Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=466e087b-f546-49db-b3d2-7a6d47f3a8ec rw quiet
cryptdevice=UUID=98731595-07e7-49db-8cec-31aa02e3ea9a:luks-98731595-07e7-49db-8cec-31aa02e3ea9a
root=/dev/mapper/luks-98731595-07e7-49db-8cec-31aa02e3ea9a
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: Z370 Extreme4
serial: <filter> UEFI: American Megatrends v: P3.10
date: 07/04/2018
Device-1: sony_controller_battery_90:89:5f:3e:b5:1d
model: N/A serial: N/A charge: N/A status: Charging
Topology: 6-Core model: Intel Core i7-8700K bits: 64
type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: A (10) microcode: D6 L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vmx
bogomips: 88824
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz):
1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Vulnerabilities: Type: itlb_multihit
status: KVM: Split huge pages
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache
flushes, SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: tsx_async_abort
mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti]
vendor: eVga.com. driver: nvidia v: 450.57
alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1b06
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 108
s-size: 1204x342mm (47.4x13.5") s-diag: 1252mm (49.3")
Monitor-1: DP-2 res: 2560x1440 dpi: 109
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DP-4 res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 450.57 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Device-2: NVIDIA GP102 HDMI Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:10ef
Device-3: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid bus ID: 1-3.2:4
chip ID: 054c:09cc
Device-4: Focusrite-Novation Scarlett 2i4 USB type: USB
driver: snd-usb-audio bus ID: 1-9:6 chip ID: 1235:8200
Sound Server: ALSA v: k5.8.1-3-MANJARO
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e
v: 3.2.6-k port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: eno1 state: up speed: 1000 Mbps duplex: full
mac: <filter>
Local Storage: total: 5.03 TiB used: 470.61 GiB (9.1%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP
size: 953.87 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 42AZS6AC
scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST3000DM008-2DM166
size: 2.73 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC26
scheme: GPT
ID-3: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdc vendor: Samsung model: SSD 860 EVO 1TB
size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: GPT
ID-1: / raw size: 460.89 GiB size: 452.66 GiB (98.21%)
used: 186.48 GiB (41.2%) fs: ext4 dev: /dev/dm-0
Kernel: swappiness: 60 (default)
cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 3.81 GiB
used: 1.8 MiB (0.0%) priority: -2 dev: /dev/nvme0n1p8
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia
temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 318 Uptime: 1h 43m Memory: 15.57 GiB
used: 3.52 GiB (22.6%) Init: systemd v: 245 Compilers:
gcc: 10.1.0 Packages: pacman: 1295 lib: 370 flatpak: 0
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
I’m currently unable to mount my 1tb samsung 860 evo ssd and my 3tb seagate hdd. If anyone has any idea what’s wrong, it’d be really helpful. I’m new to manjaro but I have a little bit of experience in other distros like ubuntu and mint. If there’s any other info that I can post that might help, please let me know and I’ll post it.
