mc 1 ✘
zsh: correct ‘mc’ to ‘mv’ [nyae]?
Hi @Kerogaz,
Is Midnight commander installed? Check with:
pamac search mc
Example:
$ pamac search mc
mc [Installed] 4.8.27-1 community
A file manager that emulates Norton Commander
If not, install it with:
pamac install mc
Hope this helps!
Type n
for NO, to not correct mc
with mv
and then press Enter
Is just zsh
checking if mc was a typo and should be mv, i’m sure the OP already installed the correct package.
Thanks now it work
Thanks!
My bad. For some reason I misread that as command not found.
