Hello,
I don’t have any sound on my i3 version of manjaro. On one post I see that someone ask to run a command for the same problem so here it is :
Kernel: 5.4.181-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5e3ff3b9-1f33-478e-b658-2cb85766528c rw quiet apparmor=1
Desktop: i3 4.20.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: CHUWI Innovation And (ShenZhen) product: LarkBook
v: N/A serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends v: WX3103.2107050.008 date: 09/01/2021
ID-1: BAT0 charge: 22.2 Wh (67.1%) condition: 33.1/33.1 Wh (100.0%)
volts: 7.8 min: N/A model: N/A type: Unknown serial: <filter>
status: Discharging
RAM: total: 7.61 GiB used: 5.16 GiB (67.8%)
RAM Report:
Info: model: Intel Celeron N4120 bits: 64 type: MCP arch: Goldmont Plus
family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x1C
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1873 high: 1890 min/max: 800/2600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1859 2: 1890 3: 1890
4: 1854 bogomips: 8756
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: Realtek MTD Camera type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 0bda:0561 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: BOE Display LCD serial: <filter> built: 2019
res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.6x6.5")
diag: 337mm (13.3") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.4.181-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
any ideas ?
