Hello there,
So i upgraded my pc hardware. The new mainboard dont recognize my SSD with Manjaro but does recognize my other SSD with windows10. In windows10 i can access the other SSDs (one with manjaro and the other just ext4).
Any ideas what the problem could be and how to fix? I assume the bootsection of the installtion is roasted for some reason. But how to fix? I prefer not to clean install on to the main SSD
Best,
Boot a live ISO, try to manjaro-chroot into the existing OS on the not-recognized SSD and restore the boot-loader. Then try to boot from that SSD via firmware.
So
[manjaro@manjaro ~]$ lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME,SIZE
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME SIZE
/dev/loop0 squashfs 71.2M
/dev/loop1 squashfs 905.7M
/dev/loop2 squashfs 1.8G
/dev/loop3 squashfs 755.6M
/dev/sda dos 931.5G
/dev/sda1 dos 0x83 ext4 Linux 931.5G
/dev/sdb gpt 119.2G
/dev/sdb1 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment 499M
/dev/sdb2 gpt c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat EFI System 100M
/dev/sdb3 gpt e3c9e316-0b5c-4db8-817d-f92df00215ae Microsoft reserved 16M
/dev/sdb4 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data 118.1G
/dev/sdb5 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment 559M
/dev/sdc ext4 465.8G
/dev/sdd dos iso9660 14.7G
/dev/sdd1 dos 0x0 iso9660 Empty 3.6G
/dev/sdd2 dos 0xef vfat EFI (FAT-12/16/32) 4M
/dev/sde dos 192K
/dev/sde1 dos 0xe vfat W95 FAT16 (LBA) 160.5K
/dev/sdf 0B
/dev/sdg 0B
/dev/sdh 0B
/dev/sdi 0B
So sda(1) is the Linux SSD.
So i
[manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda1]
--> mount: [/mnt]
[manjaro /]#
then i (can i limit this update to the importent updates? i have currently very slow internet and its like 6.5gb)
[manjaro /]# pacman -Syu grub
So now i have to choose either the EFI or the BIOS Part buw how do i know what system do i have?
@edit i choose the BIOS part because the efi one aint working. Seems like /boot/efi isnt existing.
But even tho it didnt end in an error the SSD still aint bootable
It seems you have installed Windoze in UEFI mode on an gpt parted disk and Linux in BIOS mode on a msdos parted disk. This is possible but will later-on not allow you to boot from grub’s boot menu into Windoze. So, first you should decide if this is OK for you.
If it’s OK, then redo and proceed with this. If you have errors post them.
Otherwise, I would backup your files on the Linux partition and re-install it in UEFI mode after formatting the disk /dev/sda in gpt.
