Hi,
I’ve hit a bit of a wall in trying to troubleshoot this myself. Yesterday I was making some customization’s to my urxvt, powerline and fonts when I encountered a core dump error. It seemed random to me. I was running firefox and all of the sudden it froze. dmenu wasn’t working either so I decided to reboot. After rebooting I made it to the i3 login screen and when I entered my password the screen would go black for a little bit and then I’d be sent back to the login screen. I opened up a TTY and tried to startx from there and the same thing happened (I was sent back to the TTY) I checked my Xorg log and it says that the server terminated successfully. I did a pacman -Syyu and rebooted and the problem did not resolve.
After searching around these forums I now know not to do this but I wanted to test another profile so I tried startx in root and was able to launch i3
Here is my xorg.1.log
[ 3874.316] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 3874.317]
X.Org X Server 1.20.13
[ 3874.318] Build Operating System: Linux Manjaro Linux
[ 3874.319] Current Operating System: Linux sgdesk 5.10.70-1-MANJARO #1 SMP PREEMPT Thu Sep 30 15:29:01 UTC 2021 x86_64
[ 3874.319] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=2d312f2e-e40a-4c25-9af9-0f1fb4662fc9 rw
[ 3874.320] Build Date: 24 August 2021 10:21:29AM
[ 3874.321]
[ 3874.322] Current version of pixman: 0.40.0
[ 3874.323] Before reporting problems, check http://wiki.x.org
[ 3874.323] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3874.325] (==) Log file: "/home/br/.local/share/xorg/Xorg.1.log", Time: Sat Oct 9 11:48:09 2021
[ 3874.325] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3874.326] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3874.326] (==) No Layout section. Using the first Screen section.
[ 3874.326] (==) No screen section available. Using defaults.
[ 3874.326] (**) |-->Screen "Default Screen Section" (0)
[ 3874.326] (**) | |-->Monitor "<default monitor>"
[ 3874.326] (==) No monitor specified for screen "Default Screen Section".
[ 3874.326] (==) Automatically adding devices
[ 3874.326] (==) Automatically enabling devices
[ 3874.326] (==) Automatically adding GPU devices
[ 3874.326] (==) Automatically binding GPU devices
[ 3874.326] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3874.326] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3874.326] Entry deleted from font path.
[ 3874.326] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3874.326] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3874.326] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 3874.326] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3874.326] (II) The server relies on udev to provide the list of input devices.
[ 3874.326] (II) Module ABI versions:
[ 3874.326] X.Org ANSI C Emulation: 0.4
[ 3874.326] X.Org Video Driver: 24.1
[ 3874.326] X.Org XInput driver : 24.1
[ 3874.326] X.Org Server Extension : 10.0
[ 3874.327] (++) using VT number 2
[ 3874.329] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[ 3874.330] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3874.331] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 3874.338] (--) PCI:*(9@0:0:0) 10de:2182:19da:3527 rev 161, Mem @ 0xf5000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[ 3874.338] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3874.338] (II) LoadModule: "glx"
[ 3874.338] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3874.340] (II) Module glx: vendor="X.Org Foundation"
[ 3874.340] compiled for 1.20.13, module version = 1.0.0
[ 3874.340] ABI class: X.Org Server Extension, version 10.0
[ 3874.341] (==) Matched modesetting as autoconfigured driver 0
[ 3874.341] (==) Matched fbdev as autoconfigured driver 1
[ 3874.341] (==) Matched vesa as autoconfigured driver 2
[ 3874.341] (==) Assigned the driver to the xf86ConfigLayout
[ 3874.341] (II) LoadModule: "modesetting"
[ 3874.341] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3874.342] (II) Module modesetting: vendor="X.Org Foundation"
[ 3874.342] compiled for 1.20.13, module version = 1.20.13
[ 3874.342] Module class: X.Org Video Driver
[ 3874.342] ABI class: X.Org Video Driver, version 24.1
[ 3874.342] (II) LoadModule: "fbdev"
[ 3874.342] (WW) Warning, couldn't open module fbdev
[ 3874.342] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3874.342] (II) LoadModule: "vesa"
[ 3874.342] (WW) Warning, couldn't open module vesa
[ 3874.342] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3874.342] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3874.342] (II) modeset(0): using drv /dev/dri/card0
[ 3874.342] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 3874.343] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 3874.343] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 3874.343] (==) modeset(0): RGB weight 888
[ 3874.343] (==) modeset(0): Default visual is TrueColor
[ 3874.343] (II) Loading sub module "glamoregl"
[ 3874.343] (II) LoadModule: "glamoregl"
[ 3874.343] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 3874.348] (II) Module glamoregl: vendor="X.Org Foundation"
[ 3874.348] compiled for 1.20.13, module version = 1.0.1
[ 3874.348] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3874.386] (II) modeset(0): glamor X acceleration enabled on NV168
[ 3874.386] (II) modeset(0): glamor initialized
[ 3874.456] (II) modeset(0): Output DP-1 has no monitor section
[ 3874.528] (II) modeset(0): Output HDMI-1 has no monitor section
[ 3874.535] (II) modeset(0): Output DP-2 has no monitor section
[ 3874.786] (II) modeset(0): Output DP-3 has no monitor section
[ 3874.856] (II) modeset(0): EDID for output DP-1
[ 3874.928] (II) modeset(0): EDID for output HDMI-1
