dec 21 19:15:10 majtaytre kdeconnectd[4936]: Cannot find Bluez 5 adapter for device search false
dec 21 19:15:10 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Not just one or two lines, there are hundreds of them, seems to spit a pair of lines out every 30 seconds or so, as if it’s looking for something that should be there. But I have, to my knowledge, never had a bluetooth device connected, ever, on any computer. And most certainly not this one.
Any idea how to stop that? Sure, it’s just some log entries, but the logs get drowned by all these lines. Something I should turn off, then what? And how? I checked this “Bluez” thing using pamac (GUI) and it says that Qt6 is involved, and some gadget called bluedevil (o.Ô).
I don’t think there is one, but I’m not sure how to interpret this:
$ systemctl status bluetooth.service
○ bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
dec 21 22:36:40 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:37:10 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:37:40 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:38:10 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:38:40 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:39:10 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:39:40 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:40:10 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:40:40 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
dec 21 22:41:10 majtaytre systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
This “dead” thing probably means that I now have to hold a funeral, or perhaps perform root canal surgery. If a tooth turns blue, then that’s severe toothache. 8)
I’ll try the rest of your suggestions and see what happens and report back later after inspecting the logs.
Thanks.
@nikgnomic Maybe, but the option @anon33601770 suggested strikes me as a little better. Then, as he said, I can just turn the daemon on again. If I uninstall the software/driver, I must also remember what it was I uninstalled. I’ll keep your suggestion in mind, though. Might come in handy later, if the other option doesn’t work.
it tells you that the bluetooth service is enabled (system will try to start it),
that it is not the default setting that it is enabled
and that it is inactive (dead) because it couldn’t be started
I’d guess because there is no bluetooth adapter to be started …
Isn’t that also a service that could be disabled?
I’d guess so, from the name.
Or some autostart option in your Plasma settings?
I’m not familiar with Plasma - there are many people here who are.
Try opening KDE Connect from the Application Launcher, or by running kdeconnect-app from a terminal.
When the GUI appears, click on the configuration icon at the bottom of the left column (next to your machine name). That will open the settings where you can disable the Bluetooth backend option:
