I have to close & restart Plank at each computer start
Hi !
I have a problem with Plank on Manjaro only (I also use Debian + Xfce, Xubuntu & MXLinux with about the same settings and… Plank and… no problem on them).
Each time I start my Manjaro, Plank autostarts and… opened software don’t show (if I click on an app, it opens, but then doesn’t appear as open and cannot be selected).
I then have to close Plank and restart and then it’s functional.
This happened already on 3 different installs of mine with various kernels.
Sometimes, on a new install, Plank will behave normally during a couple of weeks and ultimately behave like I just described.
Thus deleting the profile is not sufficient : it is not the origin of the problem.
  Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2
  Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: K53SD v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: K53SD v: 1.0 serial: <filter>
  UEFI: American Megatrends v: K53SD.208 date: 08/10/2012
  ID-1: BAT0 charge: 18.1 Wh condition: 18.5/57.2 Wh (32%)
  model: ASUSTek K53--52 status: Unknown
  Topology: Dual Core model: Intel Core i3-2350M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
  Speed: 798 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 798 2: 798
  3: 798 4: 798
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
  Device-2: NVIDIA GF119M [GeForce 610M] vendor: ASUSTeK driver: nouveau
  v: kernel bus ID: 01:00.0
  Device-3: Alcor Micro Asus Integrated Webcam type: USB driver: uvcvideo
  bus ID: 1-1.2:3
  Display: x11 server: X.Org 1.20.9 driver: intel,nouveau
  unloaded: modesetting resolution: 1: 1366x768~60Hz 2: 1680x1050~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
  v: 3.3 Mesa 20.1.8 direct render: Yes
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.9.1-1-MANJARO
  Device-1: Intel Centrino Wireless-N 100 driver: iwlwifi v: kernel
  port: d000 bus ID: 03:00.0
  Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
  driver: atl1c v: kernel port: 9000 bus ID: 05:00.0
  IF: enp5s0 state: down mac: <filter>
  Local Storage: total: 931.51 GiB used: 416.01 GiB (44.7%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
  ID-1: / size: 95.62 GiB used: 34.54 GiB (36.1%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 819.53 GiB used: 381.47 GiB (46.5%) fs: ext4
  dev: /dev/sda3
  ID-1: swap-1 type: file size: 256.0 MiB used: 0 KiB (0.0%)
  file: /var/lib/systemd-swap/swapfc/1
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 49 C
  Fan Speeds (RPM): cpu: 2100
  Packages: 1710
  1: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
  2: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
  3: https://manjaro.moson.eu/stable/$repo/$arch
  4: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
  5: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
  Processes: 237 Uptime: 10h 27m Memory: 11.48 GiB used: 4.98 GiB (43.4%)
  Init: systemd Compilers: gcc: 10.2.0 Shell: Bash v: 5.0.18 inxi: 3.1.05
plank -v
[DEBUG 19:13:29.869137] [GLib-GIO] _g_io_module_get_default: Found default implementation gvfs (GDaemonVfs) for ‘gio-vfs’
[DEBUG 19:13:29.933419] [GLib] unsetenv() is not thread-safe and should not be used after threads are created
[INFO 19:13:29.935115] [AbstractMain:229] Plank version: 0.11.89
[INFO 19:13:29.935609] [AbstractMain:230] Kernel version: 5.9.1-1-MANJARO
[INFO 19:13:29.936074] [AbstractMain:231] GLib version: 2.66.0 (2.64.4)
[INFO 19:13:29.936548] [AbstractMain:234] GTK+ version: 3.24.23 (3.24.21)
[INFO 19:13:29.937013] [AbstractMain:237] Wnck version: 3.36.0
[INFO 19:13:29.937673] [AbstractMain:238] Cairo version: 1.17.3
[INFO 19:13:29.938500] [AbstractMain:239] Pango version: 1.46.2
[INFO 19:13:29.939334] [AbstractMain:240] + Cairo/Gtk+ HiDPI support enabled
[INFO 19:13:29.940148] [AbstractMain:245] + XInput Barriers support enabled
[INFO 19:13:29.965159] [WindowControl:68] Window-manager: Xfwm4
[VERBOSE 19:13:29.965779] Searching for modules in folder '/usr/lib/plank/docklets'
[DEBUG 19:13:29.967322] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-applications.so'
[INFO 19:13:29.967813] [DockletManager:107] Docklet 'applications' registered
[DEBUG 19:13:29.968809] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-battery.so'
[INFO 19:13:29.969311] [DockletManager:107] Docklet 'battery' registered
[DEBUG 19:13:29.970375] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-clippy.so'
[INFO 19:13:29.970958] [DockletManager:107] Docklet 'clippy' registered
[DEBUG 19:13:29.972072] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-clock.so'
[INFO 19:13:29.972586] [DockletManager:107] Docklet 'clock' registered
[DEBUG 19:13:29.973685] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-cpumonitor.so'
[INFO 19:13:29.974370] [DockletManager:107] Docklet 'cpumonitor' registered
[DEBUG 19:13:29.975438] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-desktop.so'
[INFO 19:13:29.975943] [DockletManager:107] Docklet 'desktop' registered
