Instead of GNU appearing, its just running Manjaro. I mean no GNU interface. I reinstalled GNU from this instruction (GRUB/Restore the GRUB Bootloader - Manjaro )
sblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0 squashfs
/dev/loop1 squashfs
/dev/loop2 squashfs
/dev/loop3 squashfs
/dev/sda gpt
/dev/sda1 gpt e3c9e316-0b5c-4db8-817d-f92df00215ae Microsoft reserved
/dev/sda2 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
/dev/sda3 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/sdb dos iso9660
/dev/sdb1 dos 0x0 iso9660 Empty
/dev/sdb2 dos 0xef vfat EFI (FAT-12/16/32)
/dev/nvme0n1 gpt
/dev/nvme0n1p1 gpt c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat EFI System
/dev/nvme0n1p2 gpt e3c9e316-0b5c-4db8-817d-f92df00215ae Microsoft reserved
/dev/nvme0n1p3 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
/dev/nvme0n1p4 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment
/dev/nvme0n1p5 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda3]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.5-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.5-x86_64.img
Found initrd fallback image: /boot/initramfs-6.5-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
What did I do wrong?