[ 3874.928] (II) modeset(0): Manufacturer: ACR Model: 2ca Serial#: 1126212357
[ 3874.928] (II) modeset(0): Year: 2014 Week: 32
[ 3874.928] (II) modeset(0): EDID Version: 1.3
[ 3874.928] (II) modeset(0): Digital Display Input
[ 3874.928] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34
[ 3874.928] (II) modeset(0): Gamma: 2.20
[ 3874.928] (II) modeset(0): DPMS capabilities: StandBy Suspend
[ 3874.928] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 3874.928] (II) modeset(0): First detailed timing is preferred mode
[ 3874.928] (II) modeset(0): redX: 0.642 redY: 0.335 greenX: 0.291 greenY: 0.636
[ 3874.928] (II) modeset(0): blueX: 0.153 blueY: 0.043 whiteX: 0.313 whiteY: 0.329
[ 3874.928] (II) modeset(0): Supported established timings:
[ 3874.928] (II) modeset(0): 720x400@70Hz
[ 3874.928] (II) modeset(0): 640x480@60Hz
[ 3874.928] (II) modeset(0): 640x480@67Hz
[ 3874.928] (II) modeset(0): 640x480@72Hz
[ 3874.928] (II) modeset(0): 640x480@75Hz
[ 3874.928] (II) modeset(0): 800x600@56Hz
[ 3874.928] (II) modeset(0): 800x600@60Hz
[ 3874.928] (II) modeset(0): 800x600@72Hz
[ 3874.928] (II) modeset(0): 800x600@75Hz
[ 3874.928] (II) modeset(0): 832x624@75Hz
[ 3874.928] (II) modeset(0): 1024x768@60Hz
[ 3874.928] (II) modeset(0): 1024x768@70Hz
[ 3874.928] (II) modeset(0): 1024x768@75Hz
[ 3874.928] (II) modeset(0): 1280x1024@75Hz
[ 3874.928] (II) modeset(0): 1152x864@75Hz
[ 3874.928] (II) modeset(0): Manufacturer's mask: 0
[ 3874.928] (II) modeset(0): Supported standard timings:
[ 3874.928] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 3874.928] (II) modeset(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 3874.928] (II) modeset(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 3874.928] (II) modeset(0): #3: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 3874.928] (II) modeset(0): #4: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 3874.928] (II) modeset(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 3874.928] (II) modeset(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 3874.928] (II) modeset(0): #7: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 3874.928] (II) modeset(0): Supported detailed timing:
[ 3874.928] (II) modeset(0): clock: 148.5 MHz Image Size: 598 x 336 mm
[ 3874.928] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 3874.928] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 3874.928] (II) modeset(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 175 MHz
[ 3874.928] (II) modeset(0): Monitor name: S271HL
[ 3874.928] (II) modeset(0): Serial No: LUWAA0058535
[ 3874.928] (II) modeset(0): clock: 74.2 MHz Image Size: 598 x 336 mm
[ 3874.928] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 3874.928] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 3874.928] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 3874.928] (II) modeset(0): clock: 27.0 MHz Image Size: 598 x 336 mm
[ 3874.928] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 3874.928] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 3874.928] (II) modeset(0): Number of EDID sections to follow: 1
[ 3874.928] (II) modeset(0): EDID (in hex):
[ 3874.928] (II) modeset(0): 00ffffffffffff000472ca0205a32043
[ 3874.928] (II) modeset(0): 20180103803c2278ca7b45a4554aa227
[ 3874.929] (II) modeset(0): 0b5054bfef80714f8140818081c08100
[ 3874.929] (II) modeset(0): 9500b300d1c0023a801871382d40582c
[ 3874.929] (II) modeset(0): 450056502100001e000000fd00384c1f
[ 3874.929] (II) modeset(0): 5311000a202020202020000000fc0053
[ 3874.929] (II) modeset(0): 323731484c0a202020202020000000ff
[ 3874.929] (II) modeset(0): 004c55574141303035383533350a01fc
[ 3874.929] (II) modeset(0): 020324f14f0102030405060790111213
[ 3874.929] (II) modeset(0): 1415161f230907078301000067030c00
[ 3874.929] (II) modeset(0): 1200382d023a801871382d40582c4500
[ 3874.929] (II) modeset(0): 56502100001f011d8018711c1620582c
[ 3874.929] (II) modeset(0): 250056502100009f011d007251d01e20
[ 3874.929] (II) modeset(0): 6e28550056502100001e8c0ad08a20e0
[ 3874.929] (II) modeset(0): 2d10103e960056502100001800000000
[ 3874.929] (II) modeset(0): 000000000000000000000000000000dc
[ 3874.929] (--) modeset(0): HDMI max TMDS frequency 225000KHz
[ 3874.929] (II) modeset(0): Not using default mode "1600x900" (bad mode clock/interlace/doublescan)
[ 3874.929] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 3874.929] (II) modeset(0): Printing probed modes for output HDMI-1
[ 3874.929] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 3874.929] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 3874.929] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 3874.929] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 3874.929] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 3874.929] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 3874.929] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 3874.929] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 3874.929] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 3874.929] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 3874.929] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 3874.929] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 3874.929] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 3874.929] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 3874.929] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 3874.929] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 3874.929] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 3874.929] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 3874.929] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 3874.929] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 3874.929] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 3874.929] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 3874.929] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 3874.929] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 3874.929] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 3874.929] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 3874.929] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 3874.929] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 3874.929] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 3874.936] (II) modeset(0): EDID for output DP-2