[DEBUG 19:13:29.977039] [DockletManager:204] Loading module '/usr/lib/plank/docklets/libdocklet-trash.so'
[INFO 19:13:29.977600] [DockletManager:107] Docklet 'trash' registered
[VERBOSE 19:13:29.978071] Finished searching for modules in folder '/usr/lib/plank/docklets'
[DEBUG 19:13:29.978528] [GLib] setenv()/putenv() are not thread-safe and should not be used after threads are created
[DEBUG 19:13:29.992348] [GLib-GIO] _g_io_module_get_default: Found default implementation dconf (DConfSettingsBackend) for ‘gsettings-backend’
[INFO 19:13:29.993364] [AbstractMain:299] Running with 1 docks ('dock1')
[DEBUG 19:13:29.994243] [DockController:80] Create dock 'dock1' (config_folder = /home/sum/.config/plank/dock1)
[DEBUG 19:13:29.995102] [GLib] setenv()/putenv() are not thread-safe and should not be used after threads are created
[DEBUG 19:13:29.995985] [Settings:53] Bind 'PlankDockPreferences' to '/net/launchpad/plank/docks/dock1/'
[VERBOSE 19:13:29.996744] Bind '/net/launchpad/plank/docks/dock1/position' to 'PlankDockPreferences.Position'
[VERBOSE 19:13:29.997388] Bind '/net/launchpad/plank/docks/dock1/icon-size' to 'PlankDockPreferences.IconSize'
[VERBOSE 19:13:29.997879] Bind '/net/launchpad/plank/docks/dock1/auto-pinning' to 'PlankDockPreferences.AutoPinning'
[VERBOSE 19:13:29.998352] Bind '/net/launchpad/plank/docks/dock1/pressure-reveal' to 'PlankDockPreferences.PressureReveal'
[VERBOSE 19:13:29.998823] Bind '/net/launchpad/plank/docks/dock1/show-dock-item' to 'PlankDockPreferences.ShowDockItem'
[VERBOSE 19:13:29.999307] Bind '/net/launchpad/plank/docks/dock1/items-alignment' to 'PlankDockPreferences.ItemsAlignment'
[VERBOSE 19:13:29.999787] Bind '/net/launchpad/plank/docks/dock1/theme' to 'PlankDockPreferences.Theme'
[VERBOSE 19:13:30.000271] Bind '/net/launchpad/plank/docks/dock1/zoom-percent' to 'PlankDockPreferences.ZoomPercent'
[VERBOSE 19:13:30.000804] Bind '/net/launchpad/plank/docks/dock1/monitor' to 'PlankDockPreferences.Monitor'
[VERBOSE 19:13:30.001277] Bind '/net/launchpad/plank/docks/dock1/lock-items' to 'PlankDockPreferences.LockItems'
[VERBOSE 19:13:30.001745] Bind '/net/launchpad/plank/docks/dock1/dock-items' to 'PlankDockPreferences.DockItems'
[VERBOSE 19:13:30.002233] Bind '/net/launchpad/plank/docks/dock1/tooltips-enabled' to 'PlankDockPreferences.TooltipsEnabled'
[VERBOSE 19:13:30.002699] Bind '/net/launchpad/plank/docks/dock1/unhide-delay' to 'PlankDockPreferences.UnhideDelay'
[VERBOSE 19:13:30.003186] Bind '/net/launchpad/plank/docks/dock1/current-workspace-only' to 'PlankDockPreferences.CurrentWorkspaceOnly'
[VERBOSE 19:13:30.003669] Bind '/net/launchpad/plank/docks/dock1/alignment' to 'PlankDockPreferences.Alignment'
[VERBOSE 19:13:30.004164] Bind '/net/launchpad/plank/docks/dock1/hide-delay' to 'PlankDockPreferences.HideDelay'
[VERBOSE 19:13:30.004690] Bind '/net/launchpad/plank/docks/dock1/hide-mode' to 'PlankDockPreferences.HideMode'
[VERBOSE 19:13:30.005168] Bind '/net/launchpad/plank/docks/dock1/zoom-enabled' to 'PlankDockPreferences.ZoomEnabled'
[VERBOSE 19:13:30.005638] Bind '/net/launchpad/plank/docks/dock1/pinned-only' to 'PlankDockPreferences.PinnedOnly'
[VERBOSE 19:13:30.006102] Bind '/net/launchpad/plank/docks/dock1/offset' to 'PlankDockPreferences.Offset'
[VERBOSE 19:13:30.007266] property changed: Launcher
[VERBOSE 19:13:30.047375] property changed: CascadeHide
[VERBOSE 19:13:30.049135] property changed: ItemMoveTime
[VERBOSE 19:13:30.051009] property changed: UrgentHueShift
[VERBOSE 19:13:30.052477] property changed: GlowPulseTime
[VERBOSE 19:13:30.053861] property changed: GlowTime
[VERBOSE 19:13:30.055350] property changed: GlowSize
[VERBOSE 19:13:30.056793] property changed: HideTime
[VERBOSE 19:13:30.058305] property changed: FadeTime
[VERBOSE 19:13:30.059836] property changed: SlideTime
[VERBOSE 19:13:30.061482] property changed: ActiveTime
[VERBOSE 19:13:30.063439] property changed: LaunchBounceTime
[VERBOSE 19:13:30.065023] property changed: UrgentBounceTime
[VERBOSE 19:13:30.066308] property changed: ClickTime
[VERBOSE 19:13:30.067432] property changed: FadeOpacity
[VERBOSE 19:13:30.068999] property changed: LaunchBounceHeight
[VERBOSE 19:13:30.070077] property changed: UrgentBounceHeight
[VERBOSE 19:13:30.071204] property changed: IconShadowSize
[VERBOSE 19:13:30.072225] property changed: IndicatorSize
[VERBOSE 19:13:30.072998] property changed: ItemPadding
[VERBOSE 19:13:30.073860] property changed: BottomPadding
[VERBOSE 19:13:30.074653] property changed: TopPadding
[VERBOSE 19:13:30.075551] property changed: InnerStrokeColor
[VERBOSE 19:13:30.076678] property changed: FillEndColor
[VERBOSE 19:13:30.077709] property changed: FillStartColor
[VERBOSE 19:13:30.078677] property changed: OuterStrokeColor
[VERBOSE 19:13:30.079410] property changed: LineWidth
[VERBOSE 19:13:30.080290] property changed: BottomRoundness
[VERBOSE 19:13:30.081092] property changed: TopRoundness
