Here is what I am seeing from updating this morning:
( 8/13) Install DKMS modules
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.2-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.6-1-MANJARO
Module version 550.54.14 for nvidia.ko.zst
exactly matches what is already found in kernel 6.7.6-1-MANJARO.
DKMS will not replace this module.
You may override by specifying --force.
Module version 550.54.14 for nvidia-uvm.ko.zst
Module version 550.54.14 for nvidia-modeset.ko.zst
Module version 550.54.14 for nvidia-drm.ko.zst
Module version 550.54.14 for nvidia-peermem.ko.zst
Error! Installation aborted.
==> WARNING: `dkms install --no-depmod nvidia/550.54.14 -k 6.7.6-1-MANJARO' exited 6
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.8-2-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.4-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.4-2-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.9-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.0-2-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.5-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.8-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.1-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.7-1-MANJARO
exactly matches what is already found in kernel 6.7.7-1-MANJARO.
==> WARNING: `dkms install --no-depmod nvidia/550.54.14 -k 6.7.7-1-MANJARO' exited 6
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.10-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.7-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.21-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.6.11-1-MANJARO
==> dkms install --no-depmod nvidia/550.54.14 -k 6.7.9-1-MANJARO
==> depmod 6.6.21-1-MANJARO
==> depmod 6.6.7-1-MANJARO
depmod: ERROR: fstatat(5, extramodules): No such file or directory
==> depmod 6.7.2-1-MANJARO
==> depmod 6.7.0-2-MANJARO
==> depmod 6.7.5-1-MANJARO
==> depmod 6.6.8-1-MANJARO
==> depmod 6.6.11-1-MANJARO
==> depmod 6.7.4-1-MANJARO
==> depmod 6.7.9-1-MANJARO
==> depmod 6.7.4-2-MANJARO
==> depmod 6.6.9-1-MANJARO
==> depmod 6.6.8-2-MANJARO
==> depmod 6.7.1-1-MANJARO
==> depmod 6.6.10-1-MANJARO
( 9/13) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64.img
==> Starting build: '4.19.309-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64.img'
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
-> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.21-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux67.preset: 'default'
-> -k /boot/vmlinuz-6.7-x86_64 -g /boot/initramfs-6.7-x86_64.img
==> Starting build: '6.7.9-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.7-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux67.preset: 'fallback'
-> -k /boot/vmlinuz-6.7-x86_64 -g /boot/initramfs-6.7-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.7-x86_64-fallback.img'
(10/13) Reloading system bus configuration...
(11/13) Updating icon theme caches...
(12/13) Checking which packages need to be rebuilt
foreign khotkeys
(13/13) Updating the desktop file MIME type cache...
Where should I start to troubleshoot this?
