I believe that I accidentally corrupted my LUKS drive by using TestDisk. It contains very important documents and I’d really appreciate some help to try and recover it.
Sun Nov 1 13:20:04 2020
Command line: TestDisk
TestDisk 7.1, Data Recovery Utility, July 2019
Christophe GRENIER <grenier@cgsecurity.org>
https://www.cgsecurity.org
OS: Linux, kernel 5.7.19-2-MANJARO (#1 SMP PREEMPT Fri Aug 28 20:22:12 UTC 2020) x86_64
Compiler: GCC 10.1
ext2fs lib: 1.45.6, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: none, curses lib: ncurses 6.2
User is not root!
Hard disk list
Disk /dev/sr0 - 1493 MB / 1424 MiB - 729392 sectors (RO), sector size=2048 - PLDS DVD-RW DH16ACSH, S/N:S0A68694ZVJ6YD01FZ4D, FW:JL3B
TestDisk exited normally.
Using locale 'LC_CTYPE=en_CA.utf8;LC_NUMERIC=en_CA.UTF-8;LC_TIME=en_CA.UTF-8;LC_COLLATE=en_CA.utf8;LC_MONETARY=en_CA.UTF-8;LC_MESSAGES=en_CA.utf8;LC_PAPER=en_CA.UTF-8;LC_NAME=en_CA.UTF-8;LC_ADDRESS=en_CA.UTF-8;LC_TELEPHONE=en_CA.UTF-8;LC_MEASUREMENT=en_CA.UTF-8;LC_IDENTIFICATION=en_CA.UTF-8'.
Sun Nov 1 13:20:15 2020
Command line: TestDisk /debug
Compiler: GCC 10.1
/dev/sda: LBA, HPA, LBA48 support
/dev/sda: size 234441648 sectors
/dev/sda: user_max 234441648 sectors
/dev/sda: native_max 234441648 sectors
/dev/sdb: LBA, HPA, LBA48 support
/dev/sdb: size 468862128 sectors
/dev/sdb: user_max 468862128 sectors
/dev/sdb: native_max 468862128 sectors
/dev/sdc: LBA, HPA, LBA48 support
/dev/sdc: size 468862128 sectors
/dev/sdc: user_max 468862128 sectors
/dev/sdc: native_max 468862128 sectors
/dev/sdd: LBA, HPA, LBA48, DCO support
/dev/sdd: size 1953525168 sectors
/dev/sdd: user_max 1953525168 sectors
/dev/sdd: native_max 1953525168 sectors
/dev/sdd: dco 1953525168 sectors
Warning: can't get size for Disk /dev/mapper/control - 0 B - 0 sectors, sector size=512
/dev/sr0 is not an ATA disk
Warning: can't get size for Disk /dev/loop13 - 0 B - 0 sectors, sector size=512
Hard disk list
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - FM-25S2S-120GBP1, S/N:GS08104511080004, FW:3.1
Disk /dev/sdb - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - INTEL SSDSC2BW240H6, S/N:CVTR610507E1240CGN, FW:RG21
Disk /dev/sdc - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - INTEL SSDSC2BW240H6, S/N:CVTR610602YM240CGN, FW:RG21
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000NM0011, S/N:Z1N0FSCT, FW:PA03
Disk /dev/sdg - 128 GB / 119 GiB - CHS 15583 255 63, sector size=512 - Generic- SD/MMC, FW:1.00
Disk /dev/loop0 - 58 MB / 55 MiB - 113296 sectors (RO), sector size=512
Disk /dev/loop1 - 58 MB / 55 MiB - 113384 sectors (RO), sector size=512
Disk /dev/loop10 - 237 MB / 226 MiB - 464216 sectors (RO), sector size=512
Disk /dev/loop11 - 32 MB / 30 MiB - 63344 sectors (RO), sector size=512
Disk /dev/loop12 - 215 MB / 205 MiB - 421576 sectors (RO), sector size=512
Disk /dev/loop2 - 169 MB / 161 MiB - 330576 sectors (RO), sector size=512
Disk /dev/loop3 - 170 MB / 162 MiB - 333552 sectors (RO), sector size=512
