Specify a list of conditions of windows that should always be considered focused.
focus-exclude = [ "class_g = 'Cairo-clock'" ];
# Use WM_TRANSIENT_FOR to group windows, and consider windows in the same group focused at the same time.
detect-transient = true;
# Use WM_CLIENT_LEADER to group windows, and consider windows in the same group focused at the same time.
# WM_TRANSIENT_FOR has higher priority if --detect-transient is enabled, too.
detect-client-leader = true;
# Window type settings
wintypes :
tooltip :
fade = true;
shadow = false;
opacity = 0.85;
focus = true;
fullscreen :
fade = true;
shadow = false;
opacity = 1;
focus = true;
# XSync
# See: https://github.com/yshui/picom/commit/b18d46bcbdc35a3b5620d817dd46fbc76485c20d
# Use X Sync fence to sync clients' draw calls. Needed on nvidia-drivers with GLX backend for some users.
xrender-sync-fence = true;
#opacity-rule = [
#"99:name *?= 'Call'",
#"99:class_g = 'Chromium'",
#"99:name *?= 'Conky'",
#"99:class_g = 'Darktable'",
#"50:class_g = 'Dmenu'",
#"99:name *?= 'Event'",
#"99:class_g = 'Firefox'",
#"99:class_g = 'GIMP'",
#"99:name *?= 'Image'",
#"99:class_g = 'Lazpaint'",
#"99:class_g = 'Midori'",
#"99:name *?= 'Minitube'",
#"99:class_g = 'Mousepad'",
#"99:name *?= 'MuseScore'",
#"90:name *?= 'Page Info'",
#"99:name *?= 'Pale Moon'",
#"90:name *?= 'Panel'",
#"99:class_g = 'Pinta'",
#"90:name *?= 'Restart'",
#"99:name *?= 'sudo'",
#"99:name *?= 'Screenshot'",
#"99:class_g = 'Viewnior'",
#"99:class_g = 'VirtualBox'",
#"99:name *?= 'VLC'",
#"99:name *?= 'Write'",
#"93:class_g = 'URxvt' && !_NET_WM_STATE@:32a",
#"0:_NET_WM_STATE@:32a *= '_NET_WM_STATE_HIDDEN'",
#"96:_NET_WM_STATE@:32a *= '_NET_WM_STATE_STICKY'"
And here is my .Xresources file:
xft.dpi: 96
xft.antialias: true
xft.hinting: true
xft.rgba: rgb
xft.autohint: false
xft.hintstyle: hintslight
xft.lcdfilter: lcddefault*.foreground: #f8f8f2CC
*.background: #282a36CC
*.color0: #44475a
*.color8: #44475a
*.color1: #ff5555
*.color9: #ff6e67
*.color2: #50fa7b
*.color10: #5af78e
*.color3: #f1fa8c
*.color11: #f4f99d
*.color4: #bd93f9
*.color12: #caa9fa
*.color5: #ff79c6
*.color13: #ff92d0
*.color6: #8be9fd
*.color14: #9aedfe
*.color7: #f8f8f2
*.color15: #f8f8f2
And my i3 bar config:
# status bar
bar {
status_command i3blocks -c /home/pedromonici/.i3/i3blocks/config
i3bar_command i3bar -t
position top
height 28
colors {
background #282a36CC
separator #676e7d
# border bground text
focused_workspace #282a36CC #282a36CC #FFFFFF
inactive_workspace #282a36CC #282a36CC #676e7d
urgent_workspace #282a36CC #282a36CC #e53935
I really need some help. Thank you guys!
