Hello, when I try to use my iPhone as a hotspot for Manjaro. I can connect to my iPhone and it will show me that a device has been connected, but it won’t work, I don’t get any internet access.
Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=c1755bc6-caf6-4206-b67a-71c63a99145a rw quiet apparmor=1
security=apparmor resume=UUID=63c0d860-02e5-4a24-87f8-f4cfee8910b1
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82L7 v: IdeaPad 5 Pro 14ACN6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 14ACN6
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: GECN27WW(V1.11)
date: 10/26/2021
ID-1: BAT1 charge: 48.8 Wh (91.6%) condition: 53.3/56.5 Wh (94.3%)
volts: 12.6 min: 11.5 model: 0x53 0x75 0x6E 0x77 0x6F 0x64 0x 0x4C 0x32
0x30 0x44 0x33 0x50 0x5650 type: Li-ion serial: <filter>
status: discharging cycles: 104
RAM: total: 13.51 GiB used: 8.71 GiB (64.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 5600U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1409 high: 1524 min/max: 1600/4288 boost: disabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1524 2: 1369
3: 1397 4: 1503 5: 1397 6: 1397 7: 1394 8: 1396 9: 1397 10: 1397 11: 1395
12: 1349 bogomips: 55123
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
prctl and seccomp
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638
class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56fb class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2240x1400 s-dpi: 96 s-size: 592x370mm (23.31x14.57")
s-diag: 698mm (27.48")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0931 built: 2020
res: 2240x1400 hz: 60 dpi: 188 gamma: 1.2 size: 302x189mm (11.89x7.44")
diag: 356mm (14") ratio: 16:10 modes: max: 2240x1400 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.59-1-MANJARO) v: 4.6
Mesa 22.1.4 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:003e class-ID: 0280
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 3-4:2 chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 7 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 68.62 GiB (14.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
rev: 11190001 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%) used: 64.32 GiB
(14.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: c1755bc6-caf6-4206-b67a-71c63a99145a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 1763-AB37
ID-1: swap-1 type: partition size: 8.8 GiB used: 4.3 GiB (48.9%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 63c0d860-02e5-4a24-87f8-f4cfee8910b1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0cf3:e300 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.9 C mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 374 Uptime: 12d 14h 42m wakeups: 1917 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1445 pacman: 1441 lib: 363 flatpak: 0 snap: 4 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
