I don't want my wifi to stop working
Hi, I’m still a newbie to linux I just came from Arch which took a lot of time and effort for me to learn to install. I the final problem (that I couldn’t resolve) and reason that I left Arch was that my wifi stopped working. a day before the wifi packed up I noticed in journalctl this
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: nl80211: kernel reports: Attribute failed policy validation Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument) Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
And now I’ve noticed it again in Manjaro. I really like this distro but I can’t use it if my wifi packs up again. At the moment my wifi is working and I’m just trying to pre-empt the problem.
~ >>> sudo journalctl -b
[sudo] password for muj:
-- Logs begin at Fri 2020-10-30 14:47:06 GMT, end at Fri 2020-10-30 18:56:09 GMT. --
Oct 30 17:24:19 The-Eagle kernel: Linux version 5.8.16-2-MANJARO (builduser@development) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Mon Oct 19 11:33:03 UTC 2020
Oct 30 17:24:19 The-Eagle kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=0cb78817-4380-4c16-aff3-db6a5cce3295 rw quiet apparmor=1 security=apparmor resume=UUID=0f2cb022-2ae2-4af5-878a-1a92b>
Oct 30 17:24:19 The-Eagle kernel: KERNEL supported cpus:
Oct 30 17:24:19 The-Eagle kernel:   Intel GenuineIntel
Oct 30 17:24:19 The-Eagle kernel:   AMD AuthenticAMD
Oct 30 17:24:19 The-Eagle kernel:   Hygon HygonGenuine
Oct 30 17:24:19 The-Eagle kernel:   Centaur CentaurHauls
Oct 30 17:24:19 The-Eagle kernel:   zhaoxin   Shanghai
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Oct 30 17:24:19 The-Eagle kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Oct 30 17:24:19 The-Eagle kernel: BIOS-provided physical RAM map:
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x0000000000100000-0x000000006b729fff] usable
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000006b72a000-0x000000006b85ffff] type 20
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000006b860000-0x000000006fac1fff] reserved
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000006fac2000-0x000000006fca9fff] ACPI NVS
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000006fcaa000-0x000000006fd0efff] ACPI data
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000006fd0f000-0x000000006fd0ffff] usable
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x000000006fd10000-0x000000007d7fffff] reserved
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Oct 30 17:24:19 The-Eagle kernel: BIOS-e820: [mem 0x0000000100000000-0x00000004807fffff] usable
Oct 30 17:24:19 The-Eagle kernel: NX (Execute Disable) protection: active
Oct 30 17:24:19 The-Eagle kernel: efi: EFI v2.60 by Lenovo
Oct 30 17:24:19 The-Eagle kernel: efi: TPMFinalLog=0x6fca2000 SMBIOS=0x6de55000 SMBIOS 3.0=0x6de48000 ACPI=0x6fd0e000 ACPI 2.0=0x6fd0e014 MEMATTR=0x688e3018 ESRT=0x6dc2f000
Oct 30 17:24:19 The-Eagle kernel: SMBIOS 3.1.1 present.
Oct 30 17:24:19 The-Eagle kernel: DMI: LENOVO 20QD00KWUK/20QD00KWUK, BIOS N2HET57W (1.40 ) 10/08/2020
Oct 30 17:24:19 The-Eagle kernel: tsc: Detected 2000.000 MHz processor
Oct 30 17:24:19 The-Eagle kernel: tsc: Detected 1999.968 MHz TSC
Oct 30 17:24:19 The-Eagle kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Oct 30 17:24:19 The-Eagle kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Oct 30 17:24:19 The-Eagle kernel: last_pfn = 0x480800 max_arch_pfn = 0x400000000
Oct 30 17:24:19 The-Eagle kernel: MTRR default type: write-back
Oct 30 17:24:19 The-Eagle kernel: MTRR fixed ranges enabled:
Oct 30 17:24:19 The-Eagle kernel:   00000-9FFFF write-back
Oct 30 17:24:19 The-Eagle kernel:   A0000-BFFFF uncachable
Oct 30 17:24:19 The-Eagle kernel:   C0000-FFFFF write-protect
Oct 30 17:24:19 The-Eagle kernel: MTRR variable ranges enabled:
Oct 30 17:24:19 The-Eagle kernel:   0 base 0080000000 mask 7F80000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   1 base 007C000000 mask 7FFC000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   2 base 007A000000 mask 7FFE000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   3 base 0079000000 mask 7FFF000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   4 base 2000000000 mask 6000000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   5 base 1000000000 mask 7000000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   6 base 0800000000 mask 7800000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   7 base 4000000000 mask 4000000000 uncachable
Oct 30 17:24:19 The-Eagle kernel:   8 disabled
Oct 30 17:24:19 The-Eagle kernel:   9 disabled
Oct 30 17:24:19 The-Eagle kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Oct 30 17:24:19 The-Eagle kernel: last_pfn = 0x6fd10 max_arch_pfn = 0x400000000
Oct 30 17:24:19 The-Eagle kernel: esrt: Reserving ESRT space from 0x000000006dc2f000 to 0x000000006dc2f100.
Oct 30 17:24:19 The-Eagle kernel: check: Scanning 1 areas for low memory corruption
Oct 30 17:24:19 The-Eagle kernel: Using GB pages for direct mapping
Oct 30 17:24:19 The-Eagle kernel: Secure boot could not be determined
Oct 30 17:24:19 The-Eagle kernel: RAMDISK: [mem 0x36759000-0x373a3fff]
Oct 30 17:24:19 The-Eagle kernel: ACPI: Early table checksum verification disabled
Oct 30 17:24:19 The-Eagle kernel: ACPI: RSDP 0x000000006FD0E014 000024 (v02 LENOVO)
Oct 30 17:24:19 The-Eagle kernel: ACPI: XSDT 0x000000006FD0C188 000114 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: FACP 0x000000006DC62000 000114 (v06 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: DSDT 0x000000006DC34000 0292E3 (v02 LENOVO CFL      20170001 INTL 20160422)
Oct 30 17:24:19 The-Eagle kernel: ACPI: FACS 0x000000006FB07000 000040
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DCB8000 001B26 (v02 LENOVO CpuSsdt  00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DCB7000 00056D (v02 LENOVO CtdpB    00001000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC7E000 004220 (v02 LENOVO DptfTabl 00001000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC67000 00330A (v02 LENOVO SaSsdt   00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC66000 000612 (v02 LENOVO Tpm2Tabl 00001000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: TPM2 0x000000006DC65000 000034 (v04 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: UEFI 0x000000006FB24000 000042 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC63000 000530 (v02 LENOVO PerfTune 00001000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: HPET 0x000000006DC61000 000038 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: APIC 0x000000006DC60000 00012C (v03 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: MCFG 0x000000006DC5F000 00003C (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: ECDT 0x000000006DC5E000 000053 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC33000 000024 (v02 LENOVO PID1Ssdt 00000010 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC31000 0014C0 (v02 LENOVO ProjSsdt 00000010 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: BOOT 0x000000006DC30000 000028 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SLIC 0x000000006DC2E000 000176 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC2C000 000EF6 (v02 LENOVO UsbCTabl 00001000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: LPIT 0x000000006DC2B000 000094 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: WSMT 0x000000006DC2A000 000028 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0x000000006DC28000 001983 (v02 LENOVO TbtTypeC 00000000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: DBGP 0x000000006DC27000 000034 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: DBG2 0x000000006DC26000 000054 (v00 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: MSDM 0x000000006DC25000 000055 (v03 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: BATB 0x000000006DA48000 00004A (v02 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: DMAR 0x000000006C241000 0000A8 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: NHLT 0x000000006C23F000 00184A (v00 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: FPDT 0x000000006C23E000 000044 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: BGRT 0x000000006C23D000 000038 (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: UEFI 0x000000006FB01000 00013E (v01 LENOVO TP-N2H   00001400 PTEC 00000002)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Local APIC address 0xfee00000
Oct 30 17:24:19 The-Eagle kernel: No NUMA configuration found
Oct 30 17:24:19 The-Eagle kernel: Faking a node at [mem 0x0000000000000000-0x00000004807fffff]
Oct 30 17:24:19 The-Eagle kernel: NODE_DATA(0) allocated [mem 0x4807fc000-0x4807fffff]
Oct 30 17:24:19 The-Eagle kernel: Zone ranges:
Oct 30 17:24:19 The-Eagle kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Oct 30 17:24:19 The-Eagle kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Oct 30 17:24:19 The-Eagle kernel:   Normal   [mem 0x0000000100000000-0x00000004807fffff]
Oct 30 17:24:19 The-Eagle kernel:   Device   empty
Oct 30 17:24:19 The-Eagle kernel: Movable zone start for each node
Oct 30 17:24:19 The-Eagle kernel: Early memory node ranges
Oct 30 17:24:19 The-Eagle kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
Oct 30 17:24:19 The-Eagle kernel:   node   0: [mem 0x0000000000100000-0x000000006b729fff]
Oct 30 17:24:19 The-Eagle kernel:   node   0: [mem 0x000000006fd0f000-0x000000006fd0ffff]
Oct 30 17:24:19 The-Eagle kernel:   node   0: [mem 0x0000000100000000-0x00000004807fffff]
Oct 30 17:24:19 The-Eagle kernel: Zeroed struct page in unavailable ranges: 49463 pages
Oct 30 17:24:19 The-Eagle kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000004807fffff]
Oct 30 17:24:19 The-Eagle kernel: On node 0 totalpages: 4112073
Oct 30 17:24:19 The-Eagle kernel:   DMA zone: 64 pages used for memmap
Oct 30 17:24:19 The-Eagle kernel:   DMA zone: 22 pages reserved
Oct 30 17:24:19 The-Eagle kernel:   DMA zone: 3998 pages, LIFO batch:0
Oct 30 17:24:19 The-Eagle kernel:   DMA32 zone: 6813 pages used for memmap
Oct 30 17:24:19 The-Eagle kernel:   DMA32 zone: 436011 pages, LIFO batch:63
Oct 30 17:24:19 The-Eagle kernel:   Normal zone: 57376 pages used for memmap
Oct 30 17:24:19 The-Eagle kernel:   Normal zone: 3672064 pages, LIFO batch:63
Oct 30 17:24:19 The-Eagle kernel: Reserving Intel graphics memory at [mem 0x79800000-0x7d7fffff]
Oct 30 17:24:19 The-Eagle kernel: ACPI: PM-Timer IO Port: 0x1808
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
Oct 30 17:24:19 The-Eagle kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Oct 30 17:24:19 The-Eagle kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Oct 30 17:24:19 The-Eagle kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Oct 30 17:24:19 The-Eagle kernel: ACPI: IRQ0 used by override.