Disk /dev/loop4 - 57 MB / 54 MiB - 112264 sectors (RO), sector size=512
Disk /dev/loop5 - 215 MB / 205 MiB - 421584 sectors (RO), sector size=512
Disk /dev/loop6 - 77 MB / 73 MiB - 151496 sectors (RO), sector size=512
Disk /dev/loop7 - 65 MB / 62 MiB - 127160 sectors (RO), sector size=512
Disk /dev/loop8 - 32 MB / 30 MiB - 63360 sectors (RO), sector size=512
Disk /dev/loop9 - 242 MB / 231 MiB - 473880 sectors (RO), sector size=512
Partition table type (auto): Intel
Disk /dev/sdb - 240 GB / 223 GiB - INTEL SSDSC2BW240H6
Partition table type: Intel
Analyse Disk /dev/sdb - 240 GB / 223 GiB - CHS 29185 255 63
Geometry from i386 MBR: head=255 sector=2
BAD_RS LBA=2048 64512
Current partition structure:
1 P Linux 0 32 33 29185 61 60 468858880
Bad relative sector.
No partition is bootable
search_part()
recover_btrfs: part_size 468858880
btrfs blocksize=4096 Backup superblock, 240 GB / 223 GiB
Results
* Linux 0 32 33 29185 61 60 468858880
Hint for advanced users: dmsetup may be used if you prefer to avoid rewriting the partition table for the moment:
echo "0 468858880 linear /dev/sdb 2048" | dmsetup create test0
interface_write()
1 * Linux 0 32 33 29185 61 60 468858880
search_part()
Results
interface_write()
interface_write()
write!
write_mbr_i386: starting...
write_all_log_i386: starting...
No extended partition
You will have to reboot for the change to take effect.
Disk /dev/sdd - 1000 GB / 931 GiB - ST1000NM0011
Interface Advanced
Geometry from i386 MBR: head=255 sector=63
check_part_i386 1 type E8: no test
1 P Sys=E8 0 32 33 121601 57 56 1953521664
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
search_part()
Linux 0 32 33 0 97 33 4096
LUKS 1 (Data size unknown), 2097 KB / 2048 KiB
Results
* Linux 0 32 33 0 97 33 4096
echo "0 4096 linear /dev/sdd 2048" | dmsetup create test0
interface_write()
1 * Linux 0 32 33 0 97 33 4096
write!
search_part()
Results
interface_write()
Couldn't open reiser filesystem
Can't open filesystem. Filesystem seems damaged.
interface_write()
write!
Sun Nov 1 17:55:20 2020
Compiler: GCC 10.1
User is not root!
Hard disk list
Sun Nov 1 17:55:35 2020
Compiler: GCC 10.1
Hard disk list
Disk /dev/loop10 - 77 MB / 73 MiB - 151496 sectors (RO), sector size=512
Disk /dev/loop11 - 237 MB / 226 MiB - 464216 sectors (RO), sector size=512
Disk /dev/loop12 - 242 MB / 231 MiB - 473880 sectors (RO), sector size=512
Disk /dev/loop3 - 57 MB / 54 MiB - 112264 sectors (RO), sector size=512
Disk /dev/loop4 - 170 MB / 162 MiB - 333552 sectors (RO), sector size=512
Disk /dev/loop6 - 65 MB / 62 MiB - 127160 sectors (RO), sector size=512
Disk /dev/loop7 - 215 MB / 205 MiB - 421576 sectors (RO), sector size=512
Disk /dev/loop9 - 32 MB / 30 MiB - 63344 sectors (RO), sector size=512
Interface Advanced
Geometry from i386 MBR: head=98 sector=33
LUKS 1, 2097 KB / 2048 KiB
search_superblock
Change partition type:
search_part()
Results
Can't open backup.log file: No such file or directory
interface_load
interface_write()
search_part()
Results
interface_write()
simulate write!
Interface Advanced