[ 3874.936] (II) modeset(0): Manufacturer: DEL Model: 404d Serial#: 1162166611
[ 3874.936] (II) modeset(0): Year: 2011 Week: 15
[ 3874.936] (II) modeset(0): EDID Version: 1.4
[ 3874.936] (II) modeset(0): Digital Display Input
[ 3874.936] (II) modeset(0): 8 bits per channel
[ 3874.936] (II) modeset(0): Digital interface is DisplayPort
[ 3874.936] (II) modeset(0): Max Image Size [cm]: horiz.: 47 vert.: 30
[ 3874.936] (II) modeset(0): Gamma: 2.20
[ 3874.936] (II) modeset(0): DPMS capabilities: Off
[ 3874.936] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 3874.936] (II) modeset(0): Default color space is primary color space
[ 3874.936] (II) modeset(0): First detailed timing is preferred mode
[ 3874.936] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 3874.936] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 3874.936] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 3874.936] (II) modeset(0): Supported established timings:
[ 3874.936] (II) modeset(0): 720x400@70Hz
[ 3874.936] (II) modeset(0): 640x480@60Hz
[ 3874.936] (II) modeset(0): 640x480@75Hz
[ 3874.936] (II) modeset(0): 800x600@60Hz
[ 3874.936] (II) modeset(0): 800x600@75Hz
[ 3874.936] (II) modeset(0): 1024x768@60Hz
[ 3874.936] (II) modeset(0): 1024x768@75Hz
[ 3874.936] (II) modeset(0): 1280x1024@75Hz
[ 3874.936] (II) modeset(0): Manufacturer's mask: 0
[ 3874.936] (II) modeset(0): Supported standard timings:
[ 3874.936] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 3874.936] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 3874.936] (II) modeset(0): #2: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 3874.936] (II) modeset(0): Supported detailed timing:
[ 3874.936] (II) modeset(0): clock: 119.0 MHz Image Size: 474 x 296 mm
[ 3874.936] (II) modeset(0): h_active: 1680 h_sync: 1728 h_sync_end 1760 h_blank_end 1840 h_border: 0
[ 3874.936] (II) modeset(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1080 v_border: 0
[ 3874.936] (II) modeset(0): Serial No: U828K14AEEAS
[ 3874.936] (II) modeset(0): Monitor name: DELL P2210
[ 3874.936] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 165 MHz
[ 3874.936] (II) modeset(0): EDID (in hex):
[ 3874.936] (II) modeset(0): 00ffffffffffff0010ac4d4053414545
[ 3874.936] (II) modeset(0): 0f150104a52f1e783eee95a3544c9926
[ 3874.936] (II) modeset(0): 0f5054a54b00714f8180b30001010101
[ 3874.936] (II) modeset(0): 0101010101017c2e90a0601a1e403020
[ 3874.936] (II) modeset(0): 3600da281100001a000000ff00553832
[ 3874.936] (II) modeset(0): 384b313441454541530a000000fc0044
[ 3874.936] (II) modeset(0): 454c4c2050323231300a2020000000fd
[ 3874.936] (II) modeset(0): 00384b1e5310000a202020202020004d
[ 3874.936] (II) modeset(0): Printing probed modes for output DP-2
[ 3874.936] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz eP)
[ 3874.936] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 3874.936] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 3874.936] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 3874.936] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 3874.936] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 3874.936] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 3874.936] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 3874.936] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 3874.936] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 3874.936] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 3875.187] (II) modeset(0): EDID for output DP-3
[ 3875.187] (II) modeset(0): Manufacturer: DEL Model: 4059 Serial#: 1128804949
[ 3875.187] (II) modeset(0): Year: 2010 Week: 49
[ 3875.187] (II) modeset(0): EDID Version: 1.3
[ 3875.187] (II) modeset(0): Digital Display Input
[ 3875.187] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 3875.187] (II) modeset(0): Gamma: 2.20
[ 3875.187] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 3875.187] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 3875.187] (II) modeset(0): Default color space is primary color space
[ 3875.187] (II) modeset(0): First detailed timing is preferred mode
[ 3875.187] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 3875.187] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 3875.187] (II) modeset(0): Supported established timings:
[ 3875.187] (II) modeset(0): 720x400@70Hz
[ 3875.187] (II) modeset(0): 640x480@60Hz
[ 3875.187] (II) modeset(0): 640x480@75Hz
[ 3875.187] (II) modeset(0): 800x600@60Hz
[ 3875.187] (II) modeset(0): 800x600@75Hz
[ 3875.187] (II) modeset(0): 1024x768@60Hz
[ 3875.187] (II) modeset(0): 1024x768@75Hz
[ 3875.187] (II) modeset(0): 1280x1024@75Hz
[ 3875.187] (II) modeset(0): Manufacturer's mask: 0
[ 3875.187] (II) modeset(0): Supported standard timings:
[ 3875.187] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 3875.187] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 3875.187] (II) modeset(0): Supported detailed timing:
[ 3875.187] (II) modeset(0): clock: 108.0 MHz Image Size: 338 x 270 mm
[ 3875.187] (II) modeset(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 3875.187] (II) modeset(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 3875.187] (II) modeset(0): Serial No: C2JMK0C9CH2U
