The console in manjaro does not let me enter my password. when i click a key E.G h or control it just doesn’t type it. i have tried copy pasting it but that wont work either.
The password in a terminal window in Linux is not shown by default when you type it (for security reasons).
Type your password when prompted and hit Enter and it should work.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
