omano
15 November 2023 18:57
1
I have a problem with Nvidia drivers 535.129.3 in this current update (and with the bad “rolled back” driver too) bad performance in games, Steam overlay not working, bad fps drops unplayable gameplay, Steam overlay not working.
I used a TimeShift snapshot from two weeks ago and it fixed the issues. 535.113.01 has no issue.
omano
17 November 2023 19:01
2
I still have same issue as before with the latest Nvidia drivers.
I have the same Problem.
Cyberpunk crashes the entire PC.
I found the problem here.
journalctl | grep Xid 0|1 ✘
Nov 17 00:04:00 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=5889, name=GameThread, Ch 00000086, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0xffff9190_00001000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 04:00:13 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=1743, name=GameThread, Ch 0000007e, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x3bb0_00001000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 20:44:36 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=2008, name=GameThread, Ch 00000089, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x250_00001000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 21:42:23 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=2874, name=GameThread, Ch 0000008b, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0xffffd410_00001000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 22:16:59 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=4122, name=GameThread, Ch 00000086, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x2ea0_00001000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 22:43:17 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=1812, name=GameThread, Ch 00000089, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0xffffb5d0_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 23:03:07 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=3124, name=GameThread, Ch 00000091, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x34d0_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 17 23:26:46 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=1731, name=GameThread, Ch 00000087, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0xfffff630_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Nov 18 01:08:49 weingeist-PC kernel: NVRM: Xid (PCI:0000:03:00): 31, pid=3156, name=GameThread, Ch 0000008f, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0xfffffd60_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
View this
Nvidia 545.x is in unstable …
omano
18 November 2023 16:59
6
Yes it is, not sure why you’re pointing that out.
omano:
a problem
What problem?
Which is? The testing branch went from 535.113.01 > 535.129.3 > 545.29.02 > 535.129.3.
omano:
same issue
What issue?
Not for me wth 545.29.02-1.
…because you never specifically mentioned you tried the 545 series, maybe?
I will refer you to your featured topic in your profile. C’mon, you know better. Help us help you.
weingeist:
545 is not in stable
You’re right. @omano is using testing and I’m using unstable. Are you lost?
omano
19 November 2023 00:40
10
Originally the 545 drivers currently on Unstable were the one provided in the previous Testing update, then they rolled back to 535, then in this update nothing changed apparently. I can’t pinpoint what is broken I can run games, just that I have horrible performance in them. Current Unstable state is the same to me it is broken. With my snapshot on 535.113 drivers I’m good, if I update to current Testing I’m good for poor performance with 535.129 It is like I have a problem with shaders and eve…
Also to be fair I didn’t open a support thread, two post I made from two different announcement thread were merged in this thread.
metalj
19 November 2023 04:42
11
Your profile gives us your system info, so we have that:
Branch: Testing
DE / WM: KDE Plasma
CPU: Ryzen 5 3600
GPU: GTX 1060
GPU Driver: Nvidia
Now, which games are giving you these performance issues?
Many of us are also gamers and usually own similar (if not the same) games.
linub
19 November 2023 14:37
12
Cyberpunk worked great for me and since the last update i get major stutters(especially after a few hours of playing).
535.129.03
i see it wasn’t updated on the 13.11 ,so I’m not sure what’s the culprit.
omano
19 November 2023 17:27
13
I updated the system again from my snapshot, and it seems to work OK now. Not sure what happened as it is the same driver that was problematic before (not same revision though). I also switched to kernel 6.6 and removed 6.5.