Oct 30 17:24:19 The-Eagle kernel: ACPI: IRQ9 used by override.
Oct 30 17:24:19 The-Eagle kernel: Using ACPI (MADT) for SMP configuration information
Oct 30 17:24:19 The-Eagle kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Oct 30 17:24:19 The-Eagle kernel: e820: update [mem 0x66449000-0x66689fff] usable ==> reserved
Oct 30 17:24:19 The-Eagle kernel: TSC deadline timer available
Oct 30 17:24:19 The-Eagle kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x66449000-0x66689fff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x6b72a000-0x6b85ffff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x6b860000-0x6fac1fff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x6fac2000-0x6fca9fff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x6fcaa000-0x6fd0efff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x6fd10000-0x7d7fffff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0x7d800000-0xfe00ffff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
Oct 30 17:24:19 The-Eagle kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xffffffff]
Oct 30 17:24:19 The-Eagle kernel: [mem 0x7d800000-0xfe00ffff] available for PCI devices
Oct 30 17:24:19 The-Eagle kernel: Booting paravirtualized kernel on bare hardware
Oct 30 17:24:19 The-Eagle kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Oct 30 17:24:19 The-Eagle kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
Oct 30 17:24:19 The-Eagle kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
Oct 30 17:24:19 The-Eagle kernel: pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
Oct 30 17:24:19 The-Eagle kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Oct 30 17:24:19 The-Eagle kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4047798
Oct 30 17:24:19 The-Eagle kernel: Policy zone: Normal
Oct 30 17:24:19 The-Eagle kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=0cb78817-4380-4c16-aff3-db6a5cce3295 rw quiet apparmor=1 security=apparmor resume=UUID=0f2cb022-2ae2-4af5-878>
Oct 30 17:24:19 The-Eagle kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: mem auto-init: stack:byref_all, heap alloc:on, heap free:off
Oct 30 17:24:19 The-Eagle kernel: Memory: 15982852K/16448292K available (14339K kernel code, 1524K rwdata, 4664K rodata, 1648K init, 2952K bss, 465440K reserved, 0K cma-reserved)
Oct 30 17:24:19 The-Eagle kernel: random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
Oct 30 17:24:19 The-Eagle kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Oct 30 17:24:19 The-Eagle kernel: ftrace: allocating 40316 entries in 158 pages
Oct 30 17:24:19 The-Eagle kernel: ftrace: allocated 158 pages with 5 groups
Oct 30 17:24:19 The-Eagle kernel: rcu: Preemptible hierarchical RCU implementation.
Oct 30 17:24:19 The-Eagle kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
Oct 30 17:24:19 The-Eagle kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
Oct 30 17:24:19 The-Eagle kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Oct 30 17:24:19 The-Eagle kernel:         Trampoline variant of Tasks RCU enabled.
Oct 30 17:24:19 The-Eagle kernel:         Rude variant of Tasks RCU enabled.
Oct 30 17:24:19 The-Eagle kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Oct 30 17:24:19 The-Eagle kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Oct 30 17:24:19 The-Eagle kernel: NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
Oct 30 17:24:19 The-Eagle kernel: Console: colour dummy device 80x25
Oct 30 17:24:19 The-Eagle kernel: printk: console [tty0] enabled
Oct 30 17:24:19 The-Eagle kernel: ACPI: Core revision 20200528
Oct 30 17:24:19 The-Eagle kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
Oct 30 17:24:19 The-Eagle kernel: APIC: Switch to symmetric I/O mode setup
Oct 30 17:24:19 The-Eagle kernel: DMAR: Host address width 39
Oct 30 17:24:19 The-Eagle kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Oct 30 17:24:19 The-Eagle kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
Oct 30 17:24:19 The-Eagle kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Oct 30 17:24:19 The-Eagle kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
Oct 30 17:24:19 The-Eagle kernel: DMAR: RMRR base: 0x0000006fa7e000 end: 0x0000006fa9dfff
Oct 30 17:24:19 The-Eagle kernel: DMAR: RMRR base: 0x00000079000000 end: 0x0000007d7fffff
Oct 30 17:24:19 The-Eagle kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
Oct 30 17:24:19 The-Eagle kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Oct 30 17:24:19 The-Eagle kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Oct 30 17:24:19 The-Eagle kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Oct 30 17:24:19 The-Eagle kernel: x2apic enabled
Oct 30 17:24:19 The-Eagle kernel: Switched APIC routing to cluster x2apic.
Oct 30 17:24:19 The-Eagle kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Oct 30 17:24:19 The-Eagle kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x39a8208cdd2, max_idle_ns: 881590748921 ns
Oct 30 17:24:19 The-Eagle kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4001.60 BogoMIPS (lpj=6666560)
Oct 30 17:24:19 The-Eagle kernel: pid_max: default: 32768 minimum: 301
Oct 30 17:24:19 The-Eagle kernel: LSM: Security Framework initializing
Oct 30 17:24:19 The-Eagle kernel: Yama: becoming mindful.
Oct 30 17:24:19 The-Eagle kernel: AppArmor: AppArmor initialized
Oct 30 17:24:19 The-Eagle kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: mce: CPU0: Thermal monitoring enabled (TM1)
Oct 30 17:24:19 The-Eagle kernel: process: using mwait in idle threads
Oct 30 17:24:19 The-Eagle kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
Oct 30 17:24:19 The-Eagle kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
Oct 30 17:24:19 The-Eagle kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Oct 30 17:24:19 The-Eagle kernel: Spectre V2 : Mitigation: Enhanced IBRS
Oct 30 17:24:19 The-Eagle kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Oct 30 17:24:19 The-Eagle kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Oct 30 17:24:19 The-Eagle kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Oct 30 17:24:19 The-Eagle kernel: SRBDS: Mitigation: TSX disabled
Oct 30 17:24:19 The-Eagle kernel: Freeing SMP alternatives memory: 32K
Oct 30 17:24:19 The-Eagle kernel: smpboot: CPU0: Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz (family: 0x6, model: 0x8e, stepping: 0xc)
Oct 30 17:24:19 The-Eagle kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
Oct 30 17:24:19 The-Eagle kernel: ... version:                4
Oct 30 17:24:19 The-Eagle kernel: ... bit width:              48
Oct 30 17:24:19 The-Eagle kernel: ... generic registers:      4
Oct 30 17:24:19 The-Eagle kernel: ... value mask:             0000ffffffffffff
Oct 30 17:24:19 The-Eagle kernel: ... max period:             00007fffffffffff
Oct 30 17:24:19 The-Eagle kernel: ... fixed-purpose events:   3
Oct 30 17:24:19 The-Eagle kernel: ... event mask:             000000070000000f
Oct 30 17:24:19 The-Eagle kernel: rcu: Hierarchical SRCU implementation.
Oct 30 17:24:19 The-Eagle kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Oct 30 17:24:19 The-Eagle kernel: smp: Bringing up secondary CPUs ...
