The library attempted to open the following supporting CUDA libraries,
but each of them failed. CUDA-aware support is disabled.
libcuda.so.1: cannot open shared object file: No such file or directory
libcuda.dylib: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.so.1: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.dylib: cannot open shared object file: No such file or directory
If you are not interested in CUDA-aware support, then run with
--mca opal_warn_on_missing_libcuda 0 to suppress this message. If you are interested
in CUDA-aware support, then try setting LD_LIBRARY_PATH to the location
of libcuda.so.1 to get passed this issue.
Did you install john
from the official repos ?
Do you have the proprietary NVIDIA drivers installed? It doesn’t look like it since it can’t find /usr/lib/libcuda.so.1
(/usr/lib64/
is a symlink to /usr/lib/
). Either way, there are some informative hints in the output. Have you tried following them?
Please copy and paste the terminal output here using the Preformatted text </> button, not screenshots.
Please also remove your cry for help from your topic title. You’ve posted in the #support category, we already know you’re requesting assistance.
i dont have nvidia video card i use intel graphic card