[ 3875.187] (II) modeset(0): Monitor name: DELL P170S
[ 3875.187] (II) modeset(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 81 kHz, PixClock max 145 MHz
[ 3875.187] (II) modeset(0): EDID (in hex):
[ 3875.187] (II) modeset(0): 00ffffffffffff0010ac594055324843
[ 3875.187] (II) modeset(0): 3114010380221b78eeee95a3544c9926
[ 3875.187] (II) modeset(0): 0f5054a54b00714f8180010101010101
[ 3875.187] (II) modeset(0): 010101010101302a009851002a403070
[ 3875.187] (II) modeset(0): 1300520e1100001e000000ff0043324a
[ 3875.187] (II) modeset(0): 4d4b304339434832550a000000fc0044
[ 3875.187] (II) modeset(0): 454c4c2050313730530a2020000000fd
[ 3875.187] (II) modeset(0): 00384c1e510e000a20202020202000a7
[ 3875.187] (II) modeset(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan)
[ 3875.187] (II) modeset(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
[ 3875.187] (II) modeset(0): Not using default mode "1280x720" (bad mode clock/interlace/doublescan)
[ 3875.187] (II) modeset(0): Not using default mode "1280x800" (bad mode clock/interlace/doublescan)
[ 3875.187] (II) modeset(0): Printing probed modes for output DP-3
[ 3875.187] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 3875.187] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 3875.187] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 3875.187] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 3875.187] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 3875.187] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 3875.187] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 3875.187] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 3875.187] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 3875.187] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 3875.187] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 3875.187] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 3875.187] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 3875.187] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 3875.187] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 3875.187] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 3875.187] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 3875.187] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 3875.187] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 3875.187] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 3875.187] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 3875.187] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 3875.188] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 3875.188] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 3875.188] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 3875.188] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 3875.188] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 3875.188] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 3875.188] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 3875.188] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 3875.188] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 3875.188] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 3875.188] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 3875.188] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 3875.188] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 3875.188] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 3875.188] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 3875.188] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 3875.188] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 3875.188] (II) modeset(0): Output DP-1 disconnected
[ 3875.188] (II) modeset(0): Output HDMI-1 connected
[ 3875.188] (II) modeset(0): Output DP-2 connected
[ 3875.188] (II) modeset(0): Output DP-3 connected
[ 3875.188] (II) modeset(0): Using spanning desktop for initial modes
[ 3875.188] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[ 3875.188] (II) modeset(0): Output DP-2 using initial mode 1680x1050 +1920+0
[ 3875.188] (II) modeset(0): Output DP-3 using initial mode 1280x1024 +3600+0
[ 3875.188] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3875.188] (==) modeset(0): DPI set to (96, 96)
[ 3875.188] (II) Loading sub module "fb"
[ 3875.188] (II) LoadModule: "fb"
[ 3875.188] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3875.188] (II) Module fb: vendor="X.Org Foundation"
[ 3875.188] compiled for 1.20.13, module version = 1.0.0
[ 3875.188] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3875.193] (==) modeset(0): Backing store enabled
[ 3875.193] (==) modeset(0): Silken mouse disabled
[ 3875.234] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 3875.234] (==) modeset(0): DPMS enabled
[ 3875.234] (II) modeset(0): [DRI2] Setup complete
[ 3875.234] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 3875.234] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 3875.234] (II) Initializing extension Generic Event Extension
[ 3875.234] (II) Initializing extension SHAPE
[ 3875.234] (II) Initializing extension MIT-SHM
[ 3875.234] (II) Initializing extension XInputExtension
[ 3875.234] (II) Initializing extension XTEST
[ 3875.234] (II) Initializing extension BIG-REQUESTS
[ 3875.234] (II) Initializing extension SYNC
[ 3875.234] (II) Initializing extension XKEYBOARD
[ 3875.234] (II) Initializing extension XC-MISC
[ 3875.234] (II) Initializing extension SECURITY
[ 3875.234] (II) Initializing extension XFIXES
[ 3875.234] (II) Initializing extension RENDER
[ 3875.234] (II) Initializing extension RANDR
[ 3875.234] (II) Initializing extension COMPOSITE
[ 3875.234] (II) Initializing extension DAMAGE