Oct 30 17:24:19 The-Eagle kernel: x86: Booting SMP configuration:
Oct 30 17:24:19 The-Eagle kernel: .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
Oct 30 17:24:19 The-Eagle kernel: smp: Brought up 1 node, 8 CPUs
Oct 30 17:24:19 The-Eagle kernel: smpboot: Max logical packages: 1
Oct 30 17:24:19 The-Eagle kernel: smpboot: Total of 8 processors activated (32012.80 BogoMIPS)
Oct 30 17:24:19 The-Eagle kernel: devtmpfs: initialized
Oct 30 17:24:19 The-Eagle kernel: x86/mm: Memory block size: 128MB
Oct 30 17:24:19 The-Eagle kernel: PM: Registering ACPI NVS region [mem 0x6fac2000-0x6fca9fff] (1998848 bytes)
Oct 30 17:24:19 The-Eagle kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Oct 30 17:24:19 The-Eagle kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: pinctrl core: initialized pinctrl subsystem
Oct 30 17:24:19 The-Eagle kernel: PM: RTC time: 17:24:17, date: 2020-10-30
Oct 30 17:24:19 The-Eagle kernel: thermal_sys: Registered thermal governor 'fair_share'
Oct 30 17:24:19 The-Eagle kernel: thermal_sys: Registered thermal governor 'bang_bang'
Oct 30 17:24:19 The-Eagle kernel: thermal_sys: Registered thermal governor 'step_wise'
Oct 30 17:24:19 The-Eagle kernel: thermal_sys: Registered thermal governor 'user_space'
Oct 30 17:24:19 The-Eagle kernel: thermal_sys: Registered thermal governor 'power_allocator'
Oct 30 17:24:19 The-Eagle kernel: NET: Registered protocol family 16
Oct 30 17:24:19 The-Eagle kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Oct 30 17:24:19 The-Eagle kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Oct 30 17:24:19 The-Eagle kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Oct 30 17:24:19 The-Eagle kernel: audit: initializing netlink subsys (disabled)
Oct 30 17:24:19 The-Eagle kernel: audit: type=2000 audit(1604078657.046:1): state=initialized audit_enabled=0 res=1
Oct 30 17:24:19 The-Eagle kernel: cpuidle: using governor ladder
Oct 30 17:24:19 The-Eagle kernel: cpuidle: using governor menu
Oct 30 17:24:19 The-Eagle kernel: Simple Boot Flag at 0x47 set to 0x1
Oct 30 17:24:19 The-Eagle kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Oct 30 17:24:19 The-Eagle kernel: ACPI: bus type PCI registered
Oct 30 17:24:19 The-Eagle kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Oct 30 17:24:19 The-Eagle kernel: PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
Oct 30 17:24:19 The-Eagle kernel: PCI: not using MMCONFIG
Oct 30 17:24:19 The-Eagle kernel: PCI: Using configuration type 1 for base access
Oct 30 17:24:19 The-Eagle kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 30 17:24:19 The-Eagle kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Oct 30 17:24:19 The-Eagle kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(Module Device)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(Processor Device)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(Processor Aggregator Device)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(Linux-Dell-Video)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Oct 30 17:24:19 The-Eagle kernel: ACPI: 11 ACPI AML tables successfully acquired and loaded
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: EC started
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: interrupt blocked
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: Boot ECDT EC used to handle transactions
Oct 30 17:24:19 The-Eagle kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Oct 30 17:24:19 The-Eagle kernel: ACPI: Dynamic OEM Table Load:
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2D487000 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DFF4400 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DB69000 00053F (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DB99600 000149 (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DB6C800 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DB6B000 0005FC (v02 PmRef  ApIst    00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DFF7C00 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DFE4000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: SSDT 0xFFFF957D2DFF5000 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Interpreter enabled
Oct 30 17:24:19 The-Eagle kernel: ACPI: (supports S0 S3 S4 S5)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Using IOAPIC for interrupt routing
Oct 30 17:24:19 The-Eagle kernel: PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in ACPI motherboard resources
Oct 30 17:24:19 The-Eagle kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Oct 30 17:24:19 The-Eagle kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [PUBS] (on)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [USBC] (on)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [V0PR] (on)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [V1PR] (on)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [V2PR] (on)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [WRST] (on)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [PIN] (off)
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Resource [PINP] (off)
Oct 30 17:24:19 The-Eagle kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER PCIeCapability]
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0A08:00: _OSC: platform willing to grant [LTR DPC]
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
Oct 30 17:24:19 The-Eagle kernel: PCI host bridge to bus 0000:00
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: root bus resource [mem 0x7d800000-0xefffffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: root bus resource [bus 00-7e]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:00.0: [8086:3e34] type 00 class 0x060000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: [8086:3ea0] type 00 class 0x030000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: reg 0x10: [mem 0xe9000000-0xe9ffffff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: reg 0x20: [io  0x2000-0x203f]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:04.0: reg 0x10: [mem 0xea330000-0xea337fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:08.0: reg 0x10: [mem 0xea342000-0xea342fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:12.0: [8086:9df9] type 00 class 0x118000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:12.0: reg 0x10: [mem 0xea343000-0xea343fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.0: [8086:9ded] type 00 class 0x0c0330
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.0: reg 0x10: [mem 0xea320000-0xea32ffff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.2: [8086:9def] type 00 class 0x050000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.2: reg 0x10: [mem 0xea340000-0xea341fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.2: reg 0x18: [mem 0xea344000-0xea344fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.3: [8086:9df0] type 00 class 0x028000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.3: reg 0x10: [mem 0xea338000-0xea33bfff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:15.0: [8086:9de8] type 00 class 0x0c8000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:15.0: reg 0x10: [mem 0xea345000-0xea345fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:15.1: [8086:9de9] type 00 class 0x0c8000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:15.1: reg 0x10: [mem 0xea346000-0xea346fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:16.0: [8086:9de0] type 00 class 0x078000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:16.0: reg 0x10: [mem 0xea347000-0xea347fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:16.0: PME# supported from D3hot
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1c.0: [8086:9db8] type 01 class 0x060400
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.0: [8086:9db0] type 01 class 0x060400
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4: [8086:9db4] type 01 class 0x060400
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4: PME# supported from D0 D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4: PTM enabled (root), 4ns granularity
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.0: [8086:9d84] type 00 class 0x060100
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.3: [8086:9dc8] type 00 class 0x040380
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xea33c000-0xea33ffff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.3: reg 0x20: [mem 0xea000000-0xea0fffff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.4: [8086:9da3] type 00 class 0x0c0500
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.4: reg 0x10: [mem 0xea348000-0xea3480ff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.5: [8086:9da4] type 00 class 0x0c8000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.6: [8086:15be] type 00 class 0x020000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.6: reg 0x10: [mem 0xea300000-0xea31ffff]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:02:00.0: [8086:7360] type 00 class 0x0d4000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:02:00.0: reg 0x10: [mem 0xea200000-0xea200fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:02:00.0: reg 0x18: [mem 0xea201000-0xea2013ff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1c.0:   bridge window [mem 0xea200000-0xea2fffff]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:03:00.0: [15b7:5006] type 00 class 0x010802
Oct 30 17:24:19 The-Eagle kernel: pci 0000:03:00.0: reg 0x10: [mem 0xea100000-0xea103fff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:03:00.0: reg 0x20: [mem 0xea104000-0xea1040ff 64bit]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.0: PCI bridge to [bus 03]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.0:   bridge window [mem 0xea100000-0xea1fffff]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4: PCI bridge to [bus 05-52]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4:   bridge window [mem 0xd0000000-0xe81fffff]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4:   bridge window [mem 0x80000000-0xbfffffff 64bit pref]
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: interrupt unblocked
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: event unblocked
Oct 30 17:24:19 The-Eagle kernel: ACPI: EC: GPE=0x16
Oct 30 17:24:19 The-Eagle kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot ECDT EC initialization complete
Oct 30 17:24:19 The-Eagle kernel: ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
Oct 30 17:24:19 The-Eagle kernel: iommu: Default domain type: Translated
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=mem,locks=none
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: vgaarb: setting as boot device
Oct 30 17:24:19 The-Eagle kernel: vgaarb: loaded
Oct 30 17:24:19 The-Eagle kernel: SCSI subsystem initialized
Oct 30 17:24:19 The-Eagle kernel: libata version 3.00 loaded.
Oct 30 17:24:19 The-Eagle kernel: ACPI: bus type USB registered
Oct 30 17:24:19 The-Eagle kernel: usbcore: registered new interface driver usbfs
Oct 30 17:24:19 The-Eagle kernel: usbcore: registered new interface driver hub
Oct 30 17:24:19 The-Eagle kernel: usbcore: registered new device driver usb
Oct 30 17:24:19 The-Eagle kernel: pps_core: LinuxPPS API ver. 1 registered
Oct 30 17:24:19 The-Eagle kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Oct 30 17:24:19 The-Eagle kernel: PTP clock support registered
Oct 30 17:24:19 The-Eagle kernel: EDAC MC: Ver: 3.0.0
Oct 30 17:24:19 The-Eagle kernel: Registered efivars operations
Oct 30 17:24:19 The-Eagle kernel: NetLabel: Initializing
Oct 30 17:24:19 The-Eagle kernel: NetLabel:  domain hash size = 128
Oct 30 17:24:19 The-Eagle kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Oct 30 17:24:19 The-Eagle kernel: NetLabel:  unlabeled traffic allowed by default
Oct 30 17:24:19 The-Eagle kernel: PCI: Using ACPI for IRQ routing
Oct 30 17:24:19 The-Eagle kernel: PCI: pci_cache_line_size set to 64 bytes
Oct 30 17:24:19 The-Eagle kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
Oct 30 17:24:19 The-Eagle kernel: e820: reserve RAM buffer [mem 0x66449000-0x67ffffff]
Oct 30 17:24:19 The-Eagle kernel: e820: reserve RAM buffer [mem 0x6b72a000-0x6bffffff]
Oct 30 17:24:19 The-Eagle kernel: e820: reserve RAM buffer [mem 0x6fd10000-0x6fffffff]
Oct 30 17:24:19 The-Eagle kernel: e820: reserve RAM buffer [mem 0x480800000-0x483ffffff]
Oct 30 17:24:19 The-Eagle kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Oct 30 17:24:19 The-Eagle kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
Oct 30 17:24:19 The-Eagle kernel: clocksource: Switched to clocksource tsc-early
Oct 30 17:24:19 The-Eagle kernel: VFS: Disk quotas dquot_6.6.0
Oct 30 17:24:19 The-Eagle kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Oct 30 17:24:19 The-Eagle kernel: AppArmor: AppArmor Filesystem Enabled
Oct 30 17:24:19 The-Eagle kernel: pnp: PnP ACPI init
Oct 30 17:24:19 The-Eagle kernel: system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [io  0x1800-0x18fe] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [mem 0xfd6b0000-0xfd6cffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: [mem 0xff000000-0xffffffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:02: [io  0xff00-0xfffe] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:03: [io  0x0680-0x069f] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:03: [io  0x164e-0x164f] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:04: [io  0x1854-0x1857] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: pnp 00:05: Plug and Play ACPI device, IDs LEN0071 PNP0303 (active)
Oct 30 17:24:19 The-Eagle kernel: pnp 00:06: Plug and Play ACPI device, IDs LEN0300 PNP0f13 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x1800-0x189f] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0800-0x087f] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0880-0x08ff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0900-0x097f] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0980-0x09ff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0a00-0x0a7f] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0a80-0x0aff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0b00-0x0b7f] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x0b80-0x0bff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x15e0-0x15ef] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x1600-0x167f] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [io  0x1640-0x165f] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xf0000000-0xf7ffffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xfed10000-0xfed13fff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xfeb00000-0xfebfffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfed10000-0xfed17fff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xf0000000-0xf7ffffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfed90000-0xfed93fff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000c0000-0x000c3fff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000c8000-0x000cbfff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000d0000-0x000d3fff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000d8000-0x000dbfff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000e0000-0x000e3fff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000e8000-0x000ebfff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x000f0000-0x000fffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0x00100000-0x7d7fffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0xfec00000-0xfed3ffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: [mem 0xfed4c000-0xffffffff] could not be reserved
Oct 30 17:24:19 The-Eagle kernel: system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
Oct 30 17:24:19 The-Eagle kernel: pnp: PnP ACPI: found 11 devices
Oct 30 17:24:19 The-Eagle kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Oct 30 17:24:19 The-Eagle kernel: NET: Registered protocol family 2
Oct 30 17:24:19 The-Eagle kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: TCP: Hash tables configured (established 131072 bind 65536)
Oct 30 17:24:19 The-Eagle kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
Oct 30 17:24:19 The-Eagle kernel: NET: Registered protocol family 44
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4: bridge window [io  0x1000-0x0fff] to [bus 05-52] add_size 1000
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4: BAR 13: assigned [io  0x3000-0x3fff]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:1d.4:   bridge window [io  0x3000-0x3fff]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: resource 7 [mem 0x7d800000-0xefffffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:02: resource 1 [mem 0xea200000-0xea2fffff]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:03: resource 1 [mem 0xea100000-0xea1fffff]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:05: resource 0 [io  0x3000-0x3fff]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:05: resource 1 [mem 0xd0000000-0xe81fffff]
Oct 30 17:24:19 The-Eagle kernel: pci_bus 0000:05: resource 2 [mem 0x80000000-0xbfffffff 64bit pref]
Oct 30 17:24:19 The-Eagle kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Oct 30 17:24:19 The-Eagle kernel: PCI: CLS 0 bytes, default 64
Oct 30 17:24:19 The-Eagle kernel: Trying to unpack rootfs image as initramfs...
