I removed kernel and after reboot grub is empty
Hi guys, by some strange play of the software I removed kernel (/boot is almost empty certainly no kernel there). Now when I rebooted GRUB offers only memtest.
I botted from live usb and went to chroot tried to use mhwd-kernel -i linux510 but it gives me error no targets specified.
Please help me to restore booting with a kernel on my notebook
Thank you
-r-
  • exit chroot
  • mount the installed system
    sudo mount /dev/sdXn /mnt
  • copy everything from life /boot to mounted /mnt/boot
    sudo cp -a /boot/* /mnt/boot
  • then chroot and try to install the kernel again, you should install the one which your live system is running
    pacman -S linuxXY
Eugen,
I copied /boot from live usb to /boot at my hdd, went to manjaro-chroot run mhwd-kernel -i and got error:
can not reinstall existing kernel
Did I misunderstood you somewhere?
I probably forgot sth how I fixed this once… Will think again.
Can you try to install the kernel with pacman -S linuxNN?
Yes maestro, this was is pacman -S linux510 in chroot did it!
Thank you!
-r-
