I have file conflicts while updating my system
Hi everyone,
I have the following errors, thank you in advance :slightly_smiling_face:
error: failed to commit transaction (conflicting files)
python-setuptools: /usr/lib/python3.10/site-packages/setuptools/pycache/logging.cpython-310.pyc exists in filesystem
python-setuptools: /usr/lib/python3.10/site-packages/setuptools/_distutils/pycache/_collections.cpython-310.pyc exists in filesystem
python-setuptools: /usr/lib/python3.10/site-packages/setuptools/_distutils/_collections.py exists in filesystem
python-setuptools: /usr/lib/python3.10/site-packages/setuptools/logging.py exists in filesystem
See the Manjaro wiki
https://wiki.manjaro.org/index.php/Pacman_troubleshooting
And the Arch wiki
If you use pip to install python packages, you may want to read
Possibly - but I would prefer to use manjaro-tools to create a Manjaro ISO.
And yes you can create an ISO from your running system - it requires som manual doing but possible.
Basically you need to
  1. install the manjaro-tools-iso package
  2. initialize iso-profiles repo
  3. copy the folder /etc/manjaro-tools to your ~/.coinfig
  4. create a file in ~/.config/manjaro-tools/iso-profiles.conf with content
    run_dir $HOME/iso-profiles
  5. copy the content of your user’s home to the iso-profile’s desktop-overlay/etc/skel
  6. build the profile
    buildiso -p profile-name
Your error comes from having installed a system wide python package using sudo pip.
Remove the package using sudo pip - Reinstall it using the package manager
Then rerun your update