Oct 30 17:24:19 The-Eagle kernel: Freeing initrd memory: 12588K
Oct 30 17:24:19 The-Eagle kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Oct 30 17:24:19 The-Eagle kernel: software IO TLB: mapped [mem 0x62449000-0x66449000] (64MB)
Oct 30 17:24:19 The-Eagle kernel: platform rtc_cmos: registered platform RTC device (no PNP device found)
Oct 30 17:24:19 The-Eagle kernel: check: Scanning for low memory corruption every 60 seconds
Oct 30 17:24:19 The-Eagle kernel: Initialise system trusted keyrings
Oct 30 17:24:19 The-Eagle kernel: Key type blacklist registered
Oct 30 17:24:19 The-Eagle kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
Oct 30 17:24:19 The-Eagle kernel: zbud: loaded
Oct 30 17:24:19 The-Eagle kernel: Key type asymmetric registered
Oct 30 17:24:19 The-Eagle kernel: Asymmetric key parser 'x509' registered
Oct 30 17:24:19 The-Eagle kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
Oct 30 17:24:19 The-Eagle kernel: io scheduler mq-deadline registered
Oct 30 17:24:19 The-Eagle kernel: io scheduler kyber registered
Oct 30 17:24:19 The-Eagle kernel: io scheduler bfq registered
Oct 30 17:24:19 The-Eagle kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Oct 30 17:24:19 The-Eagle kernel: efifb: probing for efifb
Oct 30 17:24:19 The-Eagle kernel: efifb: showing boot graphics
Oct 30 17:24:19 The-Eagle kernel: efifb: framebuffer at 0xc0000000, using 32448k, total 32448k
Oct 30 17:24:19 The-Eagle kernel: efifb: mode is 3840x2160x32, linelength=15360, pages=1
Oct 30 17:24:19 The-Eagle kernel: efifb: scrolling: redraw
Oct 30 17:24:19 The-Eagle kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Oct 30 17:24:19 The-Eagle kernel: fbcon: Deferring console take-over
Oct 30 17:24:19 The-Eagle kernel: fb0: EFI VGA frame buffer device
Oct 30 17:24:19 The-Eagle kernel: intel_idle: MWAIT substates: 0x11142120
Oct 30 17:24:19 The-Eagle kernel: intel_idle: v0.5.1 model 0x8E
Oct 30 17:24:19 The-Eagle kernel: intel_idle: Local APIC timer is reliable in all C-states
Oct 30 17:24:19 The-Eagle kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
Oct 30 17:24:19 The-Eagle kernel: ACPI: Sleep Button [SLPB]
Oct 30 17:24:19 The-Eagle kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
Oct 30 17:24:19 The-Eagle kernel: ACPI: Lid Switch [LID]
Oct 30 17:24:19 The-Eagle kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Oct 30 17:24:19 The-Eagle kernel: ACPI: Power Button [PWRF]
Oct 30 17:24:19 The-Eagle kernel: thermal LNXTHERM:00: registered as thermal_zone0
Oct 30 17:24:19 The-Eagle kernel: ACPI: Thermal Zone [THM0] (46 C)
Oct 30 17:24:19 The-Eagle kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Oct 30 17:24:19 The-Eagle kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Oct 30 17:24:19 The-Eagle kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
Oct 30 17:24:19 The-Eagle kernel: nvme nvme0: pci function 0000:03:00.0
Oct 30 17:24:19 The-Eagle kernel: usbcore: registered new interface driver usbserial_generic
Oct 30 17:24:19 The-Eagle kernel: usbserial: USB Serial support registered for generic
Oct 30 17:24:19 The-Eagle kernel: rtc_cmos rtc_cmos: RTC can wake from S4
Oct 30 17:24:19 The-Eagle kernel: rtc_cmos rtc_cmos: registered as rtc0
Oct 30 17:24:19 The-Eagle kernel: rtc_cmos rtc_cmos: setting system clock to 2020-10-30T17:24:18 UTC (1604078658)
Oct 30 17:24:19 The-Eagle kernel: rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
Oct 30 17:24:19 The-Eagle kernel: intel_pstate: Intel P-state driver initializing
Oct 30 17:24:19 The-Eagle kernel: intel_pstate: HWP enabled
Oct 30 17:24:19 The-Eagle kernel: ledtrig-cpu: registered to indicate activity on CPUs
Oct 30 17:24:19 The-Eagle kernel: ashmem: initialized
Oct 30 17:24:19 The-Eagle kernel: intel_pmc_core INT33A1:00:  initialized
Oct 30 17:24:19 The-Eagle kernel: drop_monitor: Initializing network drop monitor service
Oct 30 17:24:19 The-Eagle kernel: NET: Registered protocol family 10
Oct 30 17:24:19 The-Eagle kernel: Segment Routing with IPv6
Oct 30 17:24:19 The-Eagle kernel: RPL Segment Routing with IPv6
Oct 30 17:24:19 The-Eagle kernel: NET: Registered protocol family 17
Oct 30 17:24:19 The-Eagle kernel: microcode: sig=0x806ec, pf=0x80, revision=0xde
Oct 30 17:24:19 The-Eagle kernel: microcode: Microcode Update Driver: v2.2.
Oct 30 17:24:19 The-Eagle kernel: IPI shorthand broadcast: enabled
Oct 30 17:24:19 The-Eagle kernel: sched_clock: Marking stable (840485696, 4346493)->(853204732, -8372543)
Oct 30 17:24:19 The-Eagle kernel: registered taskstats version 1
Oct 30 17:24:19 The-Eagle kernel: Loading compiled-in X.509 certificates
Oct 30 17:24:19 The-Eagle kernel: nvme nvme0: 8/0/0 default/read/poll queues
Oct 30 17:24:19 The-Eagle kernel: Loaded X.509 cert 'Build time autogenerated kernel key: fb74929defd6a8cf1095b0b193c03c2585a8707b'
Oct 30 17:24:19 The-Eagle kernel: zswap: loaded using pool zstd/z3fold
Oct 30 17:24:19 The-Eagle kernel: Key type ._fscrypt registered
Oct 30 17:24:19 The-Eagle kernel: Key type .fscrypt registered
Oct 30 17:24:19 The-Eagle kernel: Key type fscrypt-provisioning registered
Oct 30 17:24:19 The-Eagle kernel: AppArmor: AppArmor sha1 policy hashing enabled
Oct 30 17:24:19 The-Eagle kernel:  nvme0n1: p1 p2 p3
Oct 30 17:24:19 The-Eagle kernel: PM:   Magic number: 8:458:442
Oct 30 17:24:19 The-Eagle kernel: RAS: Correctable Errors collector initialized.
Oct 30 17:24:19 The-Eagle kernel: Freeing unused decrypted memory: 2040K
Oct 30 17:24:19 The-Eagle kernel: Freeing unused kernel image (initmem) memory: 1648K
Oct 30 17:24:19 The-Eagle kernel: Write protecting the kernel read-only data: 22528k
Oct 30 17:24:19 The-Eagle kernel: Freeing unused kernel image (text/rodata gap) memory: 2044K
Oct 30 17:24:19 The-Eagle kernel: Freeing unused kernel image (rodata/data gap) memory: 1480K
Oct 30 17:24:19 The-Eagle kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Oct 30 17:24:19 The-Eagle kernel: Run /init as init process
Oct 30 17:24:19 The-Eagle kernel:   with arguments:
Oct 30 17:24:19 The-Eagle kernel:     /init
Oct 30 17:24:19 The-Eagle kernel:   with environment:
Oct 30 17:24:19 The-Eagle kernel:     HOME=/
Oct 30 17:24:19 The-Eagle kernel:     TERM=linux
Oct 30 17:24:19 The-Eagle kernel:     BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
Oct 30 17:24:19 The-Eagle kernel: i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
Oct 30 17:24:19 The-Eagle kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Oct 30 17:24:19 The-Eagle kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Oct 30 17:24:19 The-Eagle kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Oct 30 17:24:19 The-Eagle kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Oct 30 17:24:19 The-Eagle kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
Oct 30 17:24:19 The-Eagle kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Oct 30 17:24:19 The-Eagle kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
Oct 30 17:24:19 The-Eagle kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 30 17:24:19 The-Eagle kernel: usb usb1: Product: xHCI Host Controller
Oct 30 17:24:19 The-Eagle kernel: usb usb1: Manufacturer: Linux 5.8.16-2-MANJARO xhci-hcd
Oct 30 17:24:19 The-Eagle kernel: usb usb1: SerialNumber: 0000:00:14.0
Oct 30 17:24:19 The-Eagle kernel: hub 1-0:1.0: USB hub found
Oct 30 17:24:19 The-Eagle kernel: hub 1-0:1.0: 12 ports detected
Oct 30 17:24:19 The-Eagle kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Oct 30 17:24:19 The-Eagle kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
Oct 30 17:24:19 The-Eagle kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
Oct 30 17:24:19 The-Eagle kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 30 17:24:19 The-Eagle kernel: usb usb2: Product: xHCI Host Controller
Oct 30 17:24:19 The-Eagle kernel: usb usb2: Manufacturer: Linux 5.8.16-2-MANJARO xhci-hcd
Oct 30 17:24:19 The-Eagle kernel: usb usb2: SerialNumber: 0000:00:14.0
Oct 30 17:24:19 The-Eagle kernel: hub 2-0:1.0: USB hub found
Oct 30 17:24:19 The-Eagle kernel: hub 2-0:1.0: 6 ports detected
Oct 30 17:24:19 The-Eagle kernel: usb: port power management may be unreliable
Oct 30 17:24:19 The-Eagle kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Oct 30 17:24:19 The-Eagle kernel: PM: Image not found (code -22)
Oct 30 17:24:19 The-Eagle kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Oct 30 17:24:19 The-Eagle kernel: random: fast init done
Oct 30 17:24:19 The-Eagle systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLK>
Oct 30 17:24:19 The-Eagle systemd[1]: Detected architecture x86-64.
