Hello. I installed Lutrish with sudo pacman -S Lutris.
Then I tapped install ubisoft connect but not started installation. Please help me about that.
No one can help if you do not provide any information about the problem.
Please see: [HowTo] Request support
You would probably be better off posting on the Lutris Forums.
I installed Ubisoft Connect. But I getting error in title now. What can I do?
Provide more information, so others can help you. See [HowTo] Request support
I laucnhed succesfully AC: Origins in Ubisoft Launcher with Lutris.
But I got "unsupported driver , please upgrade your driver " error. How can I fix this?
Hello @ckosedag
You created 3 topics with the same issue and all containing short, vague descriptions …
Please, one more time, provide the information asked here
One relevant resource for you might be
Hello I tried but I could not. Can you help me easier?
Open up Terminal and type:
inxi -Fazy
Copy the output and paste it here using
Above and bellow the text for proper formatting.
Same for:
vulkaninfo
mhwd -li
glxinfo | grep "OpenGL renderer"
Kernel: 5.15.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6c082533-e266-443b-a855-e32053583d36 rw quiet splash apparmor=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop Mobo: BIOSTAR model: B450MH serial: <superuser required>
UEFI: American Megatrends LLC. v: 5.17 date: 06/16/2021
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2597 high: 3591 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2269 2: 3582
3: 2196 4: 2195 5: 3591 6: 2551 7: 2195 8: 2200 bogomips: 57519
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nvidia v: 515.76
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-10) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 08:00.0 chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Biostar Microtech Intl
Corp driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.15.71-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 689.33 GiB used: 72.35 GiB (10.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5003ABYZ-011FA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 0A01
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: J4.3 scheme: GPT
ID-1: / raw-size: 181.97 GiB size: 178.05 GiB (97.85%) used: 72.35 GiB
(40.6%) fs: ext4 dev: /dev/sdb6 maj-min: 8:22
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sdb5 maj-min: 8:21
System Temperatures: cpu: 52.9 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 279 Uptime: 2h 13m wakeups: 0 Memory: 7.7 GiB used: 3.89 GiB
(50.5%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1301 libs: 368
tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.22
VULKANINFO
Vulkan Instance Version: 1.3.226
Instance Extensions: count = 19
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 5
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.3.205, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (NVIDIA GeForce GTX 1660 Ti)
Layer-Device Extensions: count = 0
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (NVIDIA GeForce GTX 1660 Ti):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_UNORM
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_SRGB
Present Modes: count = 3
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
PRESENT_MODE_IMMEDIATE_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 2
maxImageCount = 8
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 1
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
supportedUsageFlags: count = 6
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
NVIDIA GeForce GTX 1660 Ti (ID: 0)
subsetAllocation = 0
Present Capabilities:
NVIDIA GeForce GTX 1660 Ti (ID: 0):
Can present images from the following devices: count = 1
Present modes: count = 1
DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4206797 (1.3.205)
driverVersion = 2161311744 (0x80d30000)
vendorID = 0x10de
deviceID = 0x2182
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = NVIDIA GeForce GTX 1660 Ti
pipelineCacheUUID = 9c5547cc-3f97-f47a-3bad-60a16c124118
VkPhysicalDeviceLimits:
maxImageDimension1D = 32768
maxImageDimension2D = 32768
maxImageDimension3D = 16384
maxImageDimensionCube = 32768
maxImageArrayLayers = 2048
maxTexelBufferElements = 134217728
maxUniformBufferRange = 65536
maxStorageBufferRange = 4294967295
maxPushConstantsSize = 256
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 4000
bufferImageGranularity = 0x00000400
sparseAddressSpaceSize = 0xffffffffff
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 1048576
maxPerStageDescriptorUniformBuffers = 1048576
maxPerStageDescriptorStorageBuffers = 1048576
maxPerStageDescriptorSampledImages = 1048576
maxPerStageDescriptorStorageImages = 1048576
maxPerStageDescriptorInputAttachments = 1048576
maxPerStageResources = 4294967295
maxDescriptorSetSamplers = 1048576
maxDescriptorSetUniformBuffers = 1048576
maxDescriptorSetUniformBuffersDynamic = 15
maxDescriptorSetStorageBuffers = 1048576
maxDescriptorSetStorageBuffersDynamic = 16
maxDescriptorSetSampledImages = 1048576
maxDescriptorSetStorageImages = 1048576
maxDescriptorSetInputAttachments = 1048576
maxVertexInputAttributes = 32
