Out of the blue, I started getting this message in Dolphin while trying to use my external drives (tried one of them on Windows, it works there):
An error occurred while accessing '...', the system responded: The requested operation has failed: Error mounting /... at /...: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error
From my terminal:
sudo mount -t ntfs /dev/sda1 /run/media/...
fuse: failed to access mountpoint /run/media/...: No such file or directory
sudo mount -t ntfs3 /dev/sda1 /run/media/...
/run/media/...: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error.
dmesg(1) may have more information after failed mount system call.
Did I mess up the command syntax? I wish the Fine Manual had several concrete examples for dumb-dumbs.
Btw, why is this happening all of a sudden?
