Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 41.3
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 48.3 Wh (100.0%) condition: 48.3/60.0 Wh (80.5%) volts: 17.2 min: 15.4
model: Celxpert L19C4PC0 status: Full
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1559 high: 1904 min/max: 1400/2900 boost: enabled cores: 1: 1397 2: 1755
3: 1739 4: 1495 5: 1460 6: 1447 7: 1496 8: 1399 9: 1511 10: 1429 11: 1743 12: 1904 13: 1483
14: 1615 15: 1563 16: 1512 bogomips: 92662
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 470.103.01
bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
Display: x11 server: X.org 1.21.1.3 driver: loaded: amdgpu,nvidia
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 202.07 GiB (42.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 44.9 C
ID-1: / size: 459.79 GiB used: 202.07 GiB (43.9%) fs: ext4 dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 2.5 MiB (0.0%) dev: /dev/nvme0n1p2
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 383 Uptime: 11h 41m Memory: 15.07 GiB used: 4.18 GiB (27.7%) Init: systemd Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1544 Client: gnome-shell v: 41.3 inxi: 3.3.12
When I use vulkaninfo I get these errors and a warning:
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_lvp.so supports Vulkan 1.1, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_radeon.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/libvulkan_intel.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
How do I fix this?