[ 3875.234] (II) Initializing extension MIT-SCREEN-SAVER
[ 3875.234] (II) Initializing extension DOUBLE-BUFFER
[ 3875.234] (II) Initializing extension RECORD
[ 3875.234] (II) Initializing extension DPMS
[ 3875.234] (II) Initializing extension Present
[ 3875.234] (II) Initializing extension DRI3
[ 3875.234] (II) Initializing extension X-Resource
[ 3875.234] (II) Initializing extension XVideo
[ 3875.234] (II) Initializing extension XVideo-MotionCompensation
[ 3875.234] (II) Initializing extension GLX
[ 3875.237] (II) AIGLX: Loaded and initialized nouveau
[ 3875.237] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 3875.237] (II) Initializing extension XFree86-VidModeExtension
[ 3875.237] (II) Initializing extension XFree86-DGA
[ 3875.237] (II) Initializing extension XFree86-DRI
[ 3875.237] (II) Initializing extension DRI2
[ 3875.239] (II) modeset(0): Damage tracking initialized
[ 3875.239] (II) modeset(0): Setting screen physical size to 1291 x 285
[ 3875.278] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3875.278] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3875.278] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3875.278] (II) LoadModule: "libinput"
[ 3875.278] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 3875.279] (II) Module libinput: vendor="X.Org Foundation"
[ 3875.279] compiled for 1.20.13, module version = 1.2.0
[ 3875.279] Module class: X.Org XInput Driver
[ 3875.279] ABI class: X.Org XInput driver, version 24.1
[ 3875.279] (II) Using input driver 'libinput' for 'Power Button'
[ 3875.281] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 17 paused 0
[ 3875.281] (**) Power Button: always reports core events
[ 3875.281] (**) Option "Device" "/dev/input/event1"
[ 3875.281] (**) Option "_source" "server/udev"
[ 3875.284] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3875.284] (II) event1 - Power Button: device is a keyboard
[ 3875.284] (II) event1 - Power Button: device removed
[ 3875.284] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 3875.284] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3875.285] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3875.286] (II) event1 - Power Button: device is a keyboard
[ 3875.287] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 3875.287] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3875.287] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3875.287] (II) Using input driver 'libinput' for 'Power Button'
[ 3875.287] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 20 paused 0
[ 3875.287] (**) Power Button: always reports core events
[ 3875.287] (**) Option "Device" "/dev/input/event0"
[ 3875.288] (**) Option "_source" "server/udev"
[ 3875.289] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 3875.289] (II) event0 - Power Button: device is a keyboard
[ 3875.289] (II) event0 - Power Button: device removed
[ 3875.289] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 3875.289] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 3875.291] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 3875.291] (II) event0 - Power Button: device is a keyboard
[ 3875.293] (II) config/udev: Adding input device HID 0c45:7403 (/dev/input/event4)
[ 3875.293] (**) HID 0c45:7403: Applying InputClass "evdev keyboard catchall"
[ 3875.293] (**) HID 0c45:7403: Applying InputClass "libinput keyboard catchall"
[ 3875.293] (II) Using input driver 'libinput' for 'HID 0c45:7403'
[ 3875.294] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 21 paused 0
[ 3875.294] (**) HID 0c45:7403: always reports core events
[ 3875.294] (**) Option "Device" "/dev/input/event4"
[ 3875.294] (**) Option "_source" "server/udev"
[ 3875.297] (II) event4 - HID 0c45:7403: is tagged by udev as: Keyboard
[ 3875.297] (II) event4 - HID 0c45:7403: device is a keyboard
[ 3875.297] (II) event4 - HID 0c45:7403: device removed
[ 3875.297] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:04.0/0000:05:00.0/usb3/3-1/3-1.2/3-1.2:1.0/0003:0C45:7403.000B/input/input6/event4"
[ 3875.297] (II) XINPUT: Adding extended input device "HID 0c45:7403" (type: KEYBOARD, id 8)
[ 3875.300] (II) event4 - HID 0c45:7403: is tagged by udev as: Keyboard
[ 3875.300] (II) event4 - HID 0c45:7403: device is a keyboard
[ 3875.302] (II) config/udev: Adding input device HID 0c45:7403 (/dev/input/event5)
[ 3875.302] (**) HID 0c45:7403: Applying InputClass "evdev pointer catchall"
[ 3875.302] (**) HID 0c45:7403: Applying InputClass "libinput pointer catchall"
[ 3875.302] (II) Using input driver 'libinput' for 'HID 0c45:7403'
[ 3875.360] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 22 paused 0
[ 3875.360] (**) HID 0c45:7403: always reports core events
[ 3875.360] (**) Option "Device" "/dev/input/event5"
[ 3875.360] (**) Option "_source" "server/udev"
[ 3875.362] (II) event5 - HID 0c45:7403: is tagged by udev as: Mouse
[ 3875.362] (II) event5 - HID 0c45:7403: device is a pointer
[ 3875.363] (II) event5 - HID 0c45:7403: device removed
[ 3875.363] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:04.0/0000:05:00.0/usb3/3-1/3-1.2/3-1.2:1.1/0003:0C45:7403.000C/input/input7/event5"
[ 3875.363] (II) XINPUT: Adding extended input device "HID 0c45:7403" (type: MOUSE, id 9)
[ 3875.363] (**) Option "AccelerationScheme" "none"
[ 3875.363] (**) HID 0c45:7403: (accel) selected scheme none/0
[ 3875.363] (**) HID 0c45:7403: (accel) acceleration factor: 2.000
[ 3875.363] (**) HID 0c45:7403: (accel) acceleration threshold: 4
[ 3875.365] (II) event5 - HID 0c45:7403: is tagged by udev as: Mouse
[ 3875.366] (II) event5 - HID 0c45:7403: device is a pointer
[ 3875.367] (II) config/udev: Adding input device HID 0c45:7403 (/dev/input/mouse1)
[ 3875.367] (II) No input driver specified, ignoring this device.