Oct 30 17:24:19 The-Eagle systemd[1]: Set hostname to <The-Eagle>.
Oct 30 17:24:19 The-Eagle systemd[1]: /usr/lib/systemd/system/gdm.service:28: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the >
Oct 30 17:24:19 The-Eagle systemd[1]: Queued start job for default target Graphical Interface.
Oct 30 17:24:19 The-Eagle systemd[1]: Created slice system-getty.slice.
Oct 30 17:24:19 The-Eagle systemd[1]: Created slice system-modprobe.slice.
Oct 30 17:24:19 The-Eagle systemd[1]: Created slice system-systemd\x2dfsck.slice.
Oct 30 17:24:19 The-Eagle systemd[1]: Created slice User and Session Slice.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Oct 30 17:24:19 The-Eagle systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Local Encrypted Volumes.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Login Prompts.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Remote File Systems.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Slices.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on Device-mapper event daemon FIFOs.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on LVM2 metadata daemon socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on LVM2 poll daemon socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on Process Core Dump Socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on Journal Audit Socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on Journal Socket (/dev/log).
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on Journal Socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on udev Control Socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on udev Kernel Socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting Huge Pages File System...
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting POSIX Message Queue File System...
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting Kernel Debug File System...
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting Kernel Trace File System...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Load AppArmor profiles...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Create list of static device nodes for the current kernel...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Load Kernel Module drm...
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Journal Service...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Load Kernel Modules...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Remount Root and Kernel File Systems...
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Coldplug All udev Devices...
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted Huge Pages File System.
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted POSIX Message Queue File System.
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted Kernel Debug File System.
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted Kernel Trace File System.
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Create list of static device nodes for the current kernel.
Oct 30 17:24:19 The-Eagle kernel: Linux agpgart interface v0.103
Oct 30 17:24:19 The-Eagle kernel: random: lvm: uninitialized urandom read (4 bytes read)
Oct 30 17:24:19 The-Eagle kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Load Kernel Modules.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in FUSE Control File System being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting Kernel Configuration File System...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Apply Kernel Variables...
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Remount Root and Kernel File Systems.
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted Kernel Configuration File System.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Load/Save Random Seed...
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Create System Users being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Create Static Device Nodes in /dev...
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Apply Kernel Variables.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting CLI Netfilter Manager...
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Create Static Device Nodes in /dev.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Rule-based Manager for Device Events and Files...
Oct 30 17:24:19 The-Eagle kernel: usb 1-8: new high-speed USB device number 2 using xhci_hcd
Oct 30 17:24:19 The-Eagle systemd[1]: Finished CLI Netfilter Manager.
Oct 30 17:24:19 The-Eagle systemd[1]: modprobe@drm.service: Succeeded.
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Load Kernel Module drm.
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Coldplug All udev Devices.
Oct 30 17:24:19 The-Eagle kernel: audit: type=1400 audit(1604078659.020:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=286 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle kernel: audit: type=1400 audit(1604078659.060:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=294 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle kernel: audit: type=1400 audit(1604078659.060:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=294 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle kernel: usb 1-8: New USB device found, idVendor=04f2, idProduct=b67c, bcdDevice=67.26
Oct 30 17:24:19 The-Eagle kernel: usb 1-8: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Oct 30 17:24:19 The-Eagle kernel: usb 1-8: Product: Integrated Camera
Oct 30 17:24:19 The-Eagle kernel: usb 1-8: Manufacturer: Chicony Electronics Co.,Ltd.
Oct 30 17:24:19 The-Eagle kernel: usb 1-8: SerialNumber: 6726
Oct 30 17:24:19 The-Eagle systemd-journald[244]: Journal started
Oct 30 17:24:19 The-Eagle systemd-journald[244]: Runtime Journal (/run/log/journal/96fdb7c573bf482d9bc07738e7c4fb0f) is 8.0M, max 784.5M, 776.5M free.
Oct 30 17:24:19 The-Eagle audit[286]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=286 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle audit[294]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=294 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle audit[294]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=294 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle systemd-modules-load[245]: Inserted module 'crypto_user'
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
Oct 30 17:24:19 The-Eagle systemd-sysctl[255]: Not setting net/ipv4/conf/all/rp_filter (explicit setting exists).
Oct 30 17:24:19 The-Eagle systemd-sysctl[255]: Not setting net/ipv4/conf/default/rp_filter (explicit setting exists).
Oct 30 17:24:19 The-Eagle systemd-sysctl[255]: Not setting net/ipv4/conf/all/accept_source_route (explicit setting exists).
Oct 30 17:24:19 The-Eagle systemd-sysctl[255]: Not setting net/ipv4/conf/default/accept_source_route (explicit setting exists).
Oct 30 17:24:19 The-Eagle apparmor.systemd[240]: Restarting AppArmor
Oct 30 17:24:19 The-Eagle apparmor.systemd[240]: Reloading AppArmor profiles
Oct 30 17:24:19 The-Eagle systemd[1]: Started Journal Service.
Oct 30 17:24:19 The-Eagle kernel: audit: type=1130 audit(1604078659.170:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" h>
Oct 30 17:24:19 The-Eagle systemd-sysctl[255]: Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
Oct 30 17:24:19 The-Eagle systemd-sysctl[255]: Not setting net/ipv4/conf/default/promote_secondaries (explicit setting exists).
Oct 30 17:24:19 The-Eagle systemd-random-seed[257]: Kernel entropy pool is not initialized yet, waiting until it is.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Flush Journal to Persistent Storage...
Oct 30 17:24:19 The-Eagle ufw-init[273]: Skip starting firewall: ufw (not enabled)
Oct 30 17:24:19 The-Eagle systemd-journald[244]: Time spent on flushing to /var/log/journal/96fdb7c573bf482d9bc07738e7c4fb0f is 63.433ms for 743 entries.
Oct 30 17:24:19 The-Eagle systemd-journald[244]: System Journal (/var/log/journal/96fdb7c573bf482d9bc07738e7c4fb0f) is 40.0M, max 4.0G, 3.9G free.
Oct 30 17:24:19 The-Eagle kernel: audit: type=1130 audit(1604078659.223:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" host>
Oct 30 17:24:19 The-Eagle kernel: audit: type=1130 audit(1604078659.223:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostn>
Oct 30 17:24:19 The-Eagle kernel: audit: type=1400 audit(1604078659.240:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=304 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle kernel: audit: type=1400 audit(1604078659.240:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid>
Oct 30 17:24:19 The-Eagle kernel: audit: type=1130 audit(1604078659.243:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname>
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? r>
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? re>
Oct 30 17:24:19 The-Eagle audit[304]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=304 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle audit[304]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=304 comm="apparmor_parser"
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
Oct 30 17:24:19 The-Eagle systemd[1]: Started Rule-based Manager for Device Events and Files.
Oct 30 17:24:19 The-Eagle systemd[1]: Started LVM2 metadata daemon.
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Load AppArmor profiles.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Flush Journal to Persistent Storage.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? term>
Oct 30 17:24:19 The-Eagle snapd-apparmor[346]: find: ‘/var/lib/snapd/apparmor/profiles/’: No such file or directory
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd.apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
Oct 30 17:24:19 The-Eagle kernel: usb 1-9: new full-speed USB device number 3 using xhci_hcd
Oct 30 17:24:19 The-Eagle kernel: hid: raw HID events driver (C) Jiri Kosina
Oct 30 17:24:19 The-Eagle kernel: ACPI: AC Adapter [AC] (off-line)
Oct 30 17:24:19 The-Eagle kernel: Non-volatile memory driver v1.3
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 30 17:24:19 The-Eagle kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 30 17:24:19 The-Eagle kernel: battery: ACPI: Battery Slot [BAT0] (battery present)
Oct 30 17:24:19 The-Eagle kernel: random: mktemp: uninitialized urandom read (6 bytes read)
Oct 30 17:24:19 The-Eagle kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Oct 30 17:24:19 The-Eagle kernel: usb 1-9: New USB device found, idVendor=06cb, idProduct=00bd, bcdDevice= 0.00
Oct 30 17:24:19 The-Eagle kernel: usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Oct 30 17:24:19 The-Eagle kernel: usb 1-9: SerialNumber: 56beefeafca5
Oct 30 17:24:19 The-Eagle kernel: nfc: nfc_init: NFC Core ver 0.1
Oct 30 17:24:19 The-Eagle kernel: NET: Registered protocol family 39
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: ThinkPad ACPI Extras v0.26
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: http://ibm-acpi.sf.net/
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: ThinkPad BIOS N2HET57W (1.40 ), EC N2HHT37W
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: Lenovo ThinkPad X1 Carbon 7th, model 20QD00KWUK
Oct 30 17:24:19 The-Eagle kernel: intel_pch_thermal 0000:00:12.0: enabling device (0000 -> 0002)
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: radio switch found; radios are enabled
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: Tablet mode switch found (type: GMMS), currently in laptop mode
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
Oct 30 17:24:19 The-Eagle kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: rfkill switch tpacpi_wwan_sw: radio is blocked
Oct 30 17:24:19 The-Eagle kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Oct 30 17:24:19 The-Eagle kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
Oct 30 17:24:19 The-Eagle kernel: intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
Oct 30 17:24:19 The-Eagle kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
Oct 30 17:24:19 The-Eagle kernel: tsc: Refined TSC clocksource calibration: 1992.022 MHz
Oct 30 17:24:19 The-Eagle kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x396d7b766dc, max_idle_ns: 881590497494 ns
Oct 30 17:24:19 The-Eagle kernel: intel_rapl_common: Found RAPL domain package
Oct 30 17:24:19 The-Eagle kernel: intel_rapl_common: Found RAPL domain dram
Oct 30 17:24:19 The-Eagle kernel: proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
Oct 30 17:24:19 The-Eagle kernel: thinkpad_acpi: battery 1 registered (start 0, stop 100)
Oct 30 17:24:19 The-Eagle kernel: battery: new extension: ThinkPad Battery Extension
Oct 30 17:24:19 The-Eagle kernel: input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input5
Oct 30 17:24:19 The-Eagle kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
Oct 30 17:24:19 The-Eagle kernel: i2c_hid i2c-SYNA8005:00: supply vdd not found, using dummy regulator
Oct 30 17:24:19 The-Eagle kernel: i2c_hid i2c-SYNA8005:00: supply vddl not found, using dummy regulator
Oct 30 17:24:19 The-Eagle kernel: tpm_tis STM7364:00: 2.0 TPM (device-id 0x0, rev-id 78)
Oct 30 17:24:19 The-Eagle kernel: Intel(R) Wireless WiFi driver for Linux
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Oct 30 17:24:19 The-Eagle kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: Found debug configuration: 0
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: loaded firmware version 46.8902351f.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Oct 30 17:24:19 The-Eagle systemd[1]: Found device WDC PC SN730 SDBQNTY-512G-1001 1.
