So i have a really big problem with themeing. I dont understand.
I have xfce installed, but im running i3 as wm and no de. So i have “apps” like:
- qt5settings
- kvantum manager
- lx appearance
- gtk theme config
- lightDM greater …
- qt assistant/designer/lingust
So what do all of these things do? What is the difference between Qt and GTK , how can i determine if im using one or the another and how/where should i install themes?
What is the theme that i sould use to get rid of this theme and color in firefox:
How should/could i chose the system vide theme for apps without config file themeing (like firefox etc.)
sorry if its messy and not understandable, i dont know how to say and im really anoyed of this decentralization.
Thanks for your time!
Sysinfo
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: i3 v: 4.21 dm: LightDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET69W (1.44 )
date: 05/25/2022
ID-1: BAT0 charge: 8.4 Wh (45.4%) condition: 18.5/23.9 Wh (77.2%)
volts: 11.3 min: 11.4 model: LGC 01AV489 serial: <filter>
status: discharging
ID-2: BAT1 charge: 16.0 Wh (89.4%) condition: 17.9/24.0 Wh (74.5%)
volts: 12.4 min: 11.5 model: SMP 01AV452 serial: <filter>
status: not charging
Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/1901 boost: disabled cores:
1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 792 bogomips: 30409
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-8:2 chip-ID: 04f2:b604
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x0521 res: 1920x1080
dpi: 157 diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa
22.1.7 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
Local Storage: total: 238.47 GiB used: 66.92 GiB (28.1%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKKF256G8L size: 238.47 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 29.9 C
ID-1: / size: 116.5 GiB used: 66.9 GiB (57.4%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 25.3 MiB (26.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 40.0 C pch: 38.0 C mobo: N/A
Processes: 246 Uptime: 1h 59m Memory: 7.51 GiB used: 3.05 GiB (40.6%)
Init: systemd v: 251 default: graphical Compilers: gcc: 12.2.0 Packages:
pm: pacman pkgs: 1384 Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.22