[WARN 19:13:30.081662] [Preferences:192] '/usr/share/plank/themes/Transparent/dock.theme' is read-only!
[DEBUG 19:13:30.082151] [Preferences:349] Loading preferences from file '/usr/share/plank/themes/Transparent/dock.theme'
[WARN 19:13:30.082743] [Preferences:378] Missing key 'OuterStrokeColor' for group 'PlankTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.083204] [Preferences:378] Missing key 'FillStartColor' for group 'PlankTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.083661] [Preferences:378] Missing key 'FillEndColor' for group 'PlankTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.084140] [Preferences:378] Missing key 'InnerStrokeColor' for group 'PlankTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.084871] [Preferences:378] Missing key 'HorizPadding' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.085545] [Preferences:378] Missing key 'ItemPadding' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.086015] [Preferences:378] Missing key 'IndicatorSize' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.086476] [Preferences:378] Missing key 'IconShadowSize' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.087289] [Preferences:378] Missing key 'UrgentBounceHeight' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.088080] [Preferences:378] Missing key 'LaunchBounceHeight' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.088629] [Preferences:378] Missing key 'FadeOpacity' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.089145] [Preferences:378] Missing key 'ClickTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.089673] [Preferences:378] Missing key 'UrgentBounceTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.090240] [Preferences:378] Missing key 'LaunchBounceTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.090770] [Preferences:378] Missing key 'ActiveTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.091275] [Preferences:378] Missing key 'SlideTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.091717] [Preferences:378] Missing key 'FadeTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.092151] [Preferences:378] Missing key 'HideTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.092585] [Preferences:378] Missing key 'GlowSize' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.093018] [Preferences:378] Missing key 'GlowTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.093453] [Preferences:378] Missing key 'GlowPulseTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.093968] [Preferences:378] Missing key 'UrgentHueShift' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.094445] [Preferences:378] Missing key 'ItemMoveTime' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.094884] [Preferences:378] Missing key 'CascadeHide' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[WARN 19:13:30.095318] [Preferences:378] Missing key 'BadgeColor' for group 'PlankDockTheme' in preferences file '/usr/share/plank/themes/Transparent/dock.theme' - using default value
[VERBOSE 19:13:30.095973] DockController.add_default_provider ()
[DEBUG 19:13:30.099024] [ItemFactory:176] Loading dock elements from '/home/sum/.config/plank/dock1/launchers'
[VERBOSE 19:13:30.100096] property changed: Launcher
[DEBUG 19:13:30.100693] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/FF Asatys.dockitem'
[VERBOSE 19:13:30.101937] property changed: Launcher
[DEBUG 19:13:30.102810] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/FF pro.dockitem'
[VERBOSE 19:13:30.104567] property changed: Launcher
[DEBUG 19:13:30.105293] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/simple-scan.dockitem'
[VERBOSE 19:13:30.107384] property changed: Launcher
[DEBUG 19:13:30.107955] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/anydesk.dockitem'
[VERBOSE 19:13:30.109136] property changed: Launcher
[DEBUG 19:13:30.109718] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/de.haeckerfelix.Shortwave.dockitem'
[VERBOSE 19:13:30.110989] property changed: Launcher
[DEBUG 19:13:30.111570] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/com.github.wwmm.pulseeffects.dockitem'
[VERBOSE 19:13:30.112726] property changed: Launcher
[DEBUG 19:13:30.113257] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/io.github.wereturtle.ghostwriter.dockitem'
[VERBOSE 19:13:30.114391] property changed: Launcher
[DEBUG 19:13:30.114922] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/Flameshot.dockitem'
[VERBOSE 19:13:30.116679] property changed: Launcher
[DEBUG 19:13:30.117279] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/vym.dockitem'
[VERBOSE 19:13:30.118436] property changed: Launcher
[DEBUG 19:13:30.119041] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/thunderbird.dockitem'
[VERBOSE 19:13:30.120567] property changed: Launcher
[DEBUG 19:13:30.121134] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/desktop.dockitem'
[VERBOSE 19:13:30.127123] property changed: Launcher
