I am trying to follow these instructions from ProtonDB so that I can play [Prototype]. I was able to get it working on another OS but here it is giving me trouble. I installed winetricks from 'add/remove software and protontricks with pipx however when I input the command shown on ProtonDB into my terminal I get this.
protontricks 10150 winxp ✔
protontricks (ERROR): Active Proton installation could not be found automatically.
Proton installation could not be found!
How do I fix this issue?
inxi --admin --verbosity=7 --filter --width 255 ✘
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a57d8fd3-1038-4121-87bf-64966f643d33 rw quiet splash apparmor=1
security=apparmor resume=UUID=718cd937-3026-4b13-9a1d-bf5077a8e4b4
udev.log_priority=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac serial: <filter>
UEFI-[Legacy]: American Megatrends v: P3.70 date: 11/18/2019
RAM: total: 15.56 GiB used: 2.35 GiB (15.1%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 81476
Speed: 2724 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 2724 2: 1328 3: 1373 4: 1373 5: 1335 6: 1374 7: 1375 8: 1373 9: 3113
10: 1431 11: 1329 12: 1372
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Corsair CORSAIR Slipstream Multi-Device Receiver type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:4 chip-ID: 1b1c:0a42
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 08:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp8s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: f000 bus-ID: 09:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:5 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 3.66 TiB used: 125.3 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 38.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 945.06 GiB size: 929.15 GiB (98.32%)
used: 125.3 GiB (13.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: a57d8fd3-1038-4121-87bf-64966f643d33
dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: 718cd937-3026-4b13-9a1d-bf5077a8e4b4
ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: N/A
uuid: 3d456880-f30d-4dc4-8d27-660956a41eb4
ID-2: /dev/sdb1 maj-min: 8:17 size: 838.36 GiB fs: ntfs label: N/A
uuid: 536677A8605E131D
Device-1: 1-1:2 info: Razer USA Tartarus V2 type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:022b class-ID: 0300
Device-2: 1-2:3 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-3: 1-4:4 info: Corsair CORSAIR Slipstream Multi-Device Receiver
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a42 class-ID: 0300
serial: <filter>
Device-4: 1-6:5 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Device-5: 1-10:6
info: Corsair CORSAIR K100 RGB Optical-Mechanical Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1b1c:1b7c class-ID: 0300
serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 55 C
Processes: 310 Uptime: 1d 2h 19m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1353 lib: 435
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.08