Oct 30 17:24:19 The-Eagle systemd[1]: Found device WDC PC SN730 SDBQNTY-512G-1001 3.
Oct 30 17:24:19 The-Eagle systemd[1]: Activating swap /dev/disk/by-uuid/0f2cb022-2ae2-4af5-878a-1a92ba18dbf1...
Oct 30 17:24:19 The-Eagle kernel: usb 1-10: new full-speed USB device number 4 using xhci_hcd
Oct 30 17:24:19 The-Eagle systemd[1]: Activated swap /dev/disk/by-uuid/0f2cb022-2ae2-4af5-878a-1a92ba18dbf1.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Swap.
Oct 30 17:24:19 The-Eagle kernel: Adding 17674640k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:17674640k SSFS
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting Temporary Directory (/tmp)...
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted Temporary Directory (/tmp).
Oct 30 17:24:19 The-Eagle kernel: input: PC Speaker as /devices/platform/pcspkr/input/input6
Oct 30 17:24:19 The-Eagle kernel: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Oct 30 17:24:19 The-Eagle kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Oct 30 17:24:19 The-Eagle kernel: e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Oct 30 17:24:19 The-Eagle kernel: i2c i2c-2: 2/2 memory slots populated (from DMI)
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? re>
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Local File Systems (Pre).
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting File System Check on /dev/disk/by-uuid/6847-7A29...
Oct 30 17:24:19 The-Eagle kernel: usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
Oct 30 17:24:19 The-Eagle kernel: usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Oct 30 17:24:19 The-Eagle systemd-fsck[399]: fsck.fat 4.1 (2017-01-24)
Oct 30 17:24:19 The-Eagle systemd-fsck[399]: /dev/nvme0n1p1: 6 files, 78/76646 clusters
Oct 30 17:24:19 The-Eagle systemd[1]: Finished File System Check on /dev/disk/by-uuid/6847-7A29.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-6847\x2d7A29 comm="systemd" exe="/usr/lib/systemd/systemd>
Oct 30 17:24:19 The-Eagle systemd[1]: Mounting /boot/efi...
Oct 30 17:24:19 The-Eagle kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:07 [mem 0xfed10000-0xfed13fff]
Oct 30 17:24:19 The-Eagle kernel: caller snb_uncore_imc_init_box+0x74/0xb0 [intel_uncore] mapping multiple BARs
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560, REV=0x318
Oct 30 17:24:19 The-Eagle kernel: RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
Oct 30 17:24:19 The-Eagle kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Oct 30 17:24:19 The-Eagle kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Oct 30 17:24:19 The-Eagle kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
Oct 30 17:24:19 The-Eagle kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Oct 30 17:24:19 The-Eagle kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
Oct 30 17:24:19 The-Eagle kernel: snd_hda_intel 0000:00:1f.3: dmic_detect option is deprecated, pass snd-intel-dspcfg.dsp_driver=1 option instead
Oct 30 17:24:19 The-Eagle kernel: cryptd: max_cpu_qlen set to 1000
Oct 30 17:24:19 The-Eagle kernel: iwlwifi 0000:00:14.3: base HW address: 04:33:c2:2d:79:22
Oct 30 17:24:19 The-Eagle kernel: AVX2 version of gcm_enc/dec engaged.
Oct 30 17:24:19 The-Eagle kernel: AES CTR mode by8 optimization enabled
Oct 30 17:24:19 The-Eagle systemd[1]: Mounted /boot/efi.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Local File Systems.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Create Volatile Files and Directories...
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: Timeout waiting for interrupt!
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: Transaction timeout
Oct 30 17:24:19 The-Eagle kernel: i915 0000:00:02.0: enabling device (0006 -> 0007)
Oct 30 17:24:19 The-Eagle kernel: checking generic (c0000000 1fb0000) vs hw (e9000000 1000000)
Oct 30 17:24:19 The-Eagle kernel: checking generic (c0000000 1fb0000) vs hw (c0000000 10000000)
Oct 30 17:24:19 The-Eagle kernel: fb0: switching to inteldrmfb from EFI VGA
Oct 30 17:24:19 The-Eagle kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: Failed terminating the transaction
Oct 30 17:24:19 The-Eagle kernel: i801_smbus 0000:00:1f.4: SMBus is busy, can't use it!
Oct 30 17:24:19 The-Eagle kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Oct 30 17:24:19 The-Eagle kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=mem
Oct 30 17:24:19 The-Eagle kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? ter>
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Create Volatile Files and Directories.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Condition check resulted in Update is Completed being skipped.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Oct 30 17:24:19 The-Eagle kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
Oct 30 17:24:19 The-Eagle kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
Oct 30 17:24:19 The-Eagle audit[442]: SYSTEM_BOOT pid=442 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? term>
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Update UTMP about System Boot/Shutdown.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termin>
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target System Initialization.
Oct 30 17:24:19 The-Eagle systemd[1]: Started CUPS Scheduler.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Daily rotation of log files.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Daily man-db regeneration.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Monthly clean packages cache.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Generate mirrorlist weekly.
Oct 30 17:24:19 The-Eagle systemd[1]: Started pkgfile database update timer.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Daily verification of password and group files.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Daily Cleanup of Temporary Directories.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Paths.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Timers.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on D-Bus System Message Bus Socket.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on CUPS Scheduler.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Socket activation for snappy daemon.
Oct 30 17:24:19 The-Eagle systemd[1]: Listening on Socket activation for snappy daemon.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Sockets.
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Basic System.
Oct 30 17:24:19 The-Eagle systemd[1]: Started Periodic Command Scheduler.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ>
Oct 30 17:24:19 The-Eagle systemd[1]: Started D-Bus System Message Bus.
Oct 30 17:24:19 The-Eagle crond[444]: (CRON) STARTUP (1.5.5)
Oct 30 17:24:19 The-Eagle crond[444]: (CRON) INFO (Syslog will be used instead of sendmail.)
Oct 30 17:24:19 The-Eagle crond[444]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 60% if used.)
Oct 30 17:24:19 The-Eagle crond[444]: (CRON) INFO (running with inotify support)
Oct 30 17:24:19 The-Eagle CROND[447]: (root) CMD (sleep 10m && timeshift --create --scripted --tags B)
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes>
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Network Manager...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Clean up modules from old kernels...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Authorization Manager...
Oct 30 17:24:19 The-Eagle audit: BPF prog-id=7 op=LOAD
Oct 30 17:24:19 The-Eagle audit: BPF prog-id=8 op=LOAD
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Snap Daemon...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting User Login Management...
Oct 30 17:24:19 The-Eagle linux-module-cleanup[454]: cat: /usr/lib/modules/.old: No such file or directory
Oct 30 17:24:19 The-Eagle kernel: [drm] Initialized i915 1.6.0 20200515 for 0000:00:02.0 on minor 0
Oct 30 17:24:19 The-Eagle systemd[1]: linux-module-cleanup.service: Succeeded.
Oct 30 17:24:19 The-Eagle systemd[1]: Finished Clean up modules from old kernels.
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termin>
Oct 30 17:24:19 The-Eagle kernel: e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
Oct 30 17:24:19 The-Eagle kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Oct 30 17:24:19 The-Eagle kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
Oct 30 17:24:19 The-Eagle kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Oct 30 17:24:19 The-Eagle polkitd[452]: Started polkitd version 0.117
Oct 30 17:24:19 The-Eagle kernel: fbcon: i915drmfb (fb0) is primary device
Oct 30 17:24:19 The-Eagle kernel: i915 0000:00:02.0: fb0: i915drmfb frame buffer device
Oct 30 17:24:19 The-Eagle NetworkManager[448]: <info>  [1604078659.9809] NetworkManager (version 1.26.2-1) is starting... (for the first time)
Oct 30 17:24:19 The-Eagle NetworkManager[448]: <info>  [1604078659.9811] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Oct 30 17:24:19 The-Eagle systemd[1]: Started Network Manager.
Oct 30 17:24:19 The-Eagle NetworkManager[448]: <info>  [1604078659.9873] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Oct 30 17:24:19 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
Oct 30 17:24:19 The-Eagle systemd[1]: Reached target Network.
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Network Manager Wait Online...
Oct 30 17:24:19 The-Eagle systemd[1]: Starting Permit User Sessions...
Oct 30 17:24:19 The-Eagle NetworkManager[448]: <info>  [1604078659.9948] manager[0x563f73fbd0c0]: monitoring kernel firmware directory '/lib/firmware'.
Oct 30 17:24:20 The-Eagle snapd[453]: AppArmor status: apparmor is enabled and all features are available
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.2' (uid=0 pid=448 comm="/usr/>
Oct 30 17:24:20 The-Eagle audit: BPF prog-id=9 op=LOAD
Oct 30 17:24:20 The-Eagle audit: BPF prog-id=10 op=LOAD
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? term>
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Hostname Service...
Oct 30 17:24:20 The-Eagle systemd[1]: Finished Permit User Sessions.
Oct 30 17:24:20 The-Eagle systemd[1]: Starting GNOME Display Manager...
