after the last update the audio returned to work correctly but i noticed that every time i start the pc i have to go to pavucontrol and select the correct audio channel, there is some solution for it
Please post system information
inxi -Fazy
and systemd service information
systemctl --user status pipewire*
systemctl --user status pulseaudio*
[eduardo@eduardo-ax370gaming5 ~]$ inxi -Fazy
Kernel: 5.11.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=cd108a76-606e-4f2f-a6db-076984534948 rw quiet apparmor=1
security=apparmor udev.log_priority=3 iommu=pt idle=nomwait rcu_nocbs=0-15
processor.max_cstate=1 amdgpu.dc=0
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5 serial:
UEFI [Legacy]: American Megatrends v: F50e date: 07/02/2020
Info: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 L2 cache: 4 MiB
bogomips: 108628
Speed: 3393 MHz min/max: N/A Core speeds (MHz): 1: 3393 2: 3393 3: 3393
4: 3393 5: 3493 6: 3393 7: 3393 8: 3393 9: 3393 10: 3393 11: 3393 12: 3393
13: 3393 14: 3393 15: 3393 16: 3393
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 07:00.0
chip ID: 1002:67df class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-1 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7")
diag: 609mm (24")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.11.0-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 07:00.1
chip ID: 1002:aaf0 class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 09:00.3 chip ID: 1022:1457 class ID: 0403
Sound Server: ALSA v: k5.11.0-1-MANJARO
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: e000 bus ID: 04:00.0 chip ID: 8086:1539 class ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: d000 bus ID: 05:00.0 chip ID: 1969:e0b1
class ID: 0200
IF: enp5s0 state: down mac:
Local Storage: total: 3.64 TiB used: 2.44 TiB (67.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD30EZRX-00DC0B0
size: 2.73 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: rev: 0A80 scheme: GPT
ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 27.48 GiB (28.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw size: 501 MiB size: 500 MiB (99.80%) used: 4 KiB (0.0%)
fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw size: 833.37 GiB size: 819.29 GiB (98.31%)
used: 363.69 GiB (44.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 29.4 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1543
Processes: 364 Uptime: 7d 10h 52m wakeups: 0 Memory: 31.3 GiB
used: 6.4 GiB (20.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1567 pacman: 1553 lib: 462 flatpak: 6 snap: 8 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.3.01
[eduardo@eduardo-ax370gaming5 ~]$ systemctl --user status pipewire*
● pipewire.socket - Multimedia System
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; vendor preset: enabled)
Active: active (running) since Thu 2021-02-11 12:35:13 JST; 1 weeks 0 days ago
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
fev 11 12:35:13 eduardo-ax370gaming5 systemd[1154]: Listening on Multimedia System.
● pipewire.service - Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Thu 2021-02-11 18:35:38 JST; 1 weeks 0 days ago
TriggeredBy: ● pipewire.socket
Main PID: 3913 (pipewire)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.service
├─3913 /usr/bin/pipewire
└─3915 /usr/bin/pipewire-media-session
fev 11 18:35:38 eduardo-ax370gaming5 systemd[1154]: Started Multimedia Service.
[eduardo@eduardo-ax370gaming5 ~]$ systemctl --user status pulseaudio*
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
Active: active (running) since Thu 2021-02-11 12:35:15 JST; 1 weeks 0 days ago
TriggeredBy: ● pulseaudio.socket
Main PID: 1378 (pulseaudio)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.service
├─1378 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─1558 /usr/lib/pulse/gsettings-helper
fev 11 12:35:15 eduardo-ax370gaming5 systemd[1154]: Starting Sound Service…
fev 11 12:35:15 eduardo-ax370gaming5 systemd[1154]: Started Sound Service.
fev 11 12:35:40 eduardo-ax370gaming5 pulseaudio[1378]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service ‘org.bluez’: timed out (service_start_timeout=25000ms)
fev 11 18:28:49 eduardo-ax370gaming5 pulseaudio[1378]: Path Speaker is not a volume control
fev 11 18:44:01 eduardo-ax370gaming5 pulseaudio[1378]: O ALSA nos acordou para gravar novos dados no dispositivo, mas não há nada a ser gravado.
fev 11 18:44:01 eduardo-ax370gaming5 pulseaudio[1378]: É mais provável que isso seja um erro no driver “snd_hda_intel” do ALSA. Por favor, relate esse problema para os desenvolvedores do ALSA.
fev 11 18:44:01 eduardo-ax370gaming5 pulseaudio[1378]: Nós fomos acordados com o conjunto POLLOUT – entretanto, a snd_pcm_avail() subsequente retornou 0 ou outro valor < min_avail.
● pulseaudio.socket - Sound System
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; vendor preset: enabled)
Triggers: ● pulseaudio.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.socket
fev 11 12:35:13 eduardo-ax370gaming5 systemd[1154]: Listening on Sound System.
Up even with system update the problem persists
