I suddenly lost external display HDMI output on nvidia driver overnight
Hi everyone! I’ve been dealing with this issue for a couple of days now and I am really confused, let me set the picture: the computer is new, has been running only Win11 for the last 6 months. Recently I decided to make the switch again and try Linux and to my surprise all distros I live booted had immediate dual screen support. This has been a problem before and I was pleased to find that with new drivers I had to do zero tinkering.
I installed Manjaro and was very satisfied for about 2 weeks, when it just stopped working from one session to another. The system booted in the morning on only one screen while I turned it off the night before working fine on two. No updates, driver changes - at least to my knowledge. I was surprised, tried open source driver, this resolved the issue, but since I game, it was not ideal. Later I did a full reinstall, no change. What I noticed, however, was that even live usbs started showing on only one screen, while before they had no problem displaying on two, regardless of the distro, and I did some distro hopping before settling.
Full wipe, reinstall (Win 10 + Manjaro on 2 partitions) and the problem persists, I am truly at a loss, don’t know what I am missing, what changed in my setup. Could you assist me in finding the problem? I am really eager to learn and I just can’t get a grip on that one. Any advice will be truly appreciated, have a great day all!
My inxi -zv8
  Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=ba80d088-1708-4a6d-925b-8ebdfb92c99b rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Laptop System: LENOVO product: 82Y9 v: Legion Slim 5 16APH8
    serial: <superuser required> Chassis: type: 10 v: Legion Slim 5 16APH8
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    part-nu: LENOVO_MT_82Y9_BU_idea_FM_Legion Slim 5 16APH8
    uuid: <superuser required> UEFI: LENOVO v: M3CN39WW date: 09/22/2023
  ID-1: BAT1 charge: 80.8 Wh (100.0%) condition: 80.8/80.0 Wh (101.0%)
    volts: 17.5 min: 15.4 model: Celxpert L22C4PC2 type: Li-poly
    serial: <filter> status: full cycles: 36
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 27.1 GiB used: 3.11 GiB (11.5%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMCG78AGBSA092N serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704103
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 462 high: 1397 min/max: 400/5137 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 1397
    14: 400 15: 400 16: 400 bogomips: 121414
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic
    xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:2860 class-ID: 0300
  Device-2: AMD Phoenix1 vendor: Lenovo driver: amdgpu v: kernel
    arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1 bus-ID: 05:00.0
    chip-ID: 1002:15bf class-ID: 0300 temp: 45.0 C
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 30c9:00ac
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1015x317mm (39.96x12.48")
    s-diag: 1063mm (41.86") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model-id: CSO 0x161d serial: <filter> built: 2022
    res: 2560x1600 dpi: 188 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
    modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
    inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
    gfx1103_r1 LLVM 17.0.6 DRM 3.57 6.9.3-3-MANJARO) device-ID: 1002:15bf
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 Laptop GPU driver: nvidia v: 550.90.07
    device-ID: 10de:2860 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV GFX1103_R1) driver: mesa radv
    v: 24.0.9-manjaro1.1 device-ID: 1002:15bf surfaces: xcb,xlib
  Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 05:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_ps
    v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
    driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-4:4 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 1013.62 GiB used: 9.72 GiB (1.0%)
    model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: EL1QGXA7 temp: 50.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: Type-C size: 59.75 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1100
    scheme: MBR
  ID-1: / raw-size: 709.61 GiB size: 697.41 GiB (98.28%) used: 9.66 GiB (1.4%)
    fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: ba80d088-1708-4a6d-925b-8ebdfb92c99b
    used: 62.7 MiB (65.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: B4FE-D03F
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 244.14 GiB fs: ntfs label: N/A
    uuid: EEF600FAF600C535
  ID-3: /dev/sda1 maj-min: 8:1 size: 3.64 GiB fs: iso9660
  ID-4: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 565A-3603
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-1:2 info: Logitech USB Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c53f class-ID: 0300
  Device-2: 1-3:3 info: Luxvisions Innotech Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00ac class-ID: fe01
    serial: <filter>
  Device-3: 1-4:4 info: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek
    MT7922] type: bluetooth driver: btusb interfaces: 3 rev: 2.1
  Hub-2: 1-5:5 info: Genesys Logic Hub ports: 2 rev: 2.0
  Device-1: 1-5.1:6 info: Integrated Express ITE Device(8176) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c982 class-ID: 0301
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Device-1: 6-1:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
    Drive type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 304mA
    chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-9: 7-1:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-10: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-11: 8-1:3 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  System Temperatures: cpu: 47.8 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1202 libs: 357 tools: pamac pm: flatpak pkgs: 0
    1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 356
  1: cpu: 53.6% command: firefox pid: 1496 mem: 616.3 MiB (2.2%)
  2: cpu: 11.9% command: firefox pid: 2213 mem: 248.9 MiB (0.8%)
  3: cpu: 10.3% command: konsole pid: 2541 mem: 132.8 MiB (0.4%)
  4: cpu: 10.0% command: zsh pid: 2569 mem: 9.31 MiB (0.0%)
  5: cpu: 9.4% command: firefox pid: 2106 mem: 272.6 MiB (0.9%)
  Memory top: 5 of 356
  1: mem: 616.3 MiB (2.2%) command: firefox pid: 1496 cpu: 53.6%
  2: mem: 323.4 MiB (1.1%) command: plasmashell pid: 1008 cpu: 2.9%
  3: mem: 272.6 MiB (0.9%) command: firefox pid: 2106 cpu: 9.4%
  4: mem: 249.4 MiB (0.8%) command: firefox pid: 1886 cpu: 5.1%
  5: mem: 248.9 MiB (0.8%) command: firefox pid: 2213 cpu: 11.9%
  Processes: 356 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
    image: 10.81 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.34
In my experience - nothing does that - what did you change ?
The APU 7840HS using 780GPU has kernel driver so no big surprise.
From your systeminfo all looks good
I recall there was a quirk with mhwd where disrcrete gpu went black if it was Nvidia.
I suggest you consult the comment number two in the recent stable announcement - issues and solutions and possibly use this comment [Stable Update] 2024-06-10 - Kernels, Systemd, NVIDIA, Mesa, Qt5 - #74 by Yochanan .
Just for the future, if you happy how your system works. Then just create a snapshot with Timeshift and if you run into a issue, you just can restore your system with a few mouse clicks and lean back.
Thank you for the reply! As for what I changed: I honestly don’t know, haven’t been tinkering for a good couple of days and I can’t remember, so must’ve been something accidental.
The thread you directed me too had my answer, I edited modprobe.d and now the system starts with both screens working perfectly well. Thank you so much!
I am curious however, since this was something that affected both installed system AND live USBs of different distros, is there a possible answer as to why? I always thought live USBs were a closed system (they in fact sometimes worked worse when installed than in live versions a good couple of years back, as I recall), but as I said, I am still learning so I have no way to recognize the issue.
Anyway, I am very grateful for the help and bookmarking the thread for future reference :slight_smile:
I did! I went back a good 4 days and it still was not working, I was really stumped! But thank you for the suggestion!