Oct 30 17:24:20 The-Eagle polkitd[452]: Loading rules from directory /etc/polkit-1/rules.d
Oct 30 17:24:20 The-Eagle polkitd[452]: Loading rules from directory /usr/share/polkit-1/rules.d
Oct 30 17:24:20 The-Eagle polkitd[452]: Finished loading, compiling and executing 7 rules
Oct 30 17:24:20 The-Eagle systemd[1]: Started Authorization Manager.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ>
Oct 30 17:24:20 The-Eagle kernel: e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) f8:75:a4:e9:15:24
Oct 30 17:24:20 The-Eagle kernel: e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
Oct 30 17:24:20 The-Eagle kernel: e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Modem Manager...
Oct 30 17:24:20 The-Eagle polkitd[452]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Oct 30 17:24:20 The-Eagle snapd[453]: daemon.go:343: started snapd/2.46-1 (series 16; classic) manjaro/ (amd64) linux/5.8.16-2-MANJARO.
Oct 30 17:24:20 The-Eagle ModemManager[499]: <info>  ModemManager (version 1.14.2) starting in system bus...
Oct 30 17:24:20 The-Eagle kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC285: line_outs=2 (0x14/0x17/0x0/0x0/0x0) type:speaker
Oct 30 17:24:20 The-Eagle kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Oct 30 17:24:20 The-Eagle kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Oct 30 17:24:20 The-Eagle kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
Oct 30 17:24:20 The-Eagle kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
Oct 30 17:24:20 The-Eagle kernel: snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
Oct 30 17:24:20 The-Eagle systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Load/Save RF Kill Switch Status...
Oct 30 17:24:20 The-Eagle kernel: psmouse serio1: trackpoint: Elan TrackPoint firmware: 0x47, buttons: 3/3
Oct 30 17:24:20 The-Eagle kernel: random: crng init done
Oct 30 17:24:20 The-Eagle kernel: random: 7 urandom warning(s) missed due to ratelimiting
Oct 30 17:24:20 The-Eagle systemd[1]: Finished Load/Save Random Seed.
Oct 30 17:24:20 The-Eagle systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termin>
Oct 30 17:24:20 The-Eagle kernel: input: TPPS/2 Elan TrackPoint as /devices/platform/i8042/serio1/input/input7
Oct 30 17:24:20 The-Eagle systemd[1]: Started Modem Manager.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? re>
Oct 30 17:24:20 The-Eagle systemd[1]: Created slice system-systemd\x2dbacklight.slice.
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight...
Oct 30 17:24:20 The-Eagle systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@leds:tpacpi::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd">
Oct 30 17:24:20 The-Eagle kernel: intel_rapl_common: Found RAPL domain package
Oct 30 17:24:20 The-Eagle kernel: intel_rapl_common: Found RAPL domain core
Oct 30 17:24:20 The-Eagle kernel: intel_rapl_common: Found RAPL domain uncore
Oct 30 17:24:20 The-Eagle kernel: intel_rapl_common: Found RAPL domain dram
Oct 30 17:24:20 The-Eagle systemd[1]: Started Load/Save RF Kill Switch Status.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
Oct 30 17:24:20 The-Eagle kernel: iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
Oct 30 17:24:20 The-Eagle kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Oct 30 17:24:20 The-Eagle kernel: iTCO_vendor_support: vendor-support=0
Oct 30 17:24:20 The-Eagle kernel: input: SYNA8005:00 06CB:CD8C Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA8005:00/0018:06CB:CD8C.0001/input/input18
Oct 30 17:24:20 The-Eagle kernel: input: SYNA8005:00 06CB:CD8C Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA8005:00/0018:06CB:CD8C.0001/input/input19
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH Headset Jack as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
Oct 30 17:24:20 The-Eagle kernel: input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
Oct 30 17:24:20 The-Eagle kernel: input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
Oct 30 17:24:20 The-Eagle kernel: hid-generic 0018:06CB:CD8C.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA8005:00 06CB:CD8C] on i2c-SYNA8005:00
Oct 30 17:24:20 The-Eagle systemd[1]: Started GNOME Display Manager.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 30 17:24:20 The-Eagle kernel: e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.login1.service' requested by ':1.5' (uid=0 pid=537 comm="/usr/bin/gd>
Oct 30 17:24:20 The-Eagle systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
Oct 30 17:24:20 The-Eagle mtp-probe[556]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8"
Oct 30 17:24:20 The-Eagle mtp-probe[558]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9"
Oct 30 17:24:20 The-Eagle mtp-probe[556]: bus: 1, device: 2 was not an MTP device
Oct 30 17:24:20 The-Eagle mtp-probe[558]: bus: 1, device: 3 was not an MTP device
Oct 30 17:24:20 The-Eagle kernel: loop: module loaded
Oct 30 17:24:20 The-Eagle kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
Oct 30 17:24:20 The-Eagle kernel: iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
Oct 30 17:24:20 The-Eagle kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Oct 30 17:24:20 The-Eagle kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Oct 30 17:24:20 The-Eagle systemd[1]: tmp-sanity\x2dmountpoint\x2d178716792.mount: Succeeded.
Oct 30 17:24:20 The-Eagle systemd[1]: Condition check resulted in Save/Restore Sound Card State being skipped.
Oct 30 17:24:20 The-Eagle systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Oct 30 17:24:20 The-Eagle systemd[1]: Reached target Sound Card.
Oct 30 17:24:20 The-Eagle snapd[453]: daemon.go:436: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Oct 30 17:24:20 The-Eagle kernel: mousedev: PS/2 mouse device common for all mice
Oct 30 17:24:20 The-Eagle kernel: input: SYNA8005:00 06CB:CD8C Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA8005:00/0018:06CB:CD8C.0001/input/input21
Oct 30 17:24:20 The-Eagle kernel: input: SYNA8005:00 06CB:CD8C Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA8005:00/0018:06CB:CD8C.0001/input/input22
Oct 30 17:24:20 The-Eagle kernel: hid-multitouch 0018:06CB:CD8C.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA8005:00 06CB:CD8C] on i2c-SYNA8005:00
Oct 30 17:24:20 The-Eagle systemd[1]: Started Snap Daemon.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succe>
Oct 30 17:24:20 The-Eagle systemd-logind[455]: New seat seat0.
Oct 30 17:24:20 The-Eagle systemd-logind[455]: Watching system buttons on /dev/input/event2 (Power Button)
Oct 30 17:24:20 The-Eagle systemd-logind[455]: Watching system buttons on /dev/input/event1 (Lid Switch)
Oct 30 17:24:20 The-Eagle systemd-logind[455]: Watching system buttons on /dev/input/event0 (Sleep Button)
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Successfully activated service 'org.freedesktop.hostname1'
Oct 30 17:24:20 The-Eagle systemd[1]: Started Hostname Service.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal>
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5307] hostname: hostname: using hostnamed
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5312] hostname: hostname changed from (none) to "The-Eagle"
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5317] dns-mgr[0x563f73fa2220]: init: dns=default,systemd-resolved rc-manager=symlink
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5332] rfkill3: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill3) (driver iwlwifi)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5335] rfkill1: found WWAN radio killswitch (at /sys/devices/platform/thinkpad_acpi/rfkill/rfkill1) (platform driver thinkpad_acpi)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5338] manager[0x563f73fbd0c0]: rfkill: Wi-Fi hardware radio set enabled
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5347] manager[0x563f73fbd0c0]: rfkill: WWAN hardware radio set enabled
Oct 30 17:24:20 The-Eagle snapd[453]: stateengine.go:150: state ensure error: Get "https://api.snapcraft.io/api/v1/snaps/sections": dial tcp: lookup api.snapcraft.io: no such host
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5472] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.26.2-1/libnm-device-plugin-bluetooth.so)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5484] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.26.2-1/libnm-device-plugin-adsl.so)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5498] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.26.2-1/libnm-device-plugin-wifi.so)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5502] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.26.2-1/libnm-device-plugin-wwan.so)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5683] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.26.2-1/libnm-device-plugin-team.so)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5691] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.26.2-1/libnm-device-plugin-ovs.so)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5695] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5696] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5697] manager: Networking is enabled by state file
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5701] dhcp-init: Using DHCP client 'internal'
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=448 com>
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5707] settings: Loaded settings plugin: keyfile (internal)
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5734] device (lo): carrier: link connected
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5737] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5746] manager: (enp0s31f6): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5752] device (wlp0s20f3): driver supports Access Point (AP) mode
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5757] manager: (wlp0s20f3): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 30 17:24:20 The-Eagle systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? >
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5797] ovsdb: Could not connect: No such file or directory
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.5807] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 17:24:20 The-Eagle NetworkManager[448]: <info>  [1604078660.8156] device (wlp0s20f3): set-hw-addr: set MAC address to 76:5E:F9:F4:B1:6D (scanning)
Oct 30 17:24:20 The-Eagle systemd-logind[455]: Watching system buttons on /dev/input/event3 (AT Translated Set 2 keyboard)
Oct 30 17:24:20 The-Eagle systemd-logind[455]: Watching system buttons on /dev/input/event4 (ThinkPad Extra Buttons)
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Successfully activated service 'org.freedesktop.login1'
Oct 30 17:24:20 The-Eagle systemd[1]: Started User Login Management.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
Oct 30 17:24:20 The-Eagle systemd[1]: Reached target Multi-User System.
Oct 30 17:24:20 The-Eagle systemd[1]: Reached target Graphical Interface.
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.5' (uid=0 pid=537 comm="/usr/bin/gdm " label=>
Oct 30 17:24:20 The-Eagle systemd[1]: Starting TLP system startup/shutdown...
Oct 30 17:24:20 The-Eagle systemd[1]: Reached target User and Group Name Lookups.
Oct 30 17:24:20 The-Eagle systemd[1]: Starting Accounts Service...
Oct 30 17:24:20 The-Eagle accounts-daemon[808]: started daemon version 0.6.55
Oct 30 17:24:20 The-Eagle dbus-daemon[445]: [system] Successfully activated service 'org.freedesktop.Accounts'
Oct 30 17:24:20 The-Eagle systemd[1]: Started Accounts Service.