[DEBUG 19:13:30.127988] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/firefox.dockitem'
[VERBOSE 19:13:30.129955] property changed: Launcher
[DEBUG 19:13:30.130800] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/qBittorrent.dockitem'
[VERBOSE 19:13:30.132490] property changed: Launcher
[DEBUG 19:13:30.133322] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/xfce4-terminal.dockitem'
[VERBOSE 19:13:30.135246] property changed: Launcher
[DEBUG 19:13:30.136063] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/Marp.dockitem'
[VERBOSE 19:13:30.137832] property changed: Launcher
[DEBUG 19:13:30.138663] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/trash.dockitem'
[VERBOSE 19:13:30.158662] property changed: Launcher
[DEBUG 19:13:30.159272] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/bauh_appimage_hamsket.dockitem'
[VERBOSE 19:13:30.160623] property changed: Launcher
[DEBUG 19:13:30.161216] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/org.gnome.gedit.dockitem'
[VERBOSE 19:13:30.162605] property changed: Launcher
[DEBUG 19:13:30.163188] [Preferences:349] Loading preferences from file '/home/sum/.config/plank/dock1/launchers/io.github.quodlibet.QuodLibet.dockitem'
[VERBOSE 19:13:30.164356] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.164846] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.165461] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.165963] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.166515] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.167000] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.167574] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.168061] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.168620] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.169102] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.169641] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.170123] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.170973] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.171760] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.172646] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.173251] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.173886] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.174453] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.175472] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.175950] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.176500] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.176956] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.177542] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.178065] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.178611] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.179075] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.179604] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.180085] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.180698] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.181165] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.181740] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.182205] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.182754] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.183208] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.183717] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.184187] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.184703] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.185153] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.287588] property changed: Launcher
[VERBOSE 19:13:30.288496] property changed: Launcher
[VERBOSE 19:13:30.289489] property changed: Launcher
[VERBOSE 19:13:30.290318] DefaultDockItemProvider.update_visible_items ()
[VERBOSE 19:13:30.290862] DockContainer.update_visible_elements ()
[DEBUG 19:13:30.292466] [Unity:164] Initializing LauncherEntry support
[VERBOSE 19:13:30.293157] DockContainer.update_visible_elements ()
[VERBOSE 19:13:30.293685] DockController.update_visible_items ()
[VERBOSE 19:13:30.294384] DockController.update_items ()
[INFO 19:13:30.295163] [HideManager:616] Barriers enabled (XInput 2.3 support)
[VERBOSE 19:13:30.295668] PositionManager.update ()
[VERBOSE 19:13:30.296147] PositionManager.MaxIconSize = 128
[VERBOSE 19:13:30.296629] PositionManager.update_dimensions ()
[VERBOSE 19:13:30.297118] PositionManager.update_regions ()
[VERBOSE 19:13:30.297591] DockWindow.set_size_request (width = 74, height = 768)
[VERBOSE 19:13:30.298070] DockRenderer.reset_buffers ()
[VERBOSE 19:13:30.298840] DockWindow.move (x = 0, y = 0)
[VERBOSE 19:13:30.299641] DockWindow.update_icon_regions ()
[DEBUG 19:13:30.300481] [PositionManager:675] Without draw_values there is trouble ahead
[DEBUG 19:13:30.308672] [Unity:133] com.canonical.Unity acquired
[VERBOSE 19:13:30.321528] DockItem.draw_icon (width = 26, height = 26)
[WARN 19:13:30.368844] Creating surface took WAY TOO LONG (47ms), enabled downscaling for this cache!
