This is due to network topology and the expected behaviour.
When you are using the default NAT type network, you need to take into consideration the configuration of the network created by the hypervisor.
With NAT type network the hypervisor creates a virtual router and isolating the network 172.16.16.0/24 using the first IP address as gateway.
This network will be routed through your host’s NIC directly to the host’s gateway.
With VMware Workstation the NAT network can access internet but is isolated from the host network.
Example using VMware Workstaiton and a Live Manjaro Plasma ISO
ip addressing
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0c:29:38:f7:4f brd ff:ff:ff:ff:ff:ff
altname enp2s1
inet 172.16.40.128/24 brd 172.16.40.255 scope global dynamic noprefixroute ens33
valid_lft 1759sec preferred_lft 1759sec
inet6 fe80::9c53:c4cb:1a27:e0c6/64 scope link noprefixroute
Host route
$ ip route
default via 172.16.40.2 dev ens33 proto dhcp src 172.16.40.128 metric 100
172.16.40.0/24 dev ens33 proto kernel scope link src 172.16.40.128 metric 100
find the local router ip
$ traceroute forum.manjaro.org
traceroute to forum.manjaro.org (135.181.38.249), 30 hops max, 60 byte packets
1 _gateway (172.16.40.2) 1.117 ms 1.041 ms 0.942 ms
2 edge.net.nix.dk (172.30.30.1) 0.881 ms 0.813 ms 2.288 ms
3 80.209.106.129.static.fibianet.dk (80.209.106.129) 2.524 ms 3.007 ms 3.353 ms
4 89.150.69.122 (89.150.69.122) 7.385 ms 8.700 ms 8.345 ms
5 ae2.core01-tkbg.bb.fibianet.dk (89.150.64.25) 7.281 ms 8.054 ms 8.932 ms
6 * * *
7 89.150.69.66 (89.150.69.66) 6.171 ms 6.001 ms 6.084 ms
8 217.74.211.104 (217.74.211.104) 5.656 ms 5.233 ms 5.130 ms
9 194.182.97.132 (194.182.97.132) 6.815 ms 194.182.96.137 (194.182.96.137) 4.286 ms 4.510 ms
10 212.112.170.208 (212.112.170.208) 4.553 ms 4.897 ms 6.246 ms
11 146.247.200.189 (146.247.200.189) 21.190 ms 21.445 ms 21.381 ms
12 hetzner.ficix1.ficix.fi (193.110.226.44) 35.567 ms 35.386 ms 35.037 ms
13 core31.hel1.hetzner.com (213.239.224.38) 35.235 ms 35.611 ms core32.hel1.hetzner.com (213.239.224.26) 34.664 ms
14 * * *
15 spine2.cloud1.hel1.hetzner.com (213.239.228.26) 33.627 ms spine1.cloud1.hel1.hetzner.com (213.239.228.22) 33.705 ms 33.539 ms
16 * * *
17 20195.your-cloud.host (95.216.128.137) 33.698 ms 33.769 ms 33.623 ms
18 static.249.38.181.135.clients.your-server.de (135.181.38.249) 33.458 ms 33.042 ms 33.070 ms
Host network gateway
$ ping 172.30.30.1
PING 172.30.30.1 (172.30.30.1) 56(84) bytes of data.
64 bytes from 172.30.30.1: icmp_seq=1 ttl=128 time=1.39 ms
64 bytes from 172.30.30.1: icmp_seq=2 ttl=128 time=1.84 ms
64 bytes from 172.30.30.1: icmp_seq=3 ttl=128 time=1.78 ms
^C
--- 172.30.30.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2004ms
rtt min/avg/max/mdev = 1.389/1.671/1.844/0.201 ms
Internet access is possible
$ ping manjaro.org
PING manjaro.org (116.203.91.91) 56(84) bytes of data.
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=1 ttl=128 time=17.7 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=2 ttl=128 time=18.3 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=3 ttl=128 time=17.8 ms
^C
--- manjaro.org ping statistics ---
rtt min/avg/max/mdev = 17.662/17.930/18.309/0.275 ms
but the underlying network is isolated from the guest network - even knowing the host IP does not give access
$ ping 172.x.y.20
PING 172.x.y.20 (172.30.30.20) 56(84) bytes of data.
From 172.30.30.230 icmp_seq=1 Destination Host Unreachable
From 172.30.30.230 icmp_seq=2 Destination Host Unreachable
From 172.30.30.230 icmp_seq=3 Destination Host Unreachable
^C
--- 172.30.30.20 ping statistics ---
5 packets transmitted, 0 received, +3 errors, 100% packet loss, time 4062ms
pipe 3
Use shared folders in VM confiugration if you need to access host filesystem.
If you really need the VM to interact with the host network - you should use a bridged network instead.
