I made the boot card and image of manjaro arm according to the tutorial in the link(https://forum.manjaro.org/t/can-i-install-manjaro-on-nanopc-t4/24026),and tried to burn the image to emmc (through dd). However, neither the boot card nor the EMMC can start manjaro arm normally.
After the board is powered on, the output of the debug serial port is as follows:
Looks like hardware failure to me where the card is not detected it happened to me on nanopi neo where the uboot card detection fails due to sd card slot switch failure.
This might be one of the reason, this link helped me.
Can it work on any other image running over sd card?
Or maybe this is a different variant of the board?
At the same time, after burning manjaro arm on EMMC, it seems that SD card cannot be detected normally. If I press and hold the boot key when starting, I can force the official system to boot from SD card. However, if I do not press and hold the boot key when starting, the debug serial port will output the same error
Hello. Sorry to ask this question in this thread, but I am a newbie and cannot create my own theme.
I saw that there is support for NanoPC T4 in the assembly packages, but unfortunately I did not see support for NanoPi M4. Can you please tell me if you plan to add this device to the list of supported ones?
P.S.
Sorry for my English.
I think you can try to use the T4 image on M4, because on the official system, M4, T4 and neo4 use the same image.
PS
My English is translated by using translation software, so there may be various errors.