[ 3875.367] (II) This device may have been added with another device file.
[ 3875.368] (II) config/udev: Adding input device HD Web Camera: HD Web Camera (/dev/input/event21)
[ 3875.368] (**) HD Web Camera: HD Web Camera: Applying InputClass "evdev keyboard catchall"
[ 3875.368] (**) HD Web Camera: HD Web Camera: Applying InputClass "libinput keyboard catchall"
[ 3875.368] (II) Using input driver 'libinput' for 'HD Web Camera: HD Web Camera'
[ 3875.370] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 23 paused 0
[ 3875.370] (**) HD Web Camera: HD Web Camera: always reports core events
[ 3875.370] (**) Option "Device" "/dev/input/event21"
[ 3875.370] (**) Option "_source" "server/udev"
[ 3875.372] (II) event21 - HD Web Camera: HD Web Camera: is tagged by udev as: Keyboard
[ 3875.372] (II) event21 - HD Web Camera: HD Web Camera: device is a keyboard
[ 3875.372] (II) event21 - HD Web Camera: HD Web Camera: device removed
[ 3875.372] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:04.0/0000:05:00.0/usb3/3-2/3-2:1.0/input/input23/event21"
[ 3875.372] (II) XINPUT: Adding extended input device "HD Web Camera: HD Web Camera" (type: KEYBOARD, id 10)
[ 3875.374] (II) event21 - HD Web Camera: HD Web Camera: is tagged by udev as: Keyboard
[ 3875.375] (II) event21 - HD Web Camera: HD Web Camera: device is a keyboard
[ 3875.376] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[ 3875.376] (II) No input driver specified, ignoring this device.
[ 3875.376] (II) This device may have been added with another device file.
[ 3875.377] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[ 3875.377] (II) No input driver specified, ignoring this device.
[ 3875.377] (II) This device may have been added with another device file.
[ 3875.377] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[ 3875.378] (II) No input driver specified, ignoring this device.
[ 3875.378] (II) This device may have been added with another device file.
[ 3875.378] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event11)
[ 3875.379] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event12)
[ 3875.379] (II) No input driver specified, ignoring this device.
[ 3875.379] (II) This device may have been added with another device file.
[ 3875.379] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[ 3875.380] (II) No input driver specified, ignoring this device.
[ 3875.380] (II) This device may have been added with another device file.
[ 3875.381] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event3)
[ 3875.381] (**) Valve Software Steam Controller: Applying InputClass "evdev pointer catchall"
[ 3875.381] (**) Valve Software Steam Controller: Applying InputClass "evdev keyboard catchall"
[ 3875.381] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[ 3875.381] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[ 3875.381] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[ 3875.382] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 24 paused 0
[ 3875.382] (**) Valve Software Steam Controller: always reports core events
[ 3875.382] (**) Option "Device" "/dev/input/event3"
[ 3875.382] (**) Option "_source" "server/udev"
[ 3875.384] (II) event3 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[ 3875.384] (II) event3 - Valve Software Steam Controller: device is a pointer
[ 3875.384] (II) event3 - Valve Software Steam Controller: device is a keyboard
[ 3875.385] (II) event3 - Valve Software Steam Controller: device removed
[ 3875.385] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[ 3875.385] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0a:00.3/usb7/7-1/7-1:1.0/0003:28DE:1142.0001/input/input5/event3"
[ 3875.385] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 11)
[ 3875.385] (**) Option "AccelerationScheme" "none"
[ 3875.385] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[ 3875.385] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[ 3875.385] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[ 3875.388] (II) event3 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[ 3875.388] (II) event3 - Valve Software Steam Controller: device is a pointer
[ 3875.388] (II) event3 - Valve Software Steam Controller: device is a keyboard
[ 3875.390] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[ 3875.390] (II) No input driver specified, ignoring this device.
[ 3875.390] (II) This device may have been added with another device file.
[ 3875.390] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event13)
[ 3875.391] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event14)
[ 3875.391] (II) No input driver specified, ignoring this device.
[ 3875.391] (II) This device may have been added with another device file.