maxVertexInputBindings = 32
maxVertexInputAttributeOffset = 2047
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 120
maxTessellationControlTotalOutputComponents = 4216
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 128
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 1024
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 128
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 4294967295
maxComputeSharedMemorySize = 49152
maxComputeWorkGroupCount: count = 3
2147483647
65535
65535
maxComputeWorkGroupInvocations = 1024
maxComputeWorkGroupSize: count = 3
1024
1024
64
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 15
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
32768
32768
viewportBoundsRange: count = 2
-65536
65536
viewportSubPixelBits = 8
minMemoryMapAlignment = 64
minTexelBufferOffsetAlignment = 0x00000010
minUniformBufferOffsetAlignment = 0x00000040
minStorageBufferOffsetAlignment = 0x00000010
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 32768
maxFramebufferHeight = 32768
maxFramebufferLayers = 2048
framebufferColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferNoAttachmentsSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
storageImageSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 1
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
1
2047.94
lineWidthRange: count = 2
1
64
pointSizeGranularity = 0.0625
lineWidthGranularity = 0.0625
strictLines = true
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000001
optimalBufferCopyRowPitchAlignment = 0x00000001
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = true
residencyStandard2DMultisampleBlockShape = true
residencyStandard3DBlockShape = true
residencyAlignedMipSize = false
residencyNonResidentStrict = true
VkPhysicalDeviceAccelerationStructurePropertiesKHR:
maxGeometryCount = 16777215
maxInstanceCount = 16777215
maxPrimitiveCount = 536870911
maxPerStageDescriptorAccelerationStructures = 1048576
maxPerStageDescriptorUpdateAfterBindAccelerationStructures = 1048576
maxDescriptorSetAccelerationStructures = 1048576
maxDescriptorSetUpdateAfterBindAccelerationStructures = 1048576
minAccelerationStructureScratchOffsetAlignment = 128
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
advancedBlendMaxColorAttachments = 8
advancedBlendIndependentBlend = false
advancedBlendNonPremultipliedSrcColor = true
advancedBlendNonPremultipliedDstColor = true
advancedBlendCorrelatedOverlap = true
advancedBlendAllOperations = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
primitiveOverestimationSize = 0.00195312
maxExtraPrimitiveOverestimationSize = 0.75
extraPrimitiveOverestimationSizeGranularity = 0.25
primitiveUnderestimation = true
conservativePointAndLineRasterization = true
degenerateTrianglesRasterized = true
degenerateLinesRasterized = true
fullyCoveredFragmentShaderInputVariable = true
conservativeRasterizationPostDepthCoverage = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
maxCustomBorderColorSamplers = 4000
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 3
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 4294967295
shaderUniformBufferArrayNonUniformIndexingNative = true
shaderSampledImageArrayNonUniformIndexingNative = true
shaderStorageBufferArrayNonUniformIndexingNative = true
shaderStorageImageArrayNonUniformIndexingNative = true
shaderInputAttachmentArrayNonUniformIndexingNative = true
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = true
maxPerStageDescriptorUpdateAfterBindSamplers = 1048576
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 1048576
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 1048576
maxPerStageDescriptorUpdateAfterBindSampledImages = 1048576
maxPerStageDescriptorUpdateAfterBindStorageImages = 1048576
maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
maxPerStageUpdateAfterBindResources = 4294967295
maxDescriptorSetUpdateAfterBindSamplers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
maxDescriptorSetUpdateAfterBindStorageBuffers = 1048576
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
maxDescriptorSetUpdateAfterBindSampledImages = 1048576
maxDescriptorSetUpdateAfterBindStorageImages = 1048576
maxDescriptorSetUpdateAfterBindInputAttachments = 1048576
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
maxDiscardRectangles = 8
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 515.76
conformanceVersion:
major = 1
minor = 3
subminor = 1
patch = 0
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 0
renderMajor = 226
renderMinor = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = true
shaderDenormPreserveFloat32 = false
shaderDenormPreserveFloat64 = false
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = false
shaderDenormFlushToZeroFloat64 = false
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = false
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceFragmentShadingRatePropertiesKHR:
minFragmentShadingRateAttachmentTexelSize:
width = 16
height = 16
maxFragmentShadingRateAttachmentTexelSize:
width = 16
height = 16
maxFragmentShadingRateAttachmentTexelSizeAspectRatio = 1
