I need help with the latest mkinitcpio.conf.pacnew file
old
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont resume block filesystems fsck)```
new
HOOKS=(base systemd autodetect microcode modconf kms keyboard keymap sd-vconsole block filesystems fsck)```
i see two differences; consolefont vs sd-vconsole and resume vs nothing.
do i need to change or add something?
inxi
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=2c155c12-a203-4f76-83f3-c5a47e892804 rw
    resume=UUID=906e149c-5c8b-4b11-91fd-041805a54c5a udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
  Mobo: ASUSTeK model: TUF GAMING Z790-PLUS WIFI D4 v: Rev 1.xx
    Firmware: UEFI vendor: American Megatrends v: 1805 date: 10/30/2024
  Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x132
  Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
    st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
    KiB, 8x64 KiB L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 800 min/max: 800/5300:5400:4200 scaling:
    driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
    4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
    14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
    23: 800 24: 800 bogomips: 164088
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti GDDR6X] vendor: ASUSTeK
    driver: nvidia v: 580.105.08 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DP-3,
    HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:24c9 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-2 model: VG27AQML1A serial: <filter> built: 2023 res:
    mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: nvidia v: 580.105.08 device-ID: 10de:24c9
    surfaces: N/A
  Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-93-gbe2efb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel 700 Series CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
    chip-ID: 8086:125c class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel RST Volume Management Device Controller driver: vmd v: 0.6
    port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev: class-ID: 0104
  Local Storage: total: 1.82 TiB used: 101.92 GiB (5.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 39.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 990 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QJXD7 temp: 38.9 C
    scheme: GPT
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 101.92 GiB (11.2%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
    used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
    dev: /dev/nvme1n1p3 maj-min: 259:8
  System Temperatures: cpu: 29.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1440 libs: 396 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
  Memory: total: 32 GiB note: est. available: 31.06 GiB used: 3.12 GiB (10.1%)
  Processes: 415 Power: uptime: 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.8 running-in: konsole inxi: 3.3.40 ```
My HOOKS() were basically the same as yours. I replaced the hooks completely with the new recommendations from the .pacnew file. There was a warning during boot that annoyed me, so I removed sd-vconsole and put back consolefont.
It seems to be working as expected, but now with a slightly faster boot. Of course, that would likely be attributed to also removing Plymouth.
If you wish to know more about these hooks, there is a list at the following link with descriptions:
i’m not sure but sd-vconsole seems to be related to encryption(which i don’t use) and Resume to resume from hybernation.
it seems fine to me as it is,
i’ll leave it like that.
Thanks.
Neither do I, however sd-console seems to be a repacement for keymap and consolefont – the only thing mentioned about encryption relates to it’s position in the array:
Here, the systemd hook replaces the resume for hibernation (as well as several other hooks). I also saw a forum post briefly that suggested this might not be a good idea for everybody. I’m afraid I didn’t keep the link.
the .pacnew contains the new defaults
the difference between what you have and the new default is only the “resume” hook
put it in between “sd-vconsole” and “block”
make a copy of your original file, so you can go back if you want to for some reason
Just to be clear, the change is as of now not obligatory. The new defaults are a optimisation, but the old ones still work. Besides, there is the exact same topic already.
And they are redundant. See my post here.
The resume hook is no longer needed if you have the systemd hook.
Correct - thank you for the reminder!
I just looked at the table here again:
https://wiki.archlinux.org/title/Mkinitcpio#Common_hooks
