hello i don’t understand how to set Oreo cursor , please help
Extract the downloaded archive with the cursor files to the hidden .icons
folder in your home directory. If the folder does not exist, create it. Then the cursors should be selectable in the menu.
Thank you
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