[ 3875.392] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event15)
[ 3875.392] (II) No input driver specified, ignoring this device.
[ 3875.392] (II) This device may have been added with another device file.
[ 3875.392] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event16)
[ 3875.393] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event17)
[ 3875.393] (II) No input driver specified, ignoring this device.
[ 3875.393] (II) This device may have been added with another device file.
[ 3875.393] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event18)
[ 3875.394] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event19)
[ 3875.394] (II) No input driver specified, ignoring this device.
[ 3875.394] (II) This device may have been added with another device file.
[ 3875.395] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event20)
[ 3875.395] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 3875.395] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 3875.395] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 3875.396] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 25 paused 0
[ 3875.396] (**) Eee PC WMI hotkeys: always reports core events
[ 3875.396] (**) Option "Device" "/dev/input/event20"
[ 3875.396] (**) Option "_source" "server/udev"
[ 3875.397] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 3875.397] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[ 3875.397] (II) event20 - Eee PC WMI hotkeys: device removed
[ 3875.397] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input22/event20"
[ 3875.397] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 12)
[ 3875.398] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 3875.398] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[ 3875.399] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 3875.399] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 3875.399] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 3875.399] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 3875.400] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[ 3875.400] (**) AT Translated Set 2 keyboard: always reports core events
[ 3875.400] (**) Option "Device" "/dev/input/event2"
[ 3875.400] (**) Option "_source" "server/udev"
[ 3875.401] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 3875.401] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 3875.403] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 3875.403] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 3875.403] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 3875.404] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 3875.405] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 3875.407] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 3875.407] (II) No input driver specified, ignoring this device.
[ 3875.407] (II) This device may have been added with another device file.
[ 3875.411] (II) config/udev: Adding input device LogiOps Virtual Input (/dev/input/event22)
[ 3875.411] (**) LogiOps Virtual Input: Applying InputClass "evdev pointer catchall"
[ 3875.411] (**) LogiOps Virtual Input: Applying InputClass "evdev keyboard catchall"
[ 3875.411] (**) LogiOps Virtual Input: Applying InputClass "libinput pointer catchall"
[ 3875.411] (**) LogiOps Virtual Input: Applying InputClass "libinput keyboard catchall"
[ 3875.411] (II) Using input driver 'libinput' for 'LogiOps Virtual Input'
[ 3875.413] (EE) systemd-logind: failed to take device /dev/input/event22: No such device
[ 3875.413] (**) LogiOps Virtual Input: always reports core events
[ 3875.413] (**) Option "Device" "/dev/input/event22"
[ 3875.413] (**) Option "_source" "server/udev"
[ 3875.414] (II) event22 - LogiOps Virtual Input: is tagged by udev as: Keyboard Mouse
[ 3875.414] (II) event22 - LogiOps Virtual Input: device is a pointer
[ 3875.414] (II) event22 - LogiOps Virtual Input: device is a keyboard
[ 3875.414] (II) event22 - LogiOps Virtual Input: device removed
[ 3875.449] (II) libinput: LogiOps Virtual Input: needs a virtual subdevice
[ 3875.449] (**) Option "config_info" "udev:/sys/devices/virtual/input/input24/event22"
[ 3875.449] (II) XINPUT: Adding extended input device "LogiOps Virtual Input" (type: MOUSE, id 14)
[ 3875.450] (**) Option "AccelerationScheme" "none"
[ 3875.450] (**) LogiOps Virtual Input: (accel) selected scheme none/0
[ 3875.450] (**) LogiOps Virtual Input: (accel) acceleration factor: 2.000
[ 3875.450] (**) LogiOps Virtual Input: (accel) acceleration threshold: 4
[ 3875.451] (II) event22 - LogiOps Virtual Input: is tagged by udev as: Keyboard Mouse
[ 3875.451] (II) event22 - LogiOps Virtual Input: device is a pointer
[ 3875.451] (II) event22 - LogiOps Virtual Input: device is a keyboard
[ 3875.452] (II) config/udev: Adding input device LogiOps Virtual Input (/dev/input/mouse2)
[ 3875.452] (II) No input driver specified, ignoring this device.
[ 3875.452] (II) This device may have been added with another device file.
