So it happened when i used tty (TeleTYpewriter) for the first time(for an actual purpose)
and i came back to gui environment without logging out from there.
From then onwards wherever i type my password for any purpose, either in terminal or somewhere else, it would always deny the pass
Once i went back to tty and logged out from there,
Everything got fixed.
On my pc this works flawlessly
What about providing some details ? see: “how to provide good information”
Manjaro is a multiuser system - and you can login as many times you want from different ttys or ssh connections without being rejected.
What happened on your system is impossible to deduct - so you should reproduce the issue repeatedly while making a detailed record of the actions leading up to the issue.