primitiveFragmentShadingRateWithMultipleViewports = false
layeredShadingRateAttachments = true
fragmentShadingRateNonTrivialCombinerOps = true
maxFragmentSize:
width = 4
height = 4
maxFragmentSizeAspectRatio = 2
maxFragmentShadingRateCoverageSamples = 16
maxFragmentShadingRateRasterizationSamples = SAMPLE_COUNT_16_BIT
fragmentShadingRateWithShaderDepthStencilWrites = true
fragmentShadingRateWithSampleMask = true
fragmentShadingRateWithShaderSampleMask = true
fragmentShadingRateWithConservativeRasterization = true
fragmentShadingRateWithFragmentShaderInterlock = true
fragmentShadingRateWithCustomSampleLocations = true
fragmentShadingRateStrictMultiplyCombiner = true
VkPhysicalDeviceIDProperties:
deviceUUID = d4ced534-ab08-719d-7148-a286f08f7822
driverUUID = 0d91d1a5-7bc0-5373-923a-1f40774e46a8
deviceNodeMask = 1
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockProperties:
maxInlineUniformBlockSize = 256
maxPerStageDescriptorInlineUniformBlocks = 32
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
maxDescriptorSetInlineUniformBlocks = 32
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 8
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 4294967295
maxMemoryAllocationSize = 0xffe00000
VkPhysicalDeviceMaintenance4Properties:
maxBufferSize = 0xffffffffffff0000
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 4294967295
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 32
maxMultiviewInstanceIndex = 134217727
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 8
pciDevice = 0
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRayTracingPipelinePropertiesKHR:
shaderGroupHandleSize = 32
maxRayRecursionDepth = 31
maxShaderGroupStride = 4096
shaderGroupBaseAlignment = 64
shaderGroupHandleCaptureReplaySize = 32
maxRayDispatchInvocationCount = 1073741824
shaderGroupHandleAlignment = 32
maxRayHitAttributeSize = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000001
robustUniformBufferAccessSizeAlignment = 0x00000010
VkPhysicalDeviceSampleLocationsPropertiesEXT:
sampleLocationSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
maxSampleLocationGridSize:
width = 1
height = 1
sampleLocationCoordinateRange: count = 2
0
0.9375
sampleLocationSubPixelBits = 4
variableSampleLocations = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = true
filterMinmaxImageComponentMapping = true
VkPhysicalDeviceShaderIntegerDotProductProperties:
integerDotProduct8BitUnsignedAccelerated = true
integerDotProduct8BitSignedAccelerated = true
integerDotProduct8BitMixedSignednessAccelerated = true
integerDotProduct4x8BitPackedUnsignedAccelerated = true
integerDotProduct4x8BitPackedSignedAccelerated = true
integerDotProduct4x8BitPackedMixedSignednessAccelerated = true
integerDotProduct16BitUnsignedAccelerated = false
integerDotProduct16BitSignedAccelerated = false
integerDotProduct16BitMixedSignednessAccelerated = false
integerDotProduct32BitUnsignedAccelerated = false
integerDotProduct32BitSignedAccelerated = false
integerDotProduct32BitMixedSignednessAccelerated = false
integerDotProduct64BitUnsignedAccelerated = false
integerDotProduct64BitSignedAccelerated = false
integerDotProduct64BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating8BitUnsignedAccelerated = true
integerDotProductAccumulatingSaturating8BitSignedAccelerated = true
integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated = true
integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated = true
integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated = true
integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = true
integerDotProductAccumulatingSaturating16BitUnsignedAccelerated = true
integerDotProductAccumulatingSaturating16BitSignedAccelerated = true
integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated = true
integerDotProductAccumulatingSaturating32BitUnsignedAccelerated = true
integerDotProductAccumulatingSaturating32BitSignedAccelerated = true
integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated = true
integerDotProductAccumulatingSaturating64BitUnsignedAccelerated = true
integerDotProductAccumulatingSaturating64BitSignedAccelerated = true
integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated = true
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 32
supportedStages: count = 16
SHADER_STAGE_VERTEX_BIT
SHADER_STAGE_TESSELLATION_CONTROL_BIT
SHADER_STAGE_TESSELLATION_EVALUATION_BIT
SHADER_STAGE_GEOMETRY_BIT
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
SHADER_STAGE_ALL_GRAPHICS
SHADER_STAGE_ALL
SHADER_STAGE_RAYGEN_BIT_KHR
SHADER_STAGE_ANY_HIT_BIT_KHR
SHADER_STAGE_CLOSEST_HIT_BIT_KHR
SHADER_STAGE_MISS_BIT_KHR
SHADER_STAGE_INTERSECTION_BIT_KHR
SHADER_STAGE_CALLABLE_BIT_KHR
SHADER_STAGE_TASK_BIT_EXT
SHADER_STAGE_MESH_BIT_EXT
supportedOperations: count = 9
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_ARITHMETIC_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_CLUSTERED_BIT
SUBGROUP_FEATURE_QUAD_BIT
SUBGROUP_FEATURE_PARTITIONED_BIT_NV
quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlProperties:
minSubgroupSize = 32
maxSubgroupSize = 32
maxComputeWorkgroupSubgroups = 2097152
requiredSubgroupSizeStages: count = 16
SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentProperties:
storageTexelBufferOffsetAlignmentBytes = 0x00000010
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000010
uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0xffffffff
maxTransformFeedbackStreamDataSize = 2048
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 2048
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = false
transformFeedbackRasterizationStreamSelect = true
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 1
subgroupSize = 32
subgroupSupportedStages: count = 16
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 9
subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
driverName = NVIDIA
driverInfo = 515.76
conformanceVersion:
major = 1
minor = 3
subminor = 1
patch = 0
framebufferIntegerColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
VkPhysicalDeviceVulkan13Properties:
SHADER_STAGE_ALL
maxInlineUniformTotalSize = 3584
Device Extensions: count = 155
VK_EXT_4444_formats : extension revision 1
VK_EXT_blend_operation_advanced : extension revision 2
VK_EXT_border_color_swizzle : extension revision 1
VK_EXT_buffer_device_address : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_custom_border_color : extension revision 12
VK_EXT_depth_clip_control : extension revision 1
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_fragment_shader_interlock : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_global_priority_query : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 2
VK_EXT_image_robustness : extension revision 1
VK_EXT_image_view_min_lod : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_load_store_op_none : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_primitive_topology_list_restart : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 2
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_image_atomic_int64 : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_tooling_info : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_vertex_input_dynamic_state : extension revision 2
VK_EXT_ycbcr_2plane_444_formats : extension revision 1
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_acceleration_structure : extension revision 13
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_dynamic_rendering : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_format_feature_flags2 : extension revision 1
VK_KHR_fragment_shading_rate : extension revision 2
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_global_priority : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_maintenance4 : extension revision 2
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_pipeline_library : extension revision 1
VK_KHR_present_id : extension revision 1
VK_KHR_present_wait : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_ray_tracing_pipeline : extension revision 1
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_integer_dot_product : extension revision 1
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_extended_types : extension revision 1
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_synchronization2 : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NVX_binary_import : extension revision 1
VK_NVX_image_view_handle : extension revision 2
VK_NVX_multiview_per_view_attributes : extension revision 1
VK_NV_clip_space_w_scaling : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
VK_NV_corner_sampled_image : extension revision 2
VK_NV_coverage_reduction_mode : extension revision 1
VK_NV_cuda_kernel_launch : extension revision 2
VK_NV_dedicated_allocation : extension revision 1
VK_NV_dedicated_allocation_image_aliasing : extension revision 1
VK_NV_device_diagnostic_checkpoints : extension revision 2
VK_NV_device_diagnostics_config : extension revision 1
VK_NV_device_generated_commands : extension revision 3
VK_NV_fill_rectangle : extension revision 1
VK_NV_fragment_coverage_to_color : extension revision 1
VK_NV_fragment_shader_barycentric : extension revision 1
VK_NV_fragment_shading_rate_enums : extension revision 1
VK_NV_framebuffer_mixed_samples : extension revision 1
VK_NV_geometry_shader_passthrough : extension revision 1
VK_NV_inherited_viewport_scissor : extension revision 1
VK_NV_linear_color_attachment : extension revision 1
VK_NV_mesh_shader : extension revision 1
VK_NV_ray_tracing : extension revision 3
VK_NV_representative_fragment_test : extension revision 2
VK_NV_sample_mask_override_coverage : extension revision 1
VK_NV_scissor_exclusive : extension revision 1
VK_NV_shader_image_footprint : extension revision 2
VK_NV_shader_sm_builtins : extension revision 1
VK_NV_shader_subgroup_partitioned : extension revision 1
VK_NV_shading_rate_image : extension revision 3
VK_NV_viewport_array2 : extension revision 1
VK_NV_viewport_swizzle : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 16
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
timestampValidBits = 64
present support = true
VkQueueFamilyGlobalPriorityPropertiesKHR:
priorityCount = 1
priorities: count = 1
QUEUE_GLOBAL_PRIORITY_MEDIUM_KHR
queueProperties[1]:
queueCount = 2
