I can't intall ncurses5-compat-libs
Hi,
I can’t intall ncurses5-compat-libs. When I try to install it via command
pamac build ncurses5-compat-libs
I have an error
./configure: line 31375: make: command not found
What can I do ?
Hi,
In order to build from AUR you have to have the system ready for it. Run this command first:
sudo pacman -Syu base-devel --needed
Then proceed building packages from AUR.
:mag_right:
thank yu <3
