I install Manjaro with no Swap how to do i manually add swap i kind of need Swap?
I found out how to on this daharveyjr .com/how-to-add-swap-space-in-linux/
For a quick swapfile creation I typed out an example on another thread …
If you want a swap partition, then there must be free space on the disc or you must re-partition.
easiest way around in your case would be to create aforementioned “swap-file”;
https://wiki.archlinux.org/title/Swap#Swap_file