queueFlags = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
present support = false
priorityCount = 1
queueProperties[2]:
queueCount = 8
queueFlags = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
priorityCount = 1
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
memoryHeaps[0]:
size = 6442450944 (0x180000000) (6.00 GiB)
budget = 5538316288 (0x14a1c0000) (5.16 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryHeaps[1]:
size = 6198515712 (0x17175d800) (5.77 GiB)
budget = 6198515712 (0x17175d800) (5.77 GiB)
flags:
None
memoryHeaps[2]:
size = 257949696 (0x0f600000) (246.00 MiB)
budget = 217513984 (0x0cf70000) (207.44 MiB)
usage = 40435712 (0x02690000) (38.56 MiB)
flags: count = 1
memoryTypes: count = 5
memoryTypes[0]:
heapIndex = 1
propertyFlags = 0x0000:
None
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
FORMAT_D24_UNORM_S8_UINT
FORMAT_D32_SFLOAT_S8_UINT
IMAGE_TILING_LINEAR:
color images
(non-sparse, non-transient)
memoryTypes[1]:
heapIndex = 0
propertyFlags = 0x0001: count = 1
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[2]:
heapIndex = 1
propertyFlags = 0x0006: count = 2
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
usable for:
None
color images
memoryTypes[3]:
heapIndex = 1
propertyFlags = 0x000e: count = 3
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
None
color images
memoryTypes[4]:
heapIndex = 2
propertyFlags = 0x0007: count = 3
usable for:
None
color images
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = true
shaderStorageImageReadWithoutFormat = true
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = true
shaderInt64 = true
shaderInt16 = true
shaderResourceResidency = true
shaderResourceMinLod = true
sparseBinding = true
sparseResidencyBuffer = true
sparseResidencyImage2D = true
sparseResidencyImage3D = true
sparseResidency2Samples = true
sparseResidency4Samples = true
sparseResidency8Samples = true
sparseResidency16Samples = true
sparseResidencyAliased = true
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = true
uniformAndStorageBuffer8BitAccess = true
storagePushConstant8 = true
VkPhysicalDeviceAccelerationStructureFeaturesKHR:
accelerationStructure = true
accelerationStructureCaptureReplay = true
accelerationStructureIndirectBuild = false
accelerationStructureHostCommands = false
descriptorBindingAccelerationStructureUpdateAfterBind = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
advancedBlendCoherentOperations = true
VkPhysicalDeviceBorderColorSwizzleFeaturesEXT:
borderColorSwizzle = true
borderColorSwizzleFromImage = false
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = true
bufferDeviceAddressCaptureReplay = true
bufferDeviceAddressMultiDevice = true
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
customBorderColors = true
customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = true
shaderUniformTexelBufferArrayDynamicIndexing = true
shaderStorageTexelBufferArrayDynamicIndexing = true
shaderUniformBufferArrayNonUniformIndexing = true
shaderSampledImageArrayNonUniformIndexing = true
shaderStorageBufferArrayNonUniformIndexing = true
shaderStorageImageArrayNonUniformIndexing = true
shaderInputAttachmentArrayNonUniformIndexing = true
shaderUniformTexelBufferArrayNonUniformIndexing = true
shaderStorageTexelBufferArrayNonUniformIndexing = true
descriptorBindingUniformBufferUpdateAfterBind = true
descriptorBindingSampledImageUpdateAfterBind = true
descriptorBindingStorageImageUpdateAfterBind = true
descriptorBindingStorageBufferUpdateAfterBind = true
descriptorBindingUniformTexelBufferUpdateAfterBind = true
descriptorBindingStorageTexelBufferUpdateAfterBind = true
descriptorBindingUpdateUnusedWhilePending = true
descriptorBindingPartiallyBound = true
descriptorBindingVariableDescriptorCount = true
runtimeDescriptorArray = true
VkPhysicalDeviceDynamicRenderingFeatures:
dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = true
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceFragmentShaderBarycentricFeaturesKHR:
fragmentShaderBarycentric = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
fragmentShaderSampleInterlock = true
fragmentShaderPixelInterlock = true
fragmentShaderShadingRateInterlock = true
VkPhysicalDeviceFragmentShadingRateFeaturesKHR:
pipelineFragmentShadingRate = true
primitiveFragmentShadingRate = true
attachmentFragmentShadingRate = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesKHR:
globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeatures:
robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeatures:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = true
bresenhamLines = true
smoothLines = true
stippledRectangularLines = true
stippledBresenhamLines = true
stippledSmoothLines = true
VkPhysicalDeviceMaintenance4Features:
maintenance4 = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeatures:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePresentIdFeaturesKHR:
presentId = true
VkPhysicalDevicePresentWaitFeaturesKHR:
presentWait = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
primitiveTopologyListRestart = true
primitiveTopologyPatchListRestart = true