Oct 30 17:24:20 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
Oct 30 17:24:20 The-Eagle mtp-probe[835]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9"
Oct 30 17:24:20 The-Eagle mtp-probe[835]: bus: 1, device: 3 was not an MTP device
Oct 30 17:24:20 The-Eagle kernel: mc: Linux media interface: v0.10
Oct 30 17:24:20 The-Eagle audit[836]: USER_AUTH pid=836 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-w>
Oct 30 17:24:20 The-Eagle audit[836]: USER_ACCT pid=836 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worke>
Oct 30 17:24:20 The-Eagle audit[836]: CRED_ACQ pid=836 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=The-Eag>
Oct 30 17:24:21 The-Eagle dbus-daemon[445]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.2' (uid=0 pid=448 comm="/usr/bin/NetworkManager ->
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.0214] device (enp0s31f6): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 17:24:21 The-Eagle systemd[1]: Starting WPA supplicant...
Oct 30 17:24:21 The-Eagle kernel: videodev: Linux video capture interface: v2.00
Oct 30 17:24:21 The-Eagle dbus-daemon[445]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Oct 30 17:24:21 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: Successfully initialized wpa_supplicant
Oct 30 17:24:21 The-Eagle systemd[1]: Started WPA supplicant.
Oct 30 17:24:21 The-Eagle kernel: uvcvideo: Found UVC 1.50 device Integrated Camera (04f2:b67c)
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.0: Entity type for entity Realtek Extended Controls Unit was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.0: Entity type for entity Extension 4 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.0: Entity type for entity Processing 2 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.0: Entity type for entity Camera 1 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input24
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.2: Entity type for entity Realtek Extended Controls Unit was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.2: Entity type for entity Microsoft Extended Controls Uni was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.2: Entity type for entity Extension 9 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.2: Entity type for entity Extension 11 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.2: Entity type for entity Processing 15 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: Core ver 2.22
Oct 30 17:24:21 The-Eagle kernel: uvcvideo 1-8:1.2: Entity type for entity Camera 8 was not initialized!
Oct 30 17:24:21 The-Eagle kernel: NET: Registered protocol family 31
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: HCI device and connection manager initialized
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: HCI socket layer initialized
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: L2CAP socket layer initialized
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: SCO socket layer initialized
Oct 30 17:24:21 The-Eagle kernel: input: Integrated Camera: Integrated I as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.2/input/input25
Oct 30 17:24:21 The-Eagle kernel: usbcore: registered new interface driver uvcvideo
Oct 30 17:24:21 The-Eagle kernel: USB Video Class driver (1.1.1)
Oct 30 17:24:21 The-Eagle systemd[1]: Created slice User Slice of UID 120.
Oct 30 17:24:21 The-Eagle mtp-probe[859]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8"
Oct 30 17:24:21 The-Eagle mtp-probe[859]: bus: 1, device: 2 was not an MTP device
Oct 30 17:24:21 The-Eagle systemd[1]: Starting User Runtime Directory /run/user/120...
Oct 30 17:24:21 The-Eagle systemd-logind[455]: New session 1 of user gdm.
Oct 30 17:24:21 The-Eagle systemd[1]: Finished User Runtime Directory /run/user/120.
Oct 30 17:24:21 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
Oct 30 17:24:21 The-Eagle systemd[1]: Starting User Manager for UID 120...
Oct 30 17:24:21 The-Eagle kernel: usbcore: registered new interface driver btusb
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: Device revision is 2
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: Secure boot is enabled
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: OTP lock is enabled
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: API lock is enabled
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: Debug lock is disabled
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
Oct 30 17:24:21 The-Eagle dbus-daemon[445]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.15' (uid=0 pid=870 comm="(systemd) " >
Oct 30 17:24:21 The-Eagle dbus-daemon[445]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 30 17:24:21 The-Eagle systemd[870]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 30 17:24:21 The-Eagle audit[870]: USER_ACCT pid=870 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/syst>
Oct 30 17:24:21 The-Eagle audit[870]: CRED_ACQ pid=870 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
Oct 30 17:24:21 The-Eagle systemd[870]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
Oct 30 17:24:21 The-Eagle systemd[1]: Starting Bluetooth service...
Oct 30 17:24:21 The-Eagle systemd[870]: pam_unix(systemd-user:session): session opened for user gdm(uid=120) by (uid=0)
Oct 30 17:24:21 The-Eagle audit[870]: USER_START pid=870 uid=0 auid=120 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam>
Oct 30 17:24:21 The-Eagle audit: BPF prog-id=11 op=LOAD
Oct 30 17:24:21 The-Eagle audit: BPF prog-id=11 op=UNLOAD
Oct 30 17:24:21 The-Eagle bluetoothd[879]: Bluetooth daemon 5.55
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “BRMaxSniffInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEMinAdvertisementInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEMaxAdvertisementInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEMultiAdvertisementRotationInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAutoConnect” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAutoConnect” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalSuspend” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowSuspend” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalDiscovery” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowDiscovery” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAdvMonitor” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAdvMonitor” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Oct 30 17:24:21 The-Eagle bluetoothd[879]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Oct 30 17:24:21 The-Eagle systemd[1]: Started Bluetooth service.
Oct 30 17:24:21 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=s>
Oct 30 17:24:21 The-Eagle systemd[1]: Reached target Bluetooth.
Oct 30 17:24:21 The-Eagle bluetoothd[879]: Starting SDP server
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: BNEP filters: protocol multicast
Oct 30 17:24:21 The-Eagle kernel: Bluetooth: BNEP socket layer initialized
Oct 30 17:24:21 The-Eagle bluetoothd[879]: Bluetooth management interface 1.17 initialized
Oct 30 17:24:21 The-Eagle systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Oct 30 17:24:21 The-Eagle audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" >
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2154] settings: (enp0s31f6): created default wired connection 'Wired connection 1'
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2180] modem-manager: ModemManager available
Oct 30 17:24:21 The-Eagle systemd[908]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Sound-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Rfkill-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.MediaKeys-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Datetime-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.PrintNotifications-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Wwan-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Wacom-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dsecrets-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Keyboard-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-xapp\x2dsn\x2dwatcher-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.A11ySettings-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Power-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.XSettings-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.UsbProtection-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.ScreensaverProxy-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-at\x2dspi\x2ddbus\x2dbus-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Smartcard-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dpkcs11-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dssh-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Color-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Sharing-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-pulseaudio-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle systemd[908]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Housekeeping-autostart.service, startup phases are not supported.
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: nl80211: kernel reports: Attribute failed policy validation
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: P2P: Failed to enable P2P Device interface
Oct 30 17:24:21 The-Eagle wpa_supplicant[845]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2671] device (wlp0s20f3): supplicant interface state: internal-starting -> disconnected
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2672] Wi-Fi P2P device controlled by interface wlp0s20f3 created
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2675] manager: (p2p-dev-wlp0s20f3): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2681] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <warn>  [1604078661.2695] sup-iface[7063c886db468b98,0,wlp0s20f3]: call-p2p-cancel: failed with P2P cancel failed
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2696] device (wlp0s20f3): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 30 17:24:21 The-Eagle NetworkManager[448]: <info>  [1604078661.2708] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 30 17:24:21 The-Eagle systemd[870]: Queued start job for default target Main User Target.
thats half my log from sudo journalctl -b
Thank you in advance for any help.
Hello :slightly_smiling_face:!
If your Wi-Fi is working right now, I’d advise you to install timeshift and create a snapshot immediately.
In case you Wi-Fi later stops working for some reason, you can always restore this snapshot to fix the issue temporarily. That should also allow you to better troubleshoot what might have gone wrong in case it does break.
I would generally suspect an update in the linux-firmware package behind this, but I can’t tell for sure.
This article might be interesting for you:
https://wiki.archlinux.org/index.php/Network_configuration/Wireless
Thank you Darkwav, I do already have timeshift backing up, (something I learnt on mint to do first).
To be honest the logs don’t mean much to me, is there anything in the logs that indicate the problem, maybe that’s why you already said you suspect an issue could be with the linux-firmware package.
I’ll definitely read the link you sent me thank you.
So other than using timeshift there’s no other preventative measures I can do?
What do you reckon the chances are of me getting a fix if the wifi does stop working?
I’ve got some great news for you. Googleing the log brought me to this thread on the ArchLinux Forums:
https://bbs.archlinux.org/viewtopic.php?id=246507
According to it, all you need to to is change a kernel parameter, I’ll tell you how to do that.
Step 1:
Open up GRUB’s config file in an editor like nano.
Run the following command:
sudo nano /etc/default/grub
Step 2:
Look for the GRUB_CMDLINE_LINUX_DEFAULT entry and add the following parameter in the quotation marks after it, separate it from other parameters with a simple space:
net.ifnames=0
You can paste code in nano with mouse wheel click.
It should look like this:
GRUB_CMDLINE_LINUX_DEFAULT="<some parameter that's already there> net.ifnames=0"
After you did this, save the file with CTRL+o and exit nano with CTRL+x.
Step 3:
Finally, run update-grub:
sudo update-grub
Reboot your system afterwards!
If update-grub returns any form of error, do NOT reboot your system, revert all changes and run update-grub again until it finishes sucessfully. A failed update-grub may render your system unbootable!
I really hope that is the solution, I haven’t found anything else that’s useful so far.
I thank you with the biggest thanks that I can.
I’m going to start with a fresh install doing everything correctly. I sure hope the solution you found is the fix. Either way I am extremely grateful for your time and help. could I just ask what did you google and how did you know to google it?
I won’t forget that if a update-grub ends with errors never to reboot. That’s beneficial information.
Well, I basically just looked at the journalctl logs and put the line I thought was the most important into google:
Google returned this:
https://www.google.com/search?channel=trow2&client=firefox-b-d&q=nl80211%3A+kernel+reports%3A+Attribute+failed+policy+validation
It’s basically the first search result. If the first workaround doesn’t help, you can always go to this google page and search for other workarounds, it seems like you weren’t the first one having this issue :wink:.
lol not going to believe this but it is the truth. Like I said I first had this issue on Arch and I did paste that in google too and I did actually read the link you sent me, (I was just reading it now) lol but I didn’t know or realise that I was reading a solution that could be applicable to me.
I don’t know sometimes I think my brain needs to wake up.
Its all good though, a wonderful learning process. In the future I will google, lol and when I read make sure I’m paying close attention. I think learning not to go into panic mode will also help.
Thank you again.
Very pleased to report that I checked sudo journalctl -b today and there were no logs regarding wpa_supplicant[845]: nl80211: kernel reports: Attribute failed policy validation so I’m assuming it was the correct fix for me.