[VERBOSE 19:13:30.369494] DockItem.draw_icon (width = 42, height = 42)
[VERBOSE 19:13:30.372202] DockTheme.create_indicator (size = 13)
[VERBOSE 19:13:30.372786] DockTheme.create_indicator (size = 13)
[VERBOSE 19:13:30.373401] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.375031] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.379566] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.381280] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.386282] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.387572] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.391649] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.392984] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.395372] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.396750] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.399067] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.400455] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.402253] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.403766] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.406170] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.407771] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.410346] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.412228] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.415231] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.416723] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.418974] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.420234] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.427633] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.428918] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.431525] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.433030] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.435954] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.437565] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.440974] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.442806] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.447054] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.448662] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.450918] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.452579] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.455847] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.457444] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.460642] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[VERBOSE 19:13:30.462262] DockItem.draw_icon (width = 26, height = 26)
[VERBOSE 19:13:30.465068] DockItem.draw_icon_with_shadow (width = 32, height = 32, shadow_size = 3)
[INFO 19:13:30.466655] [DockRenderer:481] Cairo.SurfaceType: XLIB
(There it’s functional, even if errors seem to show)
I don’t know where to eventually look for a log.
I tired to delay autostart : then it doesn’t start at all…
Any hint or advice ?
Am I the only one to experience this ?
The only thing missing from your excellent debugging is: How did you install Plank?
If the answer is:
pamac install plank
Open a bug wit the developers, because Manjaro has the very latest build and you might have run into a bug. If not, please elaborate.
:+1:
Since it runs automatically, there are a couple of approaches to see if you can debug it yourself using delays. One method, if your desktop supports it is to set the delay of the applications which run at session login. The other is to use sh sleep for forcing a delay. Example:
sh -c 'sleep 10 && plank'
The reason I recommend to enclose with sh -c is because I’ve had some weirdness come from adding command sequences directly. Also handy to know for certain applications which expect you to be at a specific directory prior to execution for use with custom launchers.
See how that goes and hollar back.
Quick edit: I wouldn’t imagine it to be the case for you currently but some desktops have another set of startup applications considered as “Essential” which reload on crash if possible. In my specific instance using MATE I can set Dock preference with gsettings as shown.
gsettings set org.mate.session.required-components dock 'plank'
Obviously this will vary between desktops, use your best judgment and consult documentation regarding session configuration.
Hi, thank you for caring !
@Fabby : this is the official repository package, indeed.
 ~]$ plank -V
0.11.89
It’s the same version on my Xubuntu and 0.11.4 on Debian. The only problem appears on the Manjaro (I have about 50 outside installs with Plank).
@Hebgbs : I tried your first command, seems better than my non working :
plank -p 10
as it starts and seems to behave properly.
This is nevertheless a turnaround, I’d be curious to grasp why I have this very problem only on MAnjaro.
I’ll introduce a launchpad ticket, but as I see the activity, it’ll not be quickly taken into account ! ^^
Try building it from AUR and see if the sh command is even necessary then? I know I have some weird issues myself that differ from a live session I’ve yet to solve, but using the latest version from GitHub is a good way to resolve problems occasionally.
killall plank
sudo pacman -R plank
pamac build plank-git
Adjust your autostart so it just runs Plank (without sh and sleep) and log out. If it works once you sign in, great. If not…
pamac remove plank-git
sudo pacman -S plank
Well, I just checked what it would do and wonder if I really need to install gnome-common on my Xfce ?