[ 3875.459] (**) Valve Software Steam Controller: Applying InputClass "evdev pointer catchall"
[ 3875.459] (**) Valve Software Steam Controller: Applying InputClass "evdev keyboard catchall"
[ 3875.459] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[ 3875.459] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[ 3875.459] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[ 3875.459] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 3875.459] (**) Valve Software Steam Controller: always reports core events
[ 3875.459] (**) Option "Device" "/dev/input/event3"
[ 3875.459] (**) Option "_source" "_driver/libinput"
[ 3875.459] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[ 3875.459] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0a:00.3/usb7/7-1/7-1:1.0/0003:28DE:1142.0001/input/input5/event3"
[ 3875.459] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 15)
[ 3875.459] (**) LogiOps Virtual Input: Applying InputClass "evdev pointer catchall"
[ 3875.459] (**) LogiOps Virtual Input: Applying InputClass "evdev keyboard catchall"
[ 3875.459] (**) LogiOps Virtual Input: Applying InputClass "libinput pointer catchall"
[ 3875.459] (**) LogiOps Virtual Input: Applying InputClass "libinput keyboard catchall"
[ 3875.459] (II) Using input driver 'libinput' for 'LogiOps Virtual Input'
[ 3875.460] (EE) systemd-logind: failed to take device /dev/input/event22: No such device
[ 3875.460] (**) LogiOps Virtual Input: always reports core events
[ 3875.460] (**) Option "Device" "/dev/input/event22"
[ 3875.460] (**) Option "_source" "_driver/libinput"
[ 3875.460] (II) libinput: LogiOps Virtual Input: is a virtual subdevice
[ 3875.460] (**) Option "config_info" "udev:/sys/devices/virtual/input/input24/event22"
[ 3875.460] (II) XINPUT: Adding extended input device "LogiOps Virtual Input" (type: KEYBOARD, id 16)
[ 3875.888] (**) Option "fd" "17"
[ 3875.888] (II) event1 - Power Button: device removed
[ 3875.888] (**) Option "fd" "20"
[ 3875.888] (II) event0 - Power Button: device removed
[ 3875.888] (**) Option "fd" "21"
[ 3875.888] (II) event4 - HID 0c45:7403: device removed
[ 3875.888] (**) Option "fd" "22"
[ 3875.888] (II) event5 - HID 0c45:7403: device removed
[ 3875.889] (**) Option "fd" "23"
[ 3875.889] (II) event21 - HD Web Camera: HD Web Camera: device removed
[ 3875.889] (**) Option "fd" "24"
[ 3875.889] (**) Option "fd" "25"
[ 3875.889] (II) event20 - Eee PC WMI hotkeys: device removed
[ 3875.889] (**) Option "fd" "26"
[ 3875.889] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 3875.889] (II) event3 - Valve Software Steam Controller: device removed
[ 3875.889] (II) event22 - LogiOps Virtual Input: device removed
[ 3875.916] (II) UnloadModule: "libinput"
[ 3875.917] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 3875.917] (II) UnloadModule: "libinput"
[ 3875.917] (II) systemd-logind: releasing fd for 13:66
[ 3875.943] (II) UnloadModule: "libinput"
[ 3875.943] (II) systemd-logind: releasing fd for 13:84
[ 3876.023] (II) UnloadModule: "libinput"
[ 3876.023] (II) systemd-logind: releasing fd for 13:67
[ 3876.089] (II) UnloadModule: "libinput"
[ 3876.089] (II) systemd-logind: releasing fd for 13:85
[ 3876.169] (II) UnloadModule: "libinput"
[ 3876.169] (II) systemd-logind: releasing fd for 13:69
[ 3876.236] (II) UnloadModule: "libinput"
[ 3876.236] (II) systemd-logind: releasing fd for 13:68
[ 3876.276] (II) UnloadModule: "libinput"
[ 3876.276] (II) systemd-logind: releasing fd for 13:64
[ 3876.317] (II) UnloadModule: "libinput"
[ 3876.317] (II) systemd-logind: releasing fd for 13:65
[ 3876.369] (II) Server terminated successfully (0). Closing log file.
Here is my xinitrc as well
#!/bin/bash
# ~/.xinitrc
# Executed by startx (run your window manager from here)
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
DEFAULT_SESSION='i3 --shmlog-size 0'
#xset +fp ~/.fonts/bdf-tewi-git
# merge in defaults and keymaps
if [ -f $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -f "$userresources" ]; then
xrdb -merge "$userresources"
fi
if [ -f "$usermodmap" ]; then
xmodmap "$usermodmap"
fi
# start some nice programs
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
[ -x "$f" ] && . "$f"
done
unset f
fi
get_session(){
local dbus_args=(--sh-syntax --exit-with-session)
case $1 in
# dwm) dbus_args+=(dwm) ;;
awesome) dbus_args+=(awesome) ;;
bspwm) dbus_args+=(bspwm-session) ;;
budgie) dbus_args+=(budgie-desktop) ;;
cinnamon) dbus_args+=(cinnamon-session) ;;
deepin) dbus_args+=(startdde) ;;
enlightenment) dbus_args+=(enlightenment_start) ;;
fluxbox) dbus_args+=(startfluxbox) ;;
gnome) dbus_args+=(gnome-session) ;;
i3|i3wm) dbus_args+=(i3 --shmlog-size 0) ;;
jwm) dbus_args+=(jwm) ;;
kde) dbus_args+=(startplasma-x11) ;;
lxde) dbus_args+=(startlxde) ;;
lxqt) dbus_args+=(lxqt-session) ;;
mate) dbus_args+=(mate-session) ;;
xfce) dbus_args+=(xfce4-session) ;;
openbox) dbus_args+=(openbox-session) ;;
*) dbus_args+=($DEFAULT_SESSION) ;;
esac
echo "dbus-launch ${dbus_args[*]}"
exec $(get_session "$1")
