Hello
I have a problem of Bluetoth, i can’t turn it on or off, i don’t know why.
THis is what i get when i enter to the Bluetoth in settings :
can your return
inxi -Fza
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_MONETARY = "shi_MA.UTF-8",
LC_MEASUREMENT = "shi_MA.UTF-8",
LC_TIME = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=185c6bf5-f9cd-4d7f-adb1-e6899eb73647 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 17-bs0xx v: Type1ProductConfigId
Mobo: HP model: 833D v: 49.35 serial: <superuser required> UEFI: Insyde
v: F.06 date: 06/06/2017
ID-1: BAT0 charge: 0% condition: 1.1/1.1 Wh (100.0%) volts: 16.3 min: 14.6
model: 133-42-6E-A JC04041 type: Li-ion serial: <filter> status: Charging
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1944 high: 2000 min/max: 400/2000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1937 2: 1965 3: 2000
4: 1875 bogomips: 16006
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 1bcf:2c9b class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: eDP-1 res: 1600x900 hz: 60 dpi: 106
size: 382x214mm (15.0x8.4") diag: 438mm (17.2")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.049.02-NAPI modules: r8169
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-5:2 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 931.51 GiB used: 173.52 GiB (18.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A02 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 31.03 GiB (32.5%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 72.9 MiB (28.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 30.0 C pch: 28.0 C mobo: 28.0 C gpu: radeon
temp: 26.0 C
Processes: 195 Uptime: 38m wakeups: 22 Memory: 3.71 GiB
used: 1.38 GiB (37.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1551 pacman: 1549 lib: 473 flatpak: 0
snap: 2 Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.12