VkPhysicalDevicePrivateDataFeatures:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRayTracingPipelineFeaturesKHR:
rayTracingPipeline = true
rayTracingPipelineShaderGroupHandleCaptureReplay = false
rayTracingPipelineShaderGroupHandleCaptureReplayMixed = false
rayTracingPipelineTraceRaysIndirect = true
rayTraversalPrimitiveCulling = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = true
shaderBufferFloat64Atomics = true
shaderBufferFloat64AtomicAdd = true
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = true
shaderSharedFloat64Atomics = true
shaderSharedFloat64AtomicAdd = true
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = true
sparseImageFloat32Atomics = true
sparseImageFloat32AtomicAdd = true
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = true
shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeatures:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = true
shaderInt8 = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
shaderImageInt64Atomics = true
sparseImageInt64Atomics = true
VkPhysicalDeviceShaderIntegerDotProductFeatures:
shaderIntegerDotProduct = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeatures:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeatures:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceSynchronization2Features:
synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTextureCompressionASTCHDRFeatures:
textureCompressionASTC_HDR = false
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVertexInputDynamicStateFeaturesEXT:
vertexInputDynamicState = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = true
descriptorIndexing = true
samplerFilterMinmax = true
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = true
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkan13Features:
privateData = true
shaderZeroInitializeWorkgroupMemory = true
maintenance4 = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcr2Plane444FormatsFeaturesEXT:
ycbcr2plane444Formats = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeatures:
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
OpenGL renderer string: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
If you run from terminal this command:
nvidia-modprobe -u -c=0
can you then launch successfully the game you want via Lutris or the Ubisoft Connect?
I already can launch but in game, game is freezing. By proton.db this game is gold so it can open and run without problems. Thank you your answers. I am trying this one :
@anon89812132 hello, not worked. Same. I got error same in Ubi-Connect.
Recently I had a similar issue with Steam, solution was explicitly specify the path to the nvidia_icd.json. For any reason it didn’t work without it and I don’t what actually changed, since it works without it in the past. Maybe because of Steam Runtime?
Add it like that in the start up options:
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json gamemoderun mangohud %command%
Assassins Creed 2 works then in Steam with Ubisoft Connect. Note that you need to install Ubisoft connect manually with protontricks or on the commandline.
Sorry but I did not understand exactly what I need do? Can you be explanatory please? And again sorry bad English.
And I bought game from Ubisoft not steam.
That doesn’t matter, steam or ubisoft. Both use the ubisoft launcher.
In Lutris you need to add the environment variable with that value:
So:
Key → VK_ICD_FILENAMES
Value → /usr/share/vulkan/icd.d/nvidia_icd.json
(clearly when it is nvidia)
In here (command prefix?):
@megavolt And this time Ubisoft Connect did not launch. I did not see logging screen. ![]()
Sorry, no idea ![]()
- driver is working
- vulkan is working
Must be clearly a lutris problem.
How can I play AC: Origins in Linux? I dont want get back to Windows ![]()
@ckosedag Ok just checked…
- Top right, click on the hamburger menu
- Go to global settings
As explained… add here key + value at the environment variables.
Restart lutris.
Manjaro team is doing a fantastic job of making cutting edge Linux available - but being available and working on the majority of hardware does imply it is working for you.
Just as macOS is different so is Linux and you cannot mogrify your knowledge of Windows to Linux. Also 90% of all software in the world is designed around Windows
Linux != Windows - you cannot expect Windows programs to run flawless.
When you are asked to provide info - provide it - don’t ask the same question again and again - not even if you rephrase it - after a while you will end up being ignored completely - perhaps even banned.
- Be aware of the xy problem (http://xyproblem.info)
- Be ready to do your homework
- Search before asking
- Think
- Make notes - what did you do - what worked - what did not
- Experiment - be ready to screw up your system
- Use timeshift to roll back when your experiment fail
- Ask the right question(s) - be clear - not vague
- Be informative - the exact error messages
- Be more informative - what have you already tried
- Be specific - not vague - every system is different - every user is different
- Provide info - (no screenshots) - copy paste text from the terminal
