Hmm, I’m starting to experience small “freezes”/delays since the Pahvo 21.1.5 updates; two examples:
- I have hibernation disabled, my monitors sleep after 2 min, and session locked after 5 minutes. After returning to my PC, waking the screens (move mouse or press keyboard), and logging in… there was a very noticeable delay (~20 sec) until any of my clicks registered on the right (main) monitor. I’ve captured the log entries from 2 minutes before login until the game launched (clicked desktop icon)…
Full Log
2021-10-11 1:59 P.M. rtkit-daemon Supervising 15 threads of 9 processes of 1 users.
2021-10-11 1:59 P.M. rtkit-daemon Successfully made thread 1503519 of process 2162 owned by '1000' RT at priority 5.
2021-10-11 1:59 P.M. rtkit-daemon Supervising 16 threads of 9 processes of 1 users.
2021-10-11 1:59 P.M. kernel ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
2021-10-11 1:59 P.M. kernel ata2.00: supports DRM functions and may not be fully accessible
2021-10-11 1:59 P.M. kernel ata2.00: disabling queued TRIM support
2021-10-11 1:59 P.M. kernel ata2.00: configured for UDMA/133
2021-10-11 1:59 P.M. kernel sd 1:0:0:0: [sda] Starting disk
2021-10-11 1:59 P.M. plasmashell StorageUnitQmlModel::monitor ( UDisks2Wrapper(0x7f96342b70e0) )
2021-10-11 2:00 P.M. CROND (root) CMD (timeshift --check --scripted)
2021-10-11 2:00 P.M. CROND (root) CMDOUT ((process:1504431): GLib-GIO-CRITICAL **: 14:00:01.627: g_file_get_path: assertion 'G_IS_FILE (file)' failed)
2021-10-11 2:00 P.M. CROND (root) CMDOUT ()
2021-10-11 2:00 P.M. CROND (root) CMDOUT (** (process:1504431): CRITICAL **: 14:00:01.628: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed)
2021-10-11 2:00 P.M. CROND (root) CMDOUT (** (process:1504431): CRITICAL **: 14:00:01.628: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed)
2021-10-11 2:00 P.M. CROND (root) CMDOUT (/dev/nvme3n1p1 is mounted at: /run/timeshift/backup, options: rw,relatime)
2021-10-11 2:00 P.M. CROND (root) CMDOUT (Daily snapshots are enabled)
2021-10-11 2:00 P.M. CROND (root) CMDOUT (Last daily snapshot is 16 hours old)
2021-10-11 2:00 P.M. CROND (root) CMDOUT (------------------------------------------------------------------------------)
2021-10-11 2:00 P.M. crontab (root) LIST (root)
2021-10-11 2:00 P.M. CROND (root) CMDEND (timeshift --check --scripted)
2021-10-11 2:00 P.M. kernel sd 1:0:0:0: [sda] Synchronizing SCSI cache
2021-10-11 2:00 P.M. kernel sd 1:0:0:0: [sda] Stopping disk
2021-10-11 2:00 P.M. plasmashell kf.i18n: "1 instead of 2 arguments to message {%1 (%2)} supplied before conversion."
2021-10-11 2:00 P.M. baloo_file 201580592070984456 "/home/<my_user_name>/.cache/plasma-svgelements" renaming "1BDE5A896AC0457CD78AE5F1A505CF64FEEDE5CF" to "plasma-svgelements"
2021-10-11 2:01 P.M. CROND (root) CMD (run-parts /etc/cron.hourly)
2021-10-11 2:01 P.M. CROND (root) CMDEND (run-parts /etc/cron.hourly)
2021-10-11 2:01 P.M. audit USER_AUTH pid=1508954 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="<my_user_name>" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
2021-10-11 2:01 P.M. kscreenlocker_greet file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
2021-10-11 2:01 P.M. kernel audit: type=1100 audit(1633978876.651:302): pid=1508954 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="<my_user_name>" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
2021-10-11 2:01 P.M. kscreenlocker_greet file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:45: TypeError: Cannot read property 'height' of null
2021-10-11 2:01 P.M. kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1696, resource id: 117440591, major code: 18 (ChangeProperty), minor code: 0
2021-10-11 2:01 P.M. kdeconnectd discarding unsupported packet "kdeconnect.notification" for "LM-G850"
2021-10-11 2:01 P.M. kwin_x11 kwin_core: XCB error: 10 (BadAccess), sequence: 10063, resource id: 1739, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
2021-10-11 2:01 P.M. kwin_x11 BlurConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 DesktopGridConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 GlideConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 KscreenConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 PresentWindowsConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 SlideConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 SlidingPopupsConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. kwin_x11 ZoomConfig::instance called after the first use - ignoring
2021-10-11 2:01 P.M. plasmashell kf.i18n: "1 instead of 2 arguments to message {%1 (%2)} supplied before conversion."
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. plasmashell qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
2021-10-11 2:01 P.M. kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14207, resource id: 10487208, major code: 18 (ChangeProperty), minor code: 0
2021-10-11 2:01 P.M. systemd Started Firestone Idle RPG.
- While typing this message in the forums (via Firefox), my typing is not delayed until I use the arrow keys to move up/down the text… moving from one line to another seems to be delayed by ~3 seconds. No change restarting firefox, but after continuing typing, it has moments were it works normally again.
What stood out in the logs from #1 are:
- There seems to be a TimeShift/Cron issue… but I sense that’s unrelated to the screen freeze/delay (I’ve reinstalled it in pamac; hopefully that resolves the issue)
plasmashellkf.i18n: “1 instead of 2 arguments to message {%1 (%2)} supplied before conversion.” -
kscreenlocker_greetfile:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property ‘width’ of null -
kwin_x11BlurConfig::instance called after the first use - ignoring -
plasmashellqt.svg: :406:376: Could not add child element to parent element because the types are incorrect.
I’d also like to note that I also waited until this update to install a 5.14 kernel (5.14.10) and had previously remained on 5.13.
