I can't resize widget
It used to be possible with Alt+right mouse click but it doesn’t work now.
Can you resize Calendar widget? I also checked on Tiled Quicklounch - doesn’t work.
Did you try to press and hold the left mouse button on the widget? After a second or two the resize handles should appear.
It doesn’t work for me. When calendar widget is on desktop I can see handles to resize:
Imgur
but when calendar is on panel there are no such options:
Imgur
Of course I check it in edit mode.
